Encoder Ratio
CNC_Machines
Encoder Ratio
Post by CNC_Machines » Tue Dec 03, 2019 6:15 pm
Greetings,
I want to be sure I understand how the input/output gain works. To ensure I am setting up correctly.
Hardware:
1. KStep - 16X Microstepping
2. Oriental Motor 0.9 Step Angle Stepper
3. Encoder - US Digital 5000 count quadrature
I am getting confused with "Inv Dist Per Cycle", I have always set that to 1. Is this how the math works?
Cycles/Rotation = 400/4 = 100
Micro Steps / Rotation = 16x100 = 1600
Encoder / Motor = 1600/5000 = 3.125
So the value I would enter into the "Input Gain" field would be 3.125?
Or would it be this way?
Steps / Rotation = 400 x 16 = 6400
Encoder Pulses / Rotation = 5000 x 4 = 20000
Ratio = 20000/6400 = 3.125
They both end up being the same value. I am just wondering which is the correct way to think about it?
Scott
Re: Encoder Ratio
Post by TomKerekes » Tue Dec 03, 2019 6:43 pm
Hi Scott,
Inv Dist Per Cycle doesn't apply to Step/Dir Drives like KStep.
No.
400 full steps/rev x 16 uSteps/Full Step = 6400 uSteps/rev
This depends on whether the number 5000 is quadrature counts/rev or Pulses or cycles per rev. You initially state it is quadrature count but then treat it as cycles.
Assuming the 20000 quadrature counts is correct then an input Gain of:
6400/20000 = 0.32
Its easy to figure out these things yourself. Try a number and if it is off by a factor of X change it.
