Hi Brad,
The OutputChan0 setting on the Config Screen is not selecting pins or bits. Rather it is selecting which Step/Dir hardware generator to be used which in turn is associated with specific Pins. Maybe this will help:
But Yes - OutputChan0=4 will drive Output bits 36 and 37 in open collector mode.
More info here:
Message: 4960 |
Date: 5/16/2012 |
| Subject: Re: Step and Dir on JP5 |
Hello Tom,
Thanks that diagram is excellent, sorry for not taking a better look.
On power up now the kflop thinks every axis is encoder and my position counters go crazy.
Thats not a real big deal as nothing is actually hooked up to them.
I am having an issue where once I enable the axis channel 0 I can no longer manipulate the bits 36 and 37 in the digital IO screen.
thoughts...?
Brad Murry
> Hi Brad,
> http://www.dynomotion.com/Help/SchematicsKFLOP/KFLOPFunctionalDiagram.htm
> More info here:
> http://www.dynomotion.com/Help/StepAndDirection/StepAndDir.htm
> Sent: Wednesday, May 16, 2012 11:04 AM
> Subject: [DynoMotion] Re: Step and Dir on JP5
> Hello Bengt,
> Yep, I do want to use axis channel 0, but not sure about the output channels.
> For example, I had to use output channels 8,9 and 10 on my personal machine because the drives I am using are expecting an LVTTL signal.
> Using those channels translated to pins 15-20 on JP7.
> I guess I am not clear how the input/output bits on the config screen relate to physical pins on various connectors.
> Thanks,
> Brad Murry
> --- In DynoMotion@yahoogroups.com, "Bengt Sjoelund" <cnc@> wrote:
> > Hi Brad,
> > Isnt it 0 - 1 - 2 - 3?
> > Hope this works now with Yahoo as I have had a lot of problems for the last 24h
> > Cheers
> > Bengt
> > --- In DynoMotion@yahoogroups.com, "bradodarb" <bradodarb@> wrote:
> > > Hello Tom,
> > > We want to use pin 36 and 37 for step dir. The docs say that is axis 4.
> > > So in config and setup do I set output channel 4?
> > > Thanks,
> > > Brad Murry
Message: 4961 |
Date: 5/16/2012 |
Hello Tom,
Looks like there was another axis channel that was using generator 4.
Reconfigured other channels and works well.
Brad Murry
> Hello Tom,
> thoughts...?
> Thanks,
> Brad Murry
> > Hi Brad,
> > Â
> > Â
> > Â
> > Â
> > More info here:
> > Â
> > Â
> > Â
> > Â
> > Â
> > Hello Bengt,
> > Thanks,
> > Brad Murry
> > > Hi Brad,
> > > Cheers
> > > Bengt
> > > > Hello Tom,
> > > > Thanks,
> > > > Brad Murry
