Hi Tapio, Wrong syntax and SetBit only sets bit. To set a bit to a specified state call SetStateBit. Try: #include "KMotionDef.h" #define OPTOIN7 143 #define OPTOOUT1 145 #define OPTOOUT2 146 main() { for (;;) //loop forever { WaitNextTimeSlice(); SetStateBit(OPTOOUT1, !ReadBit(OPTOIN7)); SetStateBit(OPTOOUT2, !ReadBit(OPTOIN7)); } }
Message: 7302 |
Date: 4/20/2013 |
| Subject: Re: Understanding WatchEnable |
Hi!
Do I config the below watchenable code to run as separate thread?
I want it to run as soon as Kflop boots up, regardless if mach3 front-end is present or not.
the optoin monitors system control voltage and opto-outs control drive enable/run-inhibit that has control of the servomotor breaks.
Rgds
Tapio
> Hi Tapio,
> Try:
> #define OPTOIN7 143
> main()
> Â Â Â for (;;) //loop forever
> Â Â Â {
> Â Â Â Â Â Â WaitNextTimeSlice();
> Â Â Â Â Â Â SetStateBit(OPTOOUT1, !ReadBit(OPTOIN7));
> Â Â Â Â Â Â SetStateBit(OPTOOUT2, !ReadBit(OPTOIN7));
> Â Â Â }
> From: tapiolarikka <tapio.larikka@...>
> Sent: Friday, April 19, 2013 10:03 AM
> Subject: [DynoMotion] Understanding WatchEnable
> Hi All!
> I wanted to confirm if I have figured this correctly:
> I want KFlop to monitor OptoIn7 and keep OptoOut1&2 the opposite of OptoIn7 at all times.
> I understood that I could do this following WatchEnable example with
> main()
> SetBit(xxx)=!Readbit(xxx) // OptoOut1<>OptoIn7;
> SetBit(xxx)=!Readbit(xxx) // OptoOut2<>OptoIn7;
> And launching this in separate thread
> If the above is wrong please point out my error
> Rgds,
> Tapio
Message: 7303 |
Date: 4/20/2013 |
Hi Tapio,
You can download it to an unused Thread, set the thread to Launch on startup, then FLASH User Data. But it isn't recommended. It seems like something better handled in hardware. KFLOP takes a few seconds to boot up. FLASHing User Data can be confusing. You will need to keep track of if/what is flashed in each board in case you ever want to upgrade versions or replace a board. It is easier if everything is always just initialized from scratch by the PC (Mach3).
Regards. TK
Hi!
Rgds
Tapio
> Hi Tapio,
> Try:
> #define OPTOIN7 143
> main()
> Hi All!
> main()
> Rgds,
> Tapio
Message: 7304 |
Date: 4/20/2013 |
So the recommended way is to have 1 init.c and things that should loop forever should be place at the end of this file?.
I suppose KFlop runs with the loaded init it has until new init is loaded?
Meaning that I have Mach plugin set so that Kflop is initialized on every reset. If I hit limit or something else triggeres mach reset/e-stop then KFlop runs the time from hitting the limit to pressing reset with the init loaded at previous reset.
Rgds,
Tapio
> Hi Tapio,
> Regards.
> On Apr 20, 2013, at 5:20 AM, "tapiolarikka" <tapio.larikka@...> wrote:
> > Hi!
> > Rgds
> > Tapio
> > --- In DynoMotion@yahoogroups.com, Tom Kerekes <tk@> wrote:
> > > Hi Tapio,
> > > Try:
> > > #define OPTOIN7 143
> > > main()
> > > From: tapiolarikka <tapio.larikka@>
> > > Hi All!
> > > main()
> > > Rgds,
> > > Tapio
Message: 7310 |
Date: 4/21/2013 |
Hi Tapio,
That is correct (if I understand your description).
