Hi Kevin,
Right again. In GCodeInterpreter.dll file driver.cpp
this
int index = settings->origin_index; Vars[5221+index*20] = settings->origin_offset_x; Vars[5222+index*20] = settings->origin_offset_y; Vars[5223+index*20] = settings->origin_offset_z; Vars[5224+index*20] = settings->AA_origin_offset; Vars[5225+index*20] = settings->BB_origin_offset; Vars[5226+index*20] = settings->CC_origin_offset;
should be
int index = settings->origin_index; Vars[5201+index*20] = settings->origin_offset_x; Vars[5202+index*20] = settings->origin_offset_y; Vars[5203+index*20] = settings->origin_offset_z; Vars[5204+index*20] = settings->AA_origin_offset; Vars[5205+index*20] = settings->BB_origin_offset; Vars[5206+index*20] = settings->CC_origin_offset;
I have also attached the changed file.
Message: 7172 |
Date: 4/2/2013 |
| Subject: Re: V4.31b Fixture offset table not saved right |
That fixed the offset table for G54 to G59.9, but the global G92 offset is not being saved. Is this intentional or should that be saved also?
Kevin
> Hi Kevin,
> this
> Â Â Â int index = settings->origin_index;
> Â Â Â Vars[5221+index*20] = settings->origin_offset_x;
> Â Â Â Vars[5222+index*20] = settings->origin_offset_y;
> Â Â Â Vars[5223+index*20] = settings->origin_offset_z;
> Â Â Â Vars[5224+index*20] = settings->AA_origin_offset;
> Â Â Â Vars[5225+index*20] = settings->BB_origin_offset;
> Â Â Â Vars[5226+index*20] = settings->CC_origin_offset;
> should be
> Â Â Â Vars[5201+index*20] = settings->origin_offset_x;
> Â Â Â Vars[5202+index*20] = settings->origin_offset_y;
> Â Â Â Vars[5203+index*20] = settings->origin_offset_z;
> Â Â Â Vars[5204+index*20] = settings->AA_origin_offset;
> Â Â Â Vars[5205+index*20] = settings->BB_origin_offset;
> Â Â Â Vars[5206+index*20] = settings->CC_origin_offset;
> Sent: Tuesday, April 2, 2013 5:21 PM
> Subject: [DynoMotion] V4.31b Fixture offset table not saved right
> Seems like the Fixture offset table added in V4.31b is not being saved right. G54 and G55 seem to corrupted each others data.
Message: 7173 |
Date: 4/3/2013 |
Hi Kevin,
I think the code is working correctly but it is somewhat confusing.
The current Interpreter State (including offsets) can be saved to the Vars File. The Setup File allows you to force the initial state of things to specific values.
I think the default setup file - default.set - sets the xyz G92 offset to zero.
If you would rather the offsets to be saved rather than set to specific values then remove the settings from the Setup File.
Kevin
> Hi Kevin,
> this
> should be
Message: 7174 |
Date: 4/3/2013 |
Ok, after I remove the values from default.set it kinda works. I can save the values for G92 if I use the Zero or Set button next to the DRO but can not change the values in the table directly like I can for G54 to G59.9 (but I think it's fine the way it is now, maybe remove the clear button for G92 since it cannot be clear that way)
(you should also update the help...)
Kevin
> Hi Kevin,
> > Tom,
> > Thanks,
> > Kevin
> > --- In DynoMotion@yahoogroups.com, Tom Kerekes <tk@> wrote:
> > > Hi Kevin,
> > > this
> > > should be
> > > Regards
> > > From: fireup_kev <kliboon@>
Message: 7176 |
Date: 4/3/2013 |
Kevin,
Yes several bugs regarding applying/saving G92 offsets from the Edit Fixtures Screen. Here are two files with changes that should fix them.
Message: 7180 |
Date: 4/4/2013 |
So far so good with these updates. Can we make a V4.31c so I have an install version with all the latest changes?
> Kevin,
> Sent: Wednesday, April 3, 2013 6:28 AM
> Subject: [DynoMotion] Re: V4.31b Fixture offset table not saved right
> Thanks,
> Kevin
> --- In DynoMotion@yahoogroups.com, TK <tk@> wrote:
> > Hi Kevin,
> > On Apr 2, 2013, at 9:53 PM, "fireup_kev" <kliboon@> wrote:
> > > Tom,
> > > Thanks,
> > > Kevin
> > > > Hi Kevin,
> > > > this
> > > > should be
> > > > Regards
> > > > TK
Message: 7181 |
Date: 4/5/2013 |
I also added "KM_dotnet_Interop_GCodeInterpreter_SetVarsFile" and
"KM_dotnet_Interop_GCodeInterpreter_GetVarsFile" so I can set the "emc.var" to a different directory via .NET
> > Kevin,
> > Â
> > Thanks,
> > Kevin
> > > Hi Kevin,
> > > Regards
> > > > Tom,
> > > > Thanks,
> > > > Kevin
> > > > > Hi Kevin,
> > > > > this
> > > > > should be
> > > > > Regards
> > > > > TK
Message: 7182 |
Date: 4/5/2013 |
Hi Kevin, Can you send me the changed files? Thanks TK
Message: 7183 |
Date: 4/5/2013 |
I made a folder in the file section called V4.31c with 4 files that I changed.
> Hi Kevin,
> Thanks
> Sent: Friday, April 5, 2013 7:05 AM
> > > Kevin,
> > > Yes several bugs regarding applying/saving G92 offsets from the Edit Fixtures Screen.ÃÂ Here are two files with changes that should fix them.
> > > Regards
> > > ÃÂ
> > > Thanks,
> > > Kevin
> > > > Hi Kevin,
> > > > Regards
> > > > TK
> > > > > Tom,
> > > > > Thanks,
> > > > > Kevin
> > > > > > Hi Kevin,
> > > > > > this
> > > > > > should be
> > > > > > Regards
> > > > > > TK
Message: 7184 |
Date: 4/5/2013 |
Hi Kevin,
Thanks! Here is a New Version with the fixes for the KMotionCNC Edit Fixtures Screen.
http://www.dynomotion.com/Software/KMotion431c.exe
Message: 7248 |
Date: 4/13/2013 |
I try to use Set_VarsFile() but it was private, I had to add a public member access in KM_Interpreter.cs
/// <summary>
/// File path for the EMC Vars file
/// </summary>
public string VarsFile
get
return Get_VarsFile();
set
Set_VarsFile(value);
I update the file in the same folder V4.31c
> Hi Kevin,
> Sent: Friday, April 5, 2013 7:39 AM
> > Hi Kevin,
> > Thanks
> > ÃÂ
> > > > Kevin,
> > > > Yes several bugs regarding applying/saving G92 offsets from the Edit Fixtures Screen.ÃâàHere are two files with changes that should fix them.
> > > > Regards
> > > > TK
> > > > ÃâÃÂ
> > > > Thanks,
> > > > Kevin
> > > > > Hi Kevin,
> > > > > Regards
> > > > > TK
> > > > > > Tom,
> > > > > > Thanks,
> > > > > > Kevin
> > > > > > > Hi Kevin,
> > > > > > > this
> > > > > > > should be
> > > > > > > Regards
> > > > > > > TK
Message: 7249 |
Date: 4/13/2013 |
