Hi Bengt,
The optos and relay drivers will be off without any +5V power. The +5V is the only power going to the board. It is used to create all the other supply voltages (1.8V, 2.5V, 3.3V, +15V, -15V).
If you want to be very safe you should use the SWE (Relay Switch Enable), which is derived from a charge pump that will only turn on if everything is powered up and KFlop is up and running and communicating with Kanalog.
Message: 475 |
Date: 6/25/2010 |
| Subject: Re: What if |
Ouch! Sorry to hear that.
