Hi Bengt,
Apparently the Install Shield version we use expects all open processes to respond to some request in a standard fashion and if not it hangs. It normally works on W7 64. Please try closing all other Apps and unnecessary Processes to see if that helps.
Message: 2720 |
Date: 12/16/2011 |
| Subject: Re: W7 64bit OS |
Sorry Tom,
Still not OK, Install did take very very looooooooooong time to pass and now KFlop is 'Unknown device'.
Something is very wrong with the install package, I have downloaded 2 times still same odd behaviour. I can open Kmotion but not USB Locations as the board is not activated in the system.
So what next?
Cheers
Bengt
> Hi Bengt,
> Sent: Friday, December 16, 2011 11:49 AM
> Subject: [DynoMotion] W7 64bit OS
> Hi Tom,
> I tried to install latest version on my office box with W7 64bit but I cannot get install to start up, yes I have tried to run as admin but still no go.
> Any advise?
> Cheers
> Bengt
Message: 2721 |
Date: 12/16/2011 |
I had the same issue and had to go to the device manager and install the "unknown device" manually. Just point the wizard to the kmotion install dir.
-Brad Murry
Bengt Sjoelund
Sent:
12/16/2011 2:33 PM
To:
Subject:
[DynoMotion] Re: W7 64bit OS
Sorry Tom,
So what next?
Cheers
Bengt
> Hi Bengt,
> Hi Tom,
> Any advise?
> Cheers
> Bengt
Message: 2722 |
Date: 12/16/2011 |
Hi Bengt,
That doesn't sound like a problem with the install.
Are you running from USB power? If so can you try an external +5V supply? I've seen some cases when the USB +5V was very low and caused something like this.
Message: 2723 |
Date: 12/16/2011 |
USB power yes but I took the wrong output now that I have HighPower output it all works OK and my spare KFlop now runs latest firmware.
This 64-bit circus makes many heads spin around until we all find the path to prpoer working conditions.
After a long delay I am now getting back on track with my CombiMill, had to tear down the gearbox and get new parts mostly bearings and it all took so long time so I had time to do some paintwork also. Soon some update on my website.
Cheers from Sweden to all 'Kflopers'
Bengt
> Hi Bengt,
> Sent: Friday, December 16, 2011 1:33 PM
> Subject: [DynoMotion] Re: W7 64bit OS
> Sorry Tom,
> So what next?
> Cheers
> Bengt
> > Hi Bengt,
> > ÃÂ
> > Apparently the Install Shield version we use expects all open processes to respond to some request in a standard fashion and if not it hangs.ÃÂ It normally works on W7 64.ÃÂ Please try closing all other Apps and unnecessary Processes to see if that helps.
> > ÃÂ
> > ÃÂ
> > From: Bengt Sjoelund <cnc@>
> > ÃÂ
> > Hi Tom,
> > Any advise?
> > Cheers
> > Bengt
Message: 2724 |
Date: 12/16/2011 |
Ha!
good one Bengt
'Kflopers'
it's a fun sounding name
"Mach-er" always sounded so harsh
Carl
--- In DynoMotion@yahoogroups.com, "Bengt Sjoelund" <cnc@...> wrote:
> Hi Tom,
> Bengt
> > Hi Bengt,
> > Â
> > Â
> > Â
> > Â
> > Sorry Tom,
> > So what next?
> > Cheers
> > Bengt
> > > Hi Bengt,
> > > ÃÂ
> > > ÃÂ
> > > Regards
> > > ÃÂ
> > > ÃÂ
> > > Hi Tom,
> > > Any advise?
> > > Cheers
> > > Bengt
Message: 2725 |
Date: 12/17/2011 |
Hi Carl,
Then it is best I put both Copyright and Tm on that one :)
Cheers
Bengt
--- In DynoMotion@yahoogroups.com, "carlcnc" <cebcnc@...> wrote:
> Ha!
> good one Bengt
> 'Kflopers'
> Carl
