Hi Brad,
I don't know what you are doing looks correct to me. I'd have to debug it.
You do have a G43 with the Hxx correct?
Also as you are cutting the DRO should not be any different but the tool position and machine parameters should be different.
You might check if the #Vars are actually changing. I guess there is no way to print them but you might move an axis to them as a test ie:
G0 A#5200
Message: 2449 |
Date: 11/26/2011 |
| Subject: Re: Tool Offsets |
Hello Tom,
I am calling the G54 H12 in my program, what I was describing before was the method I am using to populate the tool table and offset parameters since I am bypassing the config files(EMC.var, etc...) and defining everything through my own XML files.
I am fairly confident that the values are being set correctly, and both the standalone interpreter as well as the canonical calls seem straight forward and should be working properly. I must be referencing a rouge instance of the setupparams or found something
else wrong. I'll debug it later and hopefully get to the bottom of it quickly. These are the last issues before MM is serviceable.
-Brad Murry
Sent:
11/26/2011 1:14 PM
To:
DynoMotion@yahoogroups.com
Subject:
Re: [DynoMotion] Tool Offsets
Hi Brad,
G0 A#5200
Sent: Saturday, November 26, 2011 9:07 AM
Subject: [DynoMotion] Tool Offsets
Hello Tom,
I belive this is again more of an EMC related question, but I am really close to having MM ready for Carl and any other brave beta testers and hope you can shed some light.
___________Tool Offset Issue______________________
I have implemented methods to define tools in the p_setup.tool_table
GC_dll->p_setup->tool_table[id].length = length;
GC_dll->p_setup->tool_table[id].diameter = diameter;
I also created a method for geting a value by index to verify the settings are correct and 'sticking'.
So if I use an index of 12, that should be addressable via T12/H12/D12 right?
It appears something else needs to be set other than the tool table, but I am not sure what because it is not changing the DRO position while cutting.
However, I can affect the DRO by issuing a python command while interpreting that calls this:
_Controller.Interpreter.SetupParams.ToolLengthOffset = 500
which immediately offsets my Z axis DRO by 500 units.
___________Origin Issue______________________
I also added
int CGCodeInterpreter::SetOrigin(int index, double x, double y, double z)
double* pars = p_setup->parameters;
int k = (5200 + (index * 20));
pars[k + 1] = x;
pars[k + 2] = y;
pars[k + 3] = z;
return 0;
and
int CGCodeInterpreter::GetOrigin(int index, double *x, double *y, double *z)
*x = pars[k + 1];
*y = pars[k + 2];
*z = pars[k + 3];
return 0;
to GCodeInterpreter.
Using and index of 1, and setting values
x = 1000;
y = 1000;
z = 1000;
When I call a G54 in my gcode file my DRO values should be offset by 1000 right?
This is not happening, and I am not sure why.
Any thoughts?
Thank you
-Brad Murry
Message: 2450 |
Date: 11/26/2011 |
Hi Brad,
You may be right but I think you need a G43 H12 to turn on length compensation. The H alone won't do it. Otherwise I think the interpreter should give an error.
Message: 2451 |
Date: 11/26/2011 |
I am using both for sure.....sorry to be unclear earlier. I must be missing something else.
-Brad Murry
Sent:
11/26/2011 4:37 PM
To:
Subject:
Hi Brad,
Sent: Saturday, November 26, 2011 3:31 PM
Subject: RE: [DynoMotion] Tool Offsets
Hello Tom,
-Brad Murry
Sent:
11/26/2011 1:14 PM
To:
Subject:
Hi Brad,
G0 A#5200
Hello Tom,
I also added
pars[k + 1] = x;
pars[k + 2] = y;
pars[k + 3] = z;
return 0;
and
*x = pars[k + 1];
*y = pars[k + 2];
*z = pars[k + 3];
return 0;
x = 1000;
y = 1000;
z = 1000;
Any thoughts?
Thank you
-Brad Murry
Message: 2458 |
Date: 11/28/2011 |
Have you tried stting the tool table manually in KMotion?
I set the toolfile name to"" and accessed the tool table array index
as I did from MM with the same results
-Brad
> Hi Brad,
> G0 A#5200
> Hello Tom,
> I also added
> pars[k + 1] = x;
> pars[k + 2] = y;
> pars[k + 3] = z;
> return 0;
> and
> *x = pars[k + 1];
> *y = pars[k + 2];
> *z = pars[k + 3];
> return 0;
> x = 1000;
> y = 1000;
> z = 1000;
> Any thoughts?
> Thank you
> -Brad Murry
Message: 2460 |
Date: 11/28/2011 |
Hi Brad
I'm not sure exactly what you mean.
But here is what I tried:
Set the Tool Table name to "" otherwise it will reload the tool table from disk every time the Interpreter starts executing.
I then set a breakpoint in KMotionCNC and used the debugger to set:
TheFrame->GCodeDlg.Interpreter.p_setup->tool_table[3].length 1.1230000000000000 double
I then ran GCode of
G43 H3 (Tool #3 length comp On)
I observe the Z DRO change by 1.123
Message: 2461 |
Date: 11/28/2011 |
Thanks Tom, Did you set the tool value before or after interpreter cycle start? -Brad Murry From: DynoMotion@yahoogroups.com [mailto:DynoMotion@yahoogroups.com] On Behalf Of Tom Kerekes Sent: Monday, November 28, 2011 5:08 PM To: DynoMotion@yahoogroups.com Subject: Re: [DynoMotion] Re: Tool Offsets I'm not sure exactly what you mean. But here is what I tried: Set the Tool Table name to "" otherwise it will reload the tool table from disk every time the Interpreter starts executing. I then set a breakpoint in KMotionCNC and used the debugger to set: TheFrame->GCodeDlg.Interpreter.p_setup->tool_table[3].length 1.1230000000000000 double G43 H3 (Tool #3 length comp On) I observe the Z DRO change by 1.123 From: bradodarb <bradodarb@...> To: DynoMotion@yahoogroups.com Sent: Monday, November 28, 2011 11:09 AM Subject: [DynoMotion] Re: Tool Offsets Have you tried stting the tool table manually in KMotion?
I set the toolfile name to"" and accessed the tool table array index as I did from MM with the same results
-Brad
--- In DynoMotion@yahoogroups.com, Tom Kerekes <tk@...> wrote: > > Hi Brad, >  > I don't know what you are doing looks correct to me. I'd have to debug it. >  > You do have a G43 with the Hxx correct? >  > Also as you are cutting the DRO should not be any different but the tool position and machine parameters should be different. >  > You might check if the #Vars are actually changing. I guess there is no way to print them but you might move an axis to them as a test ie: >  > G0 A#5200 >  > Regards > TK >  >  > > From: bradodarb <bradodarb@...> > To: DynoMotion@yahoogroups.com > Sent: Saturday, November 26, 2011 9:07 AM > Subject: [DynoMotion] Tool Offsets > > >  > Hello Tom, > > I belive this is again more of an EMC related question, but I am really close to having MM ready for Carl and any other brave beta testers and hope you can shed some light. > > ___________Tool Offset Issue______________________ > > I have implemented methods to define tools in the p_setup.tool_table > > GC_dll->p_setup->tool_table[id].length = length; > GC_dll->p_setup->tool_table[id].diameter = diameter; > > I also created a method for geting a value by index to verify the settings are correct and 'sticking'. > > So if I use an index of 12, that should be addressable via T12/H12/D12 right? > > It appears something else needs to be set other than the tool table, but I am not sure what because it is not changing the DRO position while cutting. > > However, I can affect the DRO by issuing a python command while interpreting that calls this: > > _Controller.Interpreter.SetupParams.ToolLengthOffset = 500 > > which immediately offsets my Z axis DRO by 500 units. > > ___________Origin Issue______________________ > > I also added > > int CGCodeInterpreter::SetOrigin(int index, double x, double y, double z) > { > double* pars = p_setup->parameters; > > int k = (5200 + (index * 20)); > > pars[k + 1] = x; > pars[k + 2] = y; > pars[k + 3] = z; > > return 0; > } > and > > int CGCodeInterpreter::GetOrigin(int index, double *x, double *y, double *z) > { > double* pars = p_setup->parameters; > > int k = (5200 + (index * 20)); > > *x = pars[k + 1]; > *y = pars[k + 2]; > *z = pars[k + 3]; > > return 0; > } > > to GCodeInterpreter. > > Using and index of 1, and setting values > > x = 1000; > y = 1000; > z = 1000; > > When I call a G54 in my gcode file my DRO values should be offset by 1000 right? > > This is not happening, and I am not sure why. > > Any thoughts? > > Thank you > -Brad Murry >
Message: 2462 |
Date: 11/28/2011 |
Before. I set a breakpoint in my edit table button (which thows an error because no file specified). Changed the value with the debugger in VS. Hit "Run" in VS. Hit "Single Step" in KMotionCNC.
Message: 2463 |
Date: 11/28/2011 |
Hello Tom,
I had a Z word on the same line which the EMC apparently does not like. After moving the Z word to the next line, the machine coordinates changed accordingly.
I do however have some wierdness on the .net side...
If I set the tool table prior to calling Interpreter.Interpret the tool table(and likely the parameter file) seems to be reset.
I can get it to take effect if I set the tool length after calling Interpret(args...) - But ONLY if I call a Thread.Sleep(>0)!
So even 1 ms seems to make it 'stick', which makes me think the tool table is being read.
In the initialization of the CGcodeInterpreter in dot_netInterop.dll (new)
I tried
... GC = new CGCodeInterpreter;
1)
leaving the ToolFile and SetupFile alone.
2)
strcpy(GC->ToolFile,"");
strcpy(GC->SetupFile,"");
and
3)
GC_dll->ToolFile[0]=0;
GC_dll->SetupFile[0]=0;
And all yeild the same results.
Very strange, but I think I am getting closer to the problem.
Any Ideas?
-Brad Murry
> From: Brad Murry <bradodarb@...>
> Sent: Monday, November 28, 2011 4:28 PM
> Subject: RE: [DynoMotion] Re: Tool Offsets
> Thanks Tom,
> -Brad Murry
> From:DynoMotion@yahoogroups.com [mailto:DynoMotion@yahoogroups.com] On Behalf Of Tom Kerekes
> Hi Brad
> I then ran GCode of
> From:bradodarb <bradodarb@...>
> -Brad
> > Hi Brad,
> > ÃÂ
> > I don't know what you are doing looks correct to me.ÃÂ I'd have to debug it.
> > ÃÂ
> > ÃÂ
> > ÃÂ
> > You might check if the #Vars are actually changing.ÃÂ I guess there is no way to print them but you might move an axis to them as a test ie:
> > ÃÂ
> > G0 A#5200
> > ÃÂ
> > ÃÂ
> > ÃÂ
> > ÃÂ
> > Hello Tom,
> > I also added
> > pars[k + 1] = x;
> > pars[k + 2] = y;
> > pars[k + 3] = z;
> > return 0;
> > and
> > *x = pars[k + 1];
> > *y = pars[k + 2];
> > *z = pars[k + 3];
> > return 0;
> > x = 1000;
> > y = 1000;
> > z = 1000;
> > Any thoughts?
> > Thank you
> > -Brad Murry
Message: 2464 |
Date: 11/28/2011 |
I think it is getting reset here::
CGCodeInterpreter::InitializeInterp()
|__\
rs274ngc_init()
|__\
rs274ngc_synch();
|__\
/ rs274ngc_load_tool_table();
And here is where we are getting reset::
int rs274ngc_load_tool_table()
{ /* NO ARGUMENTS */
static char name[] = "rs274ngc_load_tool_table";
int n;
CHK((_setup.tool_max > CANON_TOOL_MAX), NCE_TOOL_MAX_TOO_LARGE);
for (n = 0; n <= _setup.tool_max; n++) {
_setup.tool_table[n] = GET_EXTERNAL_TOOL_TABLE(n);
for (; n <= CANON_TOOL_MAX; n++) {
_setup.tool_table[n].id = 0;
_setup.tool_table[n].length = 0;
_setup.tool_table[n].diameter = 0;
return RS274NGC_OK;
I think if I call InitializeInterp() when the CGcodeInterpreter is created, always set m_restart on the Interpret call to false and set m_InitializeOnExecute to false it should work.
-Brad Murry
> Hello Tom,
> I tried
> 1)
> 2)
> and
> 3)
> Any Ideas?
> -Brad Murry
> > Â
> > From: Brad Murry <bradodarb@>
> > Â
> > Thanks Tom,
> > Â
> > Â
> > -Brad Murry
> > Â
> > Â
> > Â
> > Hi Brad
> > Â
> > Â
> > Â
> > Â
> > Â
> > I then ran GCode of
> > Â
> > Â
> > Â
> > Â
> > From:bradodarb <bradodarb@>
> > Â
> > -Brad
> > > Hi Brad,
> > > ÃÂ
> > > ÃÂ
> > > ÃÂ
> > > ÃÂ
> > > ÃÂ
> > > G0 A#5200
> > > ÃÂ
> > > Regards
> > > ÃÂ
> > > ÃÂ
> > > ÃÂ
> > > Hello Tom,
> > > I also added
> > > pars[k + 1] = x;
> > > pars[k + 2] = y;
> > > pars[k + 3] = z;
> > > return 0;
> > > and
> > > *x = pars[k + 1];
> > > *y = pars[k + 2];
> > > *z = pars[k + 3];
> > > return 0;
> > > x = 1000;
> > > y = 1000;
> > > z = 1000;
> > > Any thoughts?
> > > Thank you
> > > -Brad Murry
> > Â
Message: 2465 |
Date: 11/28/2011 |
Yep, adding members for InitializeOnExecute and InitializeInterp()
allows me to init from a file if I want and suppress it on subsequent Interpret() calls.
It should now be able to work as normal using the typical files or have the setup and tool table params defined externally.
-Brad
> |__\
> rs274ngc_init()
> |__\
> rs274ngc_synch();
> |__\
> int n;
> return RS274NGC_OK;
> -Brad Murry
> > Hello Tom,
> > I tried
> > 1)
> > 2)
> > and
> > 3)
> > Any Ideas?
> > -Brad Murry
> > > Â
> > > Â
> > > Thanks Tom,
> > > Â
> > > Â
> > > -Brad Murry
> > > Â
> > > Â
> > > Â
> > > Hi Brad
> > > Â
> > > Â
> > > Â
> > > Â
> > > Â
> > > I then ran GCode of
> > > Â
> > > Â
> > > Â
> > > Regards
> > > Â
> > > Â
> > > -Brad
> > > > Hi Brad,
> > > > ÃÂ
> > > > ÃÂ
> > > > ÃÂ
> > > > ÃÂ
> > > > ÃÂ
> > > > G0 A#5200
> > > > ÃÂ
> > > > Regards
> > > > TK
> > > > ÃÂ
> > > > ÃÂ
> > > > ÃÂ
> > > > Hello Tom,
> > > > I also added
> > > > pars[k + 1] = x;
> > > > pars[k + 2] = y;
> > > > pars[k + 3] = z;
> > > > return 0;
> > > > and
> > > > *x = pars[k + 1];
> > > > *y = pars[k + 2];
> > > > *z = pars[k + 3];
> > > > return 0;
> > > > x = 1000;
> > > > y = 1000;
> > > > z = 1000;
> > > > Any thoughts?
> > > > Thank you
> > > > -Brad Murry
> > > Â
Message: 2470 |
Date: 11/29/2011 |
Hi Brad,
Yes I didn't think and was single stepping from the middle of a GCode program which is different from starting at line 1.
I remember that at one point I tried initializing in the constructor but that didn't work well because the various files the app reads on startup weren't initialized.
This process probably needs to be reviewed but so far no one has complained :}
