Hi Tapio,
You shouldn't need to do any calculation KFLOP should handle that for you. You can command the MoveAtVel(0,900,300) from a stop or any time while the Jog is in progress (as long as there is still sufficient distance to stop).
Message: 8528 |
Date: 10/24/2013 |
| Subject: Re: jog to length? |
Hi Tom!
It looks that I tried too much to avoid the
language barrier, which led to a wrong question so I'll refrase:
I'm looking for a way to follow the path of two
intersecting cylinders with one linear and one rotational axis.
I need this to be in user program, outside the coord motion since
that is busy doing other stuff.
I think I ment: How do I calculate the
accel/decel distance so that a series of jog commands with alternating
speed would result new speed being in effect
at the beginning of the motion segment(?)?
instead of:
Jog(0,300) while Pos(0)<=900
Jog(0,200) while Pos(0)<=1200
Jog(0,400) while Pos(0)<=1500
I'd like to have
Jog(0,300) while Pos(0)<=900-X
Jog(0,200) while Pos(0)<=1200-X
Jog(0,400) while Pos(0)<=1500-X
so that speed is 200 starting from Pos(0)=900.
Would two consecutive MoveAtVel commands not result
in gap/stop in between?
Are the MasterAxis/Slavegain available outside the
coordmotion system?
Rgds,
Tapio
----- Original Message -----
Sent: Thursday, October 24, 2013 1:27
AM
Subject: Re: [DynoMotion] jog to
length?
Hi Tapio,
You
stop).
Message: 8529 |
Date: 10/24/2013 |
Hi Tapio,
I'm afraid I still don't understand.
Intersecting cylinders?
But anyway yes you can issue a new MoveAtVel before a previous is finished and the motion should blend together smoothly.
The Master Slave capabilities are independent of Coordinated Motion. A Slave can follow any axis regardless.
Message: 8575 |
Date: 11/5/2013 |
Hi Tom!
Intersecting cylinders means two perpendicular pipes.
Are consecutive MoveAtVel commands buffered or does next command override previous?
Rgds,
Tapio
---In DynoMotion@yahoogroups.com, <tk@...> wrote:
Hi Tapio,
Message: 8577 |
Date: 11/5/2013 |
Hi Tapio,
The next overrides the previous. If motion is in progress and a new Move or Jog is commanded, KFLOP will compute a new blended 3rd order trajectory starting at the current position, velocity, and acceleration to go to the new Move position or Jog velocity.
Message: 8584 |
Date: 11/6/2013 |
Is the slavegain similar? meaning overrides
previous as soon as executed?
Rgds,
Tapio
Sent: Tuesday, November 05, 2013 11:45
PM
Subject: Re: Re: [DynoMotion] jog to
length?
Hi Tapio,
The
Message: 8586 |
Date: 11/6/2013 |
Hi Tapio,
In a way yes. It has an instantaneous effect overriding any previous value. The slave gain causes the Slave Destination to change at the amount the master changed multiplied by the Gain. So you would need to use caution. For example if the Slave gain was 1.0 and the Master was moving at 10,000 counts/sec, and the Slave Gain was suddenly changed to 2.0, then the Slave would instantly change from moving at 10,000 counts/sec to 20,000 counts/sec which would be
likely to cause a stall or fault.
