Group: DynoMotion Message: 10206 From: eric_kato_sanders Date: 9/25/2014
Subject: Suggested improvement to KMotionCNC
Several times in the past I've had mechanical issues, (broken cutters, etc..) that caused me to want to start a multi operation GCode somewhere in the middle.  I would typically edit the file, then re-save as a delme.nc or such.  I never made use of the Block Delete option because it was too cumbersome to add all of the '/' tags at the start of the line.
What I added was code to toggle the line '/' prefix of all selected lines.  I added the appropriate code to include the option in the pop up context menu as well.  I know that the "Set Next Statement" option could be used, but it doesn't usually work if you are trying to skip over several arc commands.
ERic
void CRichEditCtrlEx::OnToggleBlock()
   CString s = GetSelText();
   if (s.GetLength() == 0)
      AfxMessageBox("Nothing Selected to Toggle");
   int oldStart = 0;
   int newLine  = -1;
   while((newLine = s.Find("\n", newLine+1)) != -1)
      if(s.GetAt(oldStart) == '/')
         s.Delete(oldStart,1);
         s.Insert(oldStart==0?oldStart:oldStart+1, '/');
         newLine++;
      oldStart = newLine;
   ReplaceSel(s);
Group: DynoMotion Message: 10213 From: Tom Kerekes Date: 9/26/2014
Subject: Re: Suggested improvement to KMotionCNC
Hi Eric,
Thanks.  This was merged into the code after fixing one bug.  We ended up with:
Does this work for you?
    int oldStart = 0;
    int newLine  = -1;
            newLine--;
            s.Insert(oldStart, '/');
            newLine++;
        oldStart = newLine+1;
    ReplaceSel(s);
From: "eric@... [DynoMotion]" <DynoMotion@yahoogroups.com>
Sent: Thursday, September 25, 2014 9:23 AM
Subject: [DynoMotion] Suggested improvement to KMotionCNC
ERic
   int oldStart = 0;
   int newLine  = -1;
         newLine++;
      oldStart = newLine;
   ReplaceSel(s);
Group: DynoMotion Message: 10223 From: eric_kato_sanders Date: 9/27/2014
Yep, your code works fine.  I'm curious, what was the bug you found in what I had listed?  In testing, what I had seemed to work as well but it's easy to miss something.
Eric
Group: DynoMotion Message: 10224 From: TK Date: 9/28/2014
Hi Eric,
It worked ok for me when all the lines selected were the the same - with or without block delete. But when selecting mixed lines it did weird things like not remove a slash or put a slash in after the G.
On Sep 27, 2014, at 8:37 PM, eric@... [DynoMotion] <DynoMotion@yahoogroups.com> wrote:
Eric
