Group: DynoMotion Message: 5077 From: himykabibble Date: 5/27/2012
Subject: dotNet Question
How can I access the channel structure LimitSwitchOptions field from a dotNet app? Or, is there some other way to determine that an axis has hit a limit?
Ray L.
Group: DynoMotion Message: 5087 From: himykabibble Date: 5/29/2012
Subject: Re: dotNet Question
No answer on this??
> Regards,
> Ray L.
Group: DynoMotion Message: 5088 From: brad murry Date: 5/29/2012
I made a helper function that packs the options into a valid hex value.  If it is not in the km_axis class I must have put it elsewhere and will dig it up
-Brad Murry
Sent: 5/29/2012 5:26 PM
Subject: [DynoMotion] Re: dotNet Question
No answer on this??
> Regards,
> Ray L.
Group: DynoMotion Message: 5089 From: Tom Kerekes Date: 5/29/2012
Hi Ray,
Sorry I missed this. But I'm not exactly sure what you are asking.
There is a Console Script command that can set the Limit Switch Options.  See:
When an axis hits a limit the axis is disabled.
A message is sent to the Console such as:
Axis:N
Neg Limit Disabled
Otherwise you might need to check the limit input bit status.
Group: DynoMotion Message: 5092 From: himykabibble Date: 5/29/2012
What I'd like to be able to do is read the limit switch options from my app, to aid in limit handling in the app. Is there a way to do that?
Also, right now, when I hit a limit, the axis is getting disabled, but when I check the enable state through dotNet, it does not show as disabled. I'm still using 429x, so hopefully that is a bug that is fixed in 429?
Ray L.
> Hi Ray,
> http://www.dynomotion.com/Help/Cmd.htm#LimitSwitch
>  Axis:N
> TKNeg Limit Disabled
> Sent: Tuesday, May 29, 2012 5:26 PM
> No answer on this??
> > Regards,
> > Ray L.
Group: DynoMotion Message: 5094 From: bradodarb Date: 5/29/2012
I updated the .net source to implement the limit switch functionality as you would find it when configuring in KMotion.exe -> Setup and Config.
Have a look at the TuningParams property of the KM_Axis object and let me know if you have any questions.
As previously stated, this was implemented in MM and I did test it there, but have not tested it here. Please report your findings.
-Brad
> Tom,
> Regards,
> Ray L.
> > Hi Ray,
> >  Axis:N
> > No answer on this??
> > > Regards,
> > > Ray L.
Group: DynoMotion Message: 5095 From: himykabibble Date: 5/29/2012
Brad,
I'm not sure that does what I need. My DSP limit changes the LimitSwitchOptions on-the-fly - has to in order to handle the way limit switches are configured on my machine. It doesn't appear to me that the TuningParameters->LimitSwitch value gets updated dynamically.
Ray L.
> -Brad
> > Tom,
> > Regards,
> > Ray L.
> > > Hi Ray,
> > >  Axis:N
> > > Regards
> > > No answer on this??
> > > > Regards,
> > > > Ray L.
Group: DynoMotion Message: 5096 From: bradodarb Date: 5/29/2012
LimitSwitch is just a property wrapper around the console command.(Mainly if you were packing your own values into a hex screen)
Have a look at properties::
LimitSwitchWatchNeg
LimitSwitchStopWhenLowNeg
LimitSwitchBitNeg
LimitSwitchWatchPos
LimitSwitchStopWhenLowPos
LimitSwitchBitPos
LimitSwitchAction
Set those as you would in KMotion.exe and then make a call to::
UpdateLimitParams()
It is a one way street, as the aforementioned properties are not being updated from the device. I have not been able to think of a use case where you would need to read them back from the device(except a configuration util... is somebody is going to make a .net version of KMotion.exe?)
If you need to read values, you can use the BitNode class I included in that last update to extract the values from the console command's hex string.
-Brad
> Brad,
> Regards,
> Ray L.
> > -Brad
> > > Tom,
> > > Regards,
> > > Ray L.
> > > > Hi Ray,
> > > >  Axis:N
> > > > Regards
> > > > No answer on this??
> > > > > Regards,
> > > > > Ray L.
Group: DynoMotion Message: 5097 From: bradodarb Date: 5/29/2012
""" It doesn't appear to me that the
It gets updated every time you read the value(as a hex string as if you were in console).
-Brad
> LimitSwitchWatchNeg
> LimitSwitchBitNeg
> LimitSwitchWatchPos
> LimitSwitchBitPos
> LimitSwitchAction
> UpdateLimitParams()
> -Brad
> > Brad,
> > Regards,
> > Ray L.
> > > -Brad
> > > > Tom,
> > > > Regards,
> > > > Ray L.
> > > > > Hi Ray,
> > > > >  Axis:N
> > > > > Regards
> > > > > No answer on this??
> > > > > > Regards,
> > > > > > Ray L.
Group: DynoMotion Message: 5099 From: TK Date: 5/30/2012
Hi Ray,
You can use the Console Command
LimitSwitchN
To report back the current setting for axis N
On May 29, 2012, at 10:21 PM, "himykabibble" <jagboy@...> wrote:
Brad,
Ray L.
> -Brad
> > Tom,
> > Regards,
> > Ray L.
> > > Hi Ray,
> > >  Axis:N
> > > Regards
> > > No answer on this??
> > > > Regards,
> > > > Ray L.
Group: DynoMotion Message: 5100 From: Brad Murry Date: 5/30/2012
  FYI for anyone using .net and the KM_Axis class, KM_Axis.TuningParams.LimitSwitch does the same thing as that console command.
-Brad
From: DynoMotion@yahoogroups.com [mailto:DynoMotion@yahoogroups.com] On Behalf Of TK
Sent: Wednesday, May 30, 2012 12:33 AM
Subject: Re: [DynoMotion] Re: dotNet Question
Hi Ray,
LimitSwitchN
Brad,
Ray L.
> -Brad
> > Tom,
> > Regards,
> > Ray L.
> > > Hi Ray,
> > >  Axis:N
> > > Regards
> > > No answer on this??
> > > > Regards,
> > > > Ray L.
