Hi Scott,
Sorry to hear this. Yes you can apply two different Voltages to different sides of SnapAmp. They do have a common GND.
I don't know what you mean by "center tap off the same transformer".
Which supply was damage?
What voltage was the SnapAmp Supply Voltage clamping set at?
Message: 11845 |
Date: 7/1/2015 |
| Subject: Re: SnapAMP Power |
I see my mistake. I am using a PSU that has a secondary coil with a center tap, 80V between the outer legs, and 40 between the center tap and either of the outer. I didnt realize there was a common ground, and wired it in such a way to short.
