I am struggling to post a file from SolidCAM. When a G2 or G3 command are repeated, it doesnt include a G2, or G3 on the following line. KMotionCNC doesnt like this.
I am wondering why it can take a G00 or G01 in this way, but not a G02 or G03. Is there anything I can do in KMotion, or do I have to fix the post processor.
60 (Contour Mill1)
N61 X14.3359 Y7.1835
N62 Z.1
N63 G01 Z-.1875 F30.
N64 X14.1984 Y7.0453 F90.
N65 G03 X14.1875 Y7.0187 I.0266 J-.0264
N66 G02 Y7. I-7.1875 J-.0187 F120.
N67 I-7.1875 J0
N68 Y6.9813 I-7.1875 J0
N69 G03 X14.1984 Y6.9547 I.0375 J0
N70 G01 X14.3359 Y6.8165
N71 G00 Z.1
N72 Y7.1835
N73 Z-.0875
N74 G01 Z-.3438 F30.
N75 X14.1984 Y7.0453 F90.
N76 G03 X14.1875 Y7.0187 I.0266 J-.0264
N77 G02 Y7. I-7.1875 J-.0187 F120.
N78 I-7.1875 J0
N79 Y6.9813 I-7.1875 J0
N80 G03 X14.1984 Y6.9547 I.0375 J0
N81 G01 X14.3359 Y6.8165
N82 G00 Z.1
N83 Y7.1835
N84 Z-.2438
N85 G01 Z-.5 F30.
N86 X14.1984 Y7.0453 F90.
N87 G03 X14.1875 Y7.0187 I.0266 J-.0264
N88 G02 Y7. I-7.1875 J-.0187 F120.
N89 I-7.1875 J0
N90 Y6.9813 I-7.1875 J0
N91 G03 X14.1984 Y6.9547 I.0375 J0
N92 G01 X14.3359 Y6.8165
N93 G00 Z.1
N94 Z1. M09
N95 M05 (M-TOOL STOP)
N96 G91 G28 G00 Z0.
N97 G91 G28 G00 X0. Y0.
N98 G90
N99 M30
Scott
I word with no g2 or g3
Re: I word with no g2 or g3
Hi Scott,
The Interpreter needs an "X" or "Y" word or the G3 to be specified. Was that intending to be a full circle? Do you have an option to specify half circles?
I am not sure if it was intending full or half, when I manually type G03 or G02 in on the lines it seems to work without the an X or Y word. It is getting tedious manually editing the code.
Hi Scott,
Normally to do a motion at least one axis needs to be commanded to move. Otherwise something such as a blank line could be treated as a repeated move.
But I suppose a full circle is a special exception as i j k at least must be specified.
Here is a patched GCodeInterpreter.dll for V4.35f that should permit it. Copy to the C:\KMotion4.35f\Kmotion\release folder.
Please let us know if it works and if it causes any other issues.
Hello
I am having the same as Scott
I word with nog2 or g3
I gave tried the GCodeInterpreter.dll but Kmotioncnc wont start up with it.
Any help would be appreciated.
Regards Tony
Regards Tony
Hi Tony,
Are you running Version 4.35f ?
