Hi Az,
The first step is to get your axes working within our KMotion.exe configuration program.
The first step within that is to determine what type of drives
you have and type of inputs they have. I assume you have Step/Dir type of drives.
Our Step/Dir Generators are hardware devices assigned to fixed pins. (An axis can not use any IO pins you want, but it can use any device you want). Please see:
http://dynomotion.com/Help/SchematicsKFLOP/KFLOPFunctionalDiagram.htm
Step/Dir is described here:
http://dynomotion.com/Help/StepAndDirection/StepAndDir.htm
Then test the axis by loading an example motor configuration such as:
SimpleStepDirAxis0.mot
and
use the Step Response Screen to test the axis
After all your axes are working you will need to create a C program that can initialize everything by defining all the axis parameters, enabling the axes and amplifiers, and defining the Gcode Coordinate System axes. The technique is very similar for either Mach3 or KMotionCNC.
For an overview see:
http://dynomotion.com/Help/FlashHelp/Parameters/index.html
and this process for Mach3 includes the steps for making an Initialization C Program.
http://dynomotion.com/Help/Mach3Plugin/Mach3.htm
You should then be ready to run KMotionCNC. Use the Tool Setup Screens in KMotionCNC to set a button to run your Initialization C program. Set the System Resolution and Trajectory Planner settings. Configure any MCode operations you need.
See:
http://dynomotion.com/Help/KMotionCNC/ToolSetupScreenM3.htm
Message: 6280 |
Date: 12/13/2012 |
| Subject: Re: kmotion cnc startup |
Thank you. I'll start with that.
AZ
> Hi Az,
> The first step within that is to determine what type of drives you have and type of inputs they have. I assume you have Step/Dir type of drives.
> and use the Step Response Screen to test the axis
> You should then be ready to run KMotionCNC. Use the Tool Setup Screens in KMotionCNC to set a button to run your Initialization C program. Set the System Resolution and Trajectory Planner settings. Configure any MCode operations you need. See:
> HTH
> From: "azubar@..." <az@...>
> Sent: Thursday, December 13, 2012 5:13 AM
> Subject: [DynoMotion] kmotion cnc startup
> I'mHi new to Kmotion but not to programmable motion control. Plus I'm kind of impatient...
> Is there a punch list of things I need to do to set up a very simple 2 axis stepper cnc machine with 2 M-code outputs and maybe two inputs.
> In the case of a simple CNC machine how much C code would there be needed?
> I'm sure once the basic machine is implemented I'll find things I'd like to add and it looks like Kmotion gives me lots of opportunity to do that.
> Thanks
> AZ
