Hi Jing,
Sorry that was a design choice on KSTEP in order to reduce the number of I/O required there is just one enable. Normally a system must be designed so that if a motor is used continuously it will not overheat anyway. You may need to reduce the current settings for your motors or add more heat sinking for them.
Message: 7265 |
Date: 4/15/2013 |
| Subject: Re: Separate Enabling of Motors |
Hi, Tom,
For the current setting, could you give me some example as how to reduce the current settings? I have already limited the current to the minimum value with current setting jumpers.
Best
Jing
Message: 7266 |
Date: 4/15/2013 |
Hi Jing, If you have removed all the jumpers that is the lowest setting. Your motors must be very small. What are their specs?
Message: 7267 |
Date: 4/15/2013 |
Hi, Tom,
Yes, the motors are small. The motors I use are EAD LH1715-12. The phase voltage is 12 volts, and the phase current is 0.4 A, the phase resistance is 30 ohms.
Best
Jing
Message: 7268 |
Date: 4/15/2013 |
Hi Jing,
The current rating is too small for KSTEP. If you chose a lower voltage motor winding option like the LH1715-M100 (1 Amp 4.7 ohms) it would work and you would get much higher speed and torque.
Message: 7270 |
Date: 4/15/2013 |
Hi, Tom,
That is true. I have the other motors already. Is there anything I can do with the small motors?
Best Jing
Message: 7272 |
Date: 4/15/2013 |
Hi Jing, Not really without going to different stepper drives. Regards TK
Message: 7273 |
Date: 4/15/2013 |
Thanks. Is there anyway I can do PWM to reduce the current in those spare motors? best Jing
Message: 7274 |
Date: 4/15/2013 |
Hi Jing,
Not really. To be honest we made a mistake when we designed KSTEP and used an opto coupler that was too slow for the Enable (and the Enable/Disable times are asymmetric). So the PWM frequency must be very low (<1KHz) which will result in an annoying sound and not work while moving.
I suppose you could add a dummy shunt inductive load to divert some of the current.
You should be able to replace these small motors very inexpensively. Here is a much better motor for $20:
http://www.kelinginc.net/NEMA17Motor.html
Message: 7275 |
Date: 4/15/2013 |
Hi, Tom,
Thanks a lot for your suggestion. Best
Jing
Message: 7276 |
Date: 4/15/2013 |
Kelings new website has a little better price, if that helps.
http://www.automationtechnologiesinc.com/products-page/nema-17
Troy
> From: Jing Zhang <jing_usc@...>
> Sent: Monday, April 15, 2013 4:41 PM
> Subject: Re: [DynoMotion] Separate Enabling of Motors
> Hi Tom,
> Thanks.
> best
> Jing
> From: Tom Kerekes <tk@...>
> Sent: Monday, April 15, 2013 4:36 PM
> Hi Jing,
> Sent: Monday, April 15, 2013 4:23 PM
> Hi, Tom,
> Best
> Jing
> Sent: Monday, April 15, 2013 3:48 PM
> Hi Jing,
> Sent: Monday, April 15, 2013 3:12 PM
> Hi, Tom,
> Best
> Jing
> Sent: Monday, April 15, 2013 3:06 PM
> Hi Jing,
> If you have removed all the jumpers that is the lowest setting. Your motors must be very small. What are their specs?Â
> Sent: Monday, April 15, 2013 2:44 PM
> Hi, Tom,
> Best
> Jing
> Sent: Monday, April 15, 2013 11:59 AM
> Hi Jing,
> Sent: Monday, April 15, 2013 11:20 AM
> Subject: [DynoMotion] Separate Enabling of Motors
> Hi, Tom,
> I am using a combination of KFlop+KStep, and I find that once one motor is enabled to work, the other three motors have voltage on.Â
> If I use one motor for a longer time, the other three motors have the trouble of overheating. How could I just enable the motor which needs to work?
> Best
> Jing
