Currently all is going well with the Studer grinder conversion.
My friend would now like to add an encoder to the servo that is used as the spindle....making it into a c axis.
The grinder is basically like a lathe except there is a grinding wheel where the tool post would be.
The need for the c axis is so that he can grind threads on this machine.
Unlike a lathe.....threads are ground by first plunging the formed wheel into the stock, then rotating the c axis in coordination with the x for the proper pitch at maybe 2 rpm.....then stopping after a set number of rotations and retracting the x. The c and x would reposition back to where they started, and the process would repeat until the necessary depth is achieved. The thread grind process begins and ends with the c axis stopped.
Does this sound reasonable to you?
It seems as though it is actually simpler than a lathe since its not syncing up at speed.
I wonder how the c would be commanded to turn more than 1 rotation since it would be an angular axis, though.
Mike
