Hi Bill,
I can't think of why they wouldn't move. Can you make some observations to see where the problem is? If you open KMotion.exe and look at the Axis Screen does it say your Axes are enabled? What modes are indicated? Do the Destinations Change. Are the SnapAmp fault lights off? Are the Motors holding?
Under KMotionCNC | Tool Setup | Tool Setup Files | Setup File you can specify a file with settings ti initialize the G Code Interpreter. You can edit the selected file or there should be already an example called Inches.set that you can select.
Message: 11326 |
Date: 4/8/2015 |
| Subject: Re: count units in kmotionCNC? |
opps again. I had InvDistPerCount left at 0.001 so my moves of 1" on XY were unnoticable.
