Hi Gordon,
If you configure the Mach3 Dynomotion Plugin Parameters for the Spindle then the actual speed should show up in the Mach3 Screens. You shouldn't need a C program for that. Just some KFLOP Axis configured for Encoder 3 as input.
Do you plan on controlling the speed (and Gears?) from Mach3+KFLOP? if so what is the interface?
Message: 6402 |
Date: 1/9/2013 |
| Subject: Re: Spindle Encoder Lathe Threading |
I'm using Custom macros in mach3/kflop outputs to activate the clutches example:M800 will active the sequence off relays to setup the clutches to = 800 rpm.M5 will swith all relays off and including spindle.It was the most simple way of doing gear change that i could come up with,Not much of a computer programmer just an old fashion fitter and turner hacking my way thru.
Regards Gordon
> Hi Gordon,
> If you configure the Mach3 Dynomotion Plugin Parameters for the Spindle then the actual speed should show up in the Mach3 Screens. Â You shouldn't need a C program for that. Â Just some KFLOP Axis configured for Encoder 3 as input.
> Do you plan on controlling the speed (and Gears?) from Mach3+KFLOP? Â if so what is the interface?
> From: "gordonphoenix@..."
> Sent: Wednesday, January 9, 2013 6:19 PM
> Subject: [DynoMotion] Spindle Encoder Lathe Threading
> Hi Tom,
> The Mori Seiki conversion is nearly complete,
> Z and X axis are working just fine,tool changer even better.
> But i have hit a brick wall with setting up the Spindle encoder with mach3 for thread cutting on the lathe.My spindle setup is an 8 speed magnetic clutch gearbox with Heidenhein Rotory encoder 500 count connected to the main spindle.
> I have conected the encoder to channel 3 and getting to count +,-.
> How would i set it a c pro to communicate with mach.
> Gordon
Message: 6404 |
Date: 1/9/2013 |
Hi Gordon,
So you don't have or need any speed control other than switching gears for selectable fixed speeds?
Are you saying that the M Codes are all working
correctly?
The next step would be to get the Current measured speed showing up properly in Mach3.
Message: 6405 |
Date: 1/9/2013 |
Yes that's what im after,I need to sync the encoder thru Kflop to mach
The ratio is 4:1 per rev so 1 rev=4000 counts on encoder.
How would go about sync the two.
P.S The M codes work fine as long as i inc M5 before gear change on next tool, It would be a mess if the clutches were engaged at the same time.
Gordon
> Hi Gordon,
> Are you saying that the M Codes are all working correctly?
> Sent: Wednesday, January 9, 2013 7:01 PM
> Subject: [DynoMotion] Re: Spindle Encoder Lathe Threading
> Hi Tom,
> Regards Gordon
> > Hi Gordon,
> > If you configure the Mach3 Dynomotion Plugin Parameters for the Spindle then the actual speed should show up in the Mach3 Screens. ÃÂ You shouldn't need a C program for that. ÃÂ Just some KFLOP Axis configured for Encoder 3 as input.
> > Do you plan on controlling the speed (and Gears?) from Mach3+KFLOP? ÃÂ if so what is the interface?
> > From: "gordonphoenix@"
> > ÃÂ
> > Hi Tom,
> > Gordon
