Group: DynoMotion Message: 15363 From: geast1967 Date: 2/12/2018
Subject: Reverse external button.
I try to install four external buttons to use them as ,Cycle Start, Feedhold, Stop end Reverse movement, in a feedhold state. By looking the c example "external buttons.c" everything i need is there, except for the reverse movement function. Does anybody know, how can i implement that?
Group: DynoMotion Message: 15364 From: kn6za Date: 2/12/2018
Subject: Re: Reverse external button.
I think you can do a negative value in the FRO variable with:
DoPCFloat(PC_COMM_SET_FRO,FRO);
machine will move backwards along the path. There may be other methods as well.
   Andrew
Group: DynoMotion Message: 15365 From: geast1967 Date: 2/12/2018
Thank a lot for the reply.
I will test it tomorrow and let you know.
Group: DynoMotion Message: 15366 From: TKSOFT Date: 2/12/2018
Actually I think KMotionCNC will ignore negative FRO values.
You should be able to command KFLOP directly to reverse feed with this
call:
void SetFROTemp(float FRO); // Temporarily change from current to the
specified FRO using a nominal rate, override FeedHold, don't save as
LastFRO
> as well.
LastFRO
Group: DynoMotion Message: 15367 From: geast1967 Date: 2/12/2018
Thank alot Tom. This should do the job.
I try it and let you know.
Group: DynoMotion Message: 15368 From: kn6za Date: 2/12/2018
Sorry for the bad intel guys.
   Andrew
Group: DynoMotion Message: 15369 From: Tom Kerekes Date: 2/12/2018
No worries.  Thank you for taking the time for a suggestion to try.
   Andrew
Group: DynoMotion Message: 15378 From: geast1967 Date: 2/13/2018
I test it today and worked fine.
Thank you Tom, again for your great support.
