As I’ve built several 3D printers, I’ll chip in.
You’ll need a few specific things.
Fourth Axis to control the stepper that will drive the extruder
Extruder – the mechanism that feeds filament at a specific rate to the hotend. Search thingiverse.com for ‘extruder’ to get a good idea of what’s
going on
Hotend, this is the item that filament is fed through which melts at the end. The gold standard is here:
http://hotends.com/.
Temperature control – this is usually built into the electronics for any reprap (Arduino mega 2650 + Ramps 1.4 being pretty popular), but those electronics
also drive the steppers. So, you’ll probably want to go with a simple analog/manual PID temperature control device.
Software – to take the 3D file (.stl usually) and slice it up into g-code. I use Slic3r from
http://slic3r.org/.
http://forums.reprap.org/ is a good place to ask questions.
Luck!
Jeremy
Message: 9881 |
Date: 7/29/2014 |
| Subject: Re: Turning CNC router into 3D printer |
Thanks for the tips on turning a router into a 3D printer. I appreciate the info. It will be a while before I can get started on this project. At least I got some good starting points.
