Unfortunately between Versions the file format sometimes changes and the files can not just be copied over.
You can either just re-enter the parameters into
the screens, or open both files in a text editor and merge values from an old data file into the current data file.
Winmerge.org is a great tool for viewing and merging changes.
I believe the only file that changed was: GCodeConfigCNC.txt
Message: 6276 |
Date: 12/12/2012 |
| Subject: Re: Upgrade to 4.29 |
Thanks for the info. I will have a go at the merge.
> Hi,
> You can either just re-enter the parameters into the screens, or open both files in a text editor and merge values from an old data file into the current data file.
> HTH
> From: hartcomm2 <hartcomm2@...>
> Sent: Wednesday, December 12, 2012 3:54 PM
> Subject: [DynoMotion] Upgrade to 4.29
> Hi
> I just acquired a mill with a Kflop controller.
> I upgraded the software from 4.26 in steps and all was fine until I tried 4.29.
> The buttons on KmotionCNC are there but there is no link to the programs or bit controls. And the init program will not run from the button.
> I have moved the data folder but this just made the empty buttons show up.
> Any suggestions would be appreciated.
