Hi Ray,
I think we discussed this before when you had the Mach3 arrow key runaway. But the standard software MPG method has a technique to handle very high speed encoders however it gets confused if your wiring has noise. To defeat the speed enhancement change:
DiffX2 = 2*(Pos-PosNoWrap) + (Change2+Change1);
to
DiffX2 = 2*(Pos-PosNoWrap);
We also discussed using the MPGSmooth.c technique instead.
We can probably add a mechanism to let KFLOP know that GCode is running by setting a virtual bit for example if you find that important.
Message: 2558 |
Date: 12/2/2011 |
| Subject: Re: Pendant Questions..... |
Hello Tom,
I've read this and that here on virtual IO and would personally likt to know more about taking advantage of it.(if that is what you meant by virtual bit)
-Brad Murry
> Hi Ray,
> I think we discussed this before when you had the Mach3 arrow key runaway. But the standard software MPG method has a technique to handle very high speed encoders however it gets confused if your wiring has noise. To defeat the speed enhancement change:Â
> Â DiffX2 = 2*(Pos-PosNoWrap) + (Change2+Change1);
> to
> Â DiffX2 = 2*(Pos-PosNoWrap);
> Sent: Friday, December 2, 2011 12:04 PM
> Subject: [DynoMotion] Pendant Questions.....
> I'm finally starting to bring up my pendant, and (surprise!) have run into at least one oddity, and some things I don't know how to implement.
> First, the MPG. I'm using the MPG code from Init3AnalogPlusMPG.c. It *sorta* works, but strangely. When I turn the MPG slowly, it seems to work OK. But, once I turn it beyond a relatively slow speed, the axis being jogged takes off at a pretty good clip, and just runs, literally, forever.
> Next, I've got a bunch of "button" functions, some of which are trivial (Execute, Halt, spindle/coolant on/off), but others less so, and I wonder if they even CAN be implemented under KMotionCNC. With Mach3, my pendant is ordinarily operated by a macropump driver, so it's easy to keep Mach3 and the hardware in-sync, and the pendant driver knows the state of Mach3. This allows me to make the button functions "state-aware". For example, a single button will do a CycleStart if no G-code program is currently running, or a Stop, if a G-code program is currently running. I have another button that serves the dual functions of FeedHold/Rewind. With KMotionCNC, it appears to me not practical to duplicate this, since the DSP has no clue whether a program is running or not. Is that correct?
> Also, in Mach3, both G00 and manual toolchanges are terminated by pressing CycleStart, but it appears to me that in KMotionCNC, a G00 is terminated by hitting "Execute", but a manual toolchange, which pops up a dialog, can only be exited by hitting Enter, or clicking with the mouse. Is there a way around this, to make them both accept the same button-triggered action?
> Regards,
> Ray L.
Message: 2560 |
Date: 12/2/2011 |
Hi Brad,
Virtual IO is just like real IO except it doesn't go to any physical pins. It just exists in KFLOP Memory. The idea is that it can take advantage of all the mechanisms in Mach3, KMotionCNC, KFLOP, and MM to set and test IO bits. So they are typically used as a flags between processes. KFLOP IO bits 45 and 46 are the KFLOP LEDs and can be used in the same way. Virtual bits exist as bits 48-63 and also as 1024-2047. Another use would be for IO expansion. One might have custom hardware with many IO bits. A User Program might read/write to the custom hardware via the UART or other means and copy the data to/from the Virtual Bits.
Message: 2563 |
Date: 12/2/2011 |
Yup, you did tell me that.... Sorry! I'm now using the Smooth code, I've added pull-ups and software de-bounce, and all is now seemingly working well.
A means of talking that G-code is running would be handy, for several reasons. Not the least would be to be able to disable the MPG. I think that would be a worthwhile addition.
Thanks!
Ray L.
> Hi Ray,
> to
> Regards,
> Ray L.
Message: 2569 |
Date: 12/2/2011 |
I think it would be very nice to have an area of shared memory that could be used to pass useful information between KMotionCNC and the DSP. Things such as a flag to indicate a program was running, jog parameters, FRO/SSO, etc. Barring that, some communications mechanism that would allow the DSP to ask for that information. It seems very odd to me to have on-screen controls for jog rates/increments, but not to be able to have those control the pendant jogging as well.
Ray L.
> Tom,
> Thanks!
> Regards,
> Ray L.
> > Hi Ray,
> > Â
> > Â
> > Â
> > Â
> > to
> > Â
> > Â
> > Â
> > Â
> > Â
> > Â
> > Â
> > Regards,
> > Ray L.
Message: 2570 |
Date: 12/2/2011 |
Hi Ray,
I think you are right. That was the idea behind that last change which allows the DSP to send commands to the PC (which include information requests).
BTW keep in mind this is a main disadvantage of being an external controller. Things will probably never be as tightly connected as an approach like Mach3 or EMC where everything (GUI and motion control) is performed by the same processor with common memory. In our case we are separated by a USB cable. (Of course I believe the advantages of an external controller far outweigh this disadvantage).
I think we could just add a couple new commands similar to requesting the axis resolutions but then these type of things change constantly unlike something like axis resolution that shouldn't really ever change.
I'm thinking to have a common C Structure like we have with uploading Global Status. The PC application can keep a copy of "last downloaded" and if it detects any change re-download it. That would make it easy to add more members to the structure. But we wouldn't want to download it more than several times per second.
Message: 2571 |
Date: 12/2/2011 |
KFlop is considerably more loosely coupled than other external controllers under Mach3. I'm finding getting the same functionality I have with the SmoothStepper to be quite difficult. With the SS, I can treat the MPG inputs as just signals, and the PC does all the processing. This seems impossible with KFlop, though I don't know why. I can get all the pendant switches working under Mach3, but it seems to not even see MPG inputs. Any idea why? There shouldn't be any speed issues, as it works perfectly connected to SmoothStepper inputs, and even a ModBus controller, which communicates over RS232! Basically, anything that can be done with a parallel port, can be done over USB or Ethernet, with no discernable performance penalty.
Also under Mach3 with SS, I have on-screen DROs which control jog speed, step size, etc., and the pendant code both reads and writes these, so I can change jog speed, step size, etc. either on-screen OR using the MPG on the pendant to modify the DROs. This basically allows me to control my machine almost entirely from the pendant, rarely having to go to the PC screen (which is not very conveniently located).
I do at least now seem to have enough functionality implemented to be able to do the most common, and important, operations under both KMotionCNC and Mach3, though it is still somewhat less, and somewhat different, from what I have with the SS.
Ray L.
> Hi Ray,
> Â Regards
> Sent: Friday, December 2, 2011 5:46 PM
> Subject: [DynoMotion] Re: Pendant Questions.....
> Tom,
> Regards,
> Ray L.
> > Tom,
> > Thanks!
> > Regards,
> > Ray L.
> > > Hi Ray,
> > > ÃÂ
> > > I think we discussed this before when you had the Mach3 arrow key runaway.ÃÂ ButÃÂ the standard software MPG method hasÃÂ a technique to handle very high speed encoders however it gets confused if your wiring has noise.ÃÂ To defeat the speed enhancement change:ÃÂ
> > > ÃÂ
> > > ÃÂ DiffX2 = 2*(Pos-PosNoWrap) + (Change2+Change1);
> > > ÃÂ
> > > ÃÂ
> > > to
> > > ÃÂ DiffX2 = 2*(Pos-PosNoWrap);
> > > ÃÂ
> > > ÃÂ
> > > ÃÂ
> > > Regards
> > > ÃÂ
> > > ÃÂ
> > > ÃÂ
> > > ÃÂ
> > > Regards,
> > > Ray L.
Message: 2572 |
Date: 12/2/2011 |
Hey Ray,
In light of the virtual IO Tom brought up, do you think the same pendant/UI sync could be achieved?
-Brad Murry
himykabibble
Sent:
12/2/2011 8:48 PM
To:
Subject:
Ray L.
> Hi Ray,
> BTW keep in mind this is a main disadvantage of being an external controller. Things will probably never be as tightly connected as an approach like Mach3 or EMC where everything (GUI and motion control) is performed by the same processor with common memory.Â
> I'm thinking to have a common C Structure like we have with uploading Global Status. The PC application can keep a copy of  "last downloaded" and if it detects any change re-download it.   That would make it easy to add more members to the structure.Â
> Â Regards
> Tom,
> Regards,
> Ray L.
> > Tom,
> > Thanks!
> > Regards,
> > Ray L.
> > > Hi Ray,
> > > ÂÂ
change:ÂÂ
> > > ÂÂ
> > > ÂÂ
> > > ÂÂ
> > > to
> > > ÂÂ
> > > ÂÂ
> > > ÂÂ
> > > Regards
> > > ÂÂ
> > > ÂÂ
> > > ÂÂ
> > > ÂÂ
Is that correct?
> > > Regards,
> > > Ray L.
Message: 2573 |
Date: 12/2/2011 |
Brad,
Don't see why not - that's basically what the other devices do.
Ray L.
--- In DynoMotion@yahoogroups.com, brad murry <bradodarb@...> wrote:
> Hey Ray,
> -Brad Murry
> From: himykabibble
> Sent: 12/2/2011 8:48 PM
> Tom,
> Regards,
> Ray L.
> > Hi Ray,
> > Tom,
> > Regards,
> > Ray L.
> > > Tom,
> > > Thanks!
> > > Regards,
> > > Ray L.
> > > > Hi Ray,
> > > > Ã
> > > > I think we discussed this before when you had the Mach3 arrow key runaway.à Butà the standard software MPG method hasà a technique to handle very high speed encoders however it gets confused if your wiring has noise.à To defeat the speed enhancement change:Ã
> > > > Ã
> > > > Ã DiffX2 = 2*(Pos-PosNoWrap) + (Change2+Change1);
> > > > Ã
> > > > Ã
> > > > to
> > > > Ã DiffX2 = 2*(Pos-PosNoWrap);
> > > > Ã
> > > > Ã
> > > > Ã
> > > > Regards
> > > > TK
> > > > Ã
> > > > Ã
> > > > Ã
> > > > Ã
> > > > Regards,
> > > > Ray L.
Message: 2574 |
Date: 12/2/2011 |
Maybe someone could wire a handler mechanism up in CGcodeInterpreter.cpp(wink wink).....
It would then be easily added to the .net side ;-)
-Brad Murry
himykabibble
Sent:
12/2/2011 10:18 PM
To:
Subject:
Brad,
Ray L.
> Hey Ray,
> -Brad Murry
> From: himykabibble
> Tom,
> Regards,
> Ray L.
> > Hi Ray,
> > Tom,
> > Regards,
> > Ray L.
> > > Tom,
> > > Thanks!
> > > Regards,
> > > Ray L.
> > > > Hi Ray,
> > > > Â
change:Â
> > > > Â
> > > > Â
> > > > Â
> > > > to
> > > > Â
> > > > Â
> > > > Â
> > > > Regards
> > > > TK
> > > > Â
> > > > Â
> > > > Â
> > > > Â
Is that correct?
> > > > Regards,
> > > > Ray L.
Message: 2577 |
Date: 12/3/2011 |
I'm confused about some of the "smooth" jogging logic. The move is programmed using MoveExp, but then there's the other "if" clause to "finalize" the move (when the axis changes, or when no MPG change occurs for one second), which programs a Move() to the same target position as the previous MoveExp(). Why is this necessary?
I'm also finding that at times, if Factor is set to some higher value (like 20.0) that the axis will sometimes continue moving for several seconds, and a pretty good distance, AFTER I stop turning the MPG. I would very much prefer movement stop ASAP after I stop turning the MPG, but can't figure out how to do that, since I don't know where the axis is.
Ray L.
> Hi Ray,
> to
> Regards,
> Ray L.
Message: 2578 |
Date: 12/3/2011 |
Hi Ray,
I think what is happening is that if you move the position faster than the max velocity then the MoveExp limits to the max velocity and the position falls behind and the position catches up after you slow down or stop.
Another possibility is that you have the smoothing set so high that it lags behind by a huge amount.
An exponential move takes forever to get to a final position. It just keeps converging closer and closer as time passes. So after some specified time of no encoder motion it just does a linear move of the last tiny bit so the move completes.
I guess by "User Stopped" you mean less than a certain movement (1 count) over a certain period of time? There really is no such thing as exactly "Stopped". But if you decide based on some criteria that you wish to suddenly stop you can issue a Jog(0,0); to stop without needing to know where you are. But also btw you do know where you are at all times.
A better solution might be to put a limit on the target position. The way an exponential move works is that as the target position moves around more or less randomly at the whim of the Operator the exponential move will always be trying to move toward the target at a speed that is proportional to how far the target is away. So by putting a clamp on the target position to within some tolerance of the current position (maybe 1 inch) then if the Operator suddenly flicks the position 10 inches away 9 inches of the change will be ignored.
Message: 2579 |
Date: 12/3/2011 |
Smoothing is set to the default value. Funny thing is, I can also get it to move well above the max speed (200 IPM) - I can sometimes make it move 50" in about 5 seconds!
"But also btw you do know where you are at all times." - How? I've tried using chan[n].Position, but I seem to get erratic results.
I'm getting something else rather baffling as well. I can get it to a state where one or more of the DROs gets clobbered - just changes instantly to some really huge number, that fills the DRO with digits, even over-writing the axis legend. This seems to happen at least sometimes when I do a Jog(n, 0.0) to stop motion.
And, I often find when I modify the code, and do an Init in KMCNC, the board goes out to lunch, and needs to be power-cycled to get it back. Downloading the same code after power-cycling always works fine. Shouldn't the download be more bullet-proof than that?
Ray L.
> Hi Ray,
> Sent: Saturday, December 3, 2011 8:28 AM
> Tom,
> Regards,
> Ray L.
> > Hi Ray,
> > ÃÂ
> > ÃÂ
> > ÃÂ
> > ÃÂ
> > to
> > ÃÂ
> > ÃÂ
> > ÃÂ
> > ÃÂ
> > ÃÂ
> > ÃÂ
> > ÃÂ
> > Regards,
> > Ray L.
Message: 2580 |
Date: 12/3/2011 |
Hi Ray,
chan[n].Dest would be the current commanded destination (you don't have position feedback).
Sounds like you have a bug and are corrupting something. If you send me your code I can look it over.
Message: 2582 |
Date: 12/3/2011 |
I seem to have gotten the worst of it sorted. I think part of it was saturating because I was doing a debug printf in a place that was generating too much output. I also found that if I try to use Jog(axis, 0.0) to stop an axis started with MoveExp(), it does all kinds of whacky, and usually bad, things. But if I move Move to end a MoveExp, and Jog to end a Jog, it seems to be OK.
Ray L.
> Hi Ray,
> Sent: Saturday, December 3, 2011 11:14 AM
> Tom,
> Regards,
> Ray L.
> > Hi Ray,
> > ÃÂ
> > ÃÂ
> > ÃÂ
> > An exponential move takes forever to get to a final position.ÃÂ It just keeps converging closer and closer as time passes.ÃÂ So after some specified time of no encoder motion it just does a linear move of the last tiny bit so the move completes.
> > ÃÂ
> > I guess by "User Stopped" you mean less than a certain movement (1 count) over a certain period of time?ÃÂ There really is no such thing as exactly "Stopped".ÃÂ But if you decide based on someÃÂ criteria that you wish to suddenly stopÃÂ you can issue a Jog(0,0); to stop without needing to know where you are.ÃÂ But also btw you do know where you are at all times.
> > ÃÂ
> > A better solution might be to put a limit on the target position.ÃÂ The way an exponential move works is that as the target position moves around more or less randomly at the whim of the Operator the exponential move will always be trying to move toward the target at a speed that is proportional to how far the target is away.ÃÂ So by putting a clamp on the target position to within some tolerance of the current position (maybe 1 inch) then if the Operator suddenly flicks the position 10 inches away 9 inches of the change will be ignored.
> > ÃÂ
> > ÃÂ
> > ÃÂ
> > ÃÂ
> > Tom,
> > Regards,
> > Ray L.
> > > Hi Ray,
> > > ÃâÃÂ
> > > I think we discussed this before when you had the Mach3 arrow key runaway.ÃâàButÃâàthe standard software MPG method hasÃâàa technique to handle very high speed encoders however it gets confused if your wiring has noise.ÃâàTo defeat the speed enhancement change:ÃâÃÂ
> > > ÃâÃÂ
> > > ÃâàDiffX2 = 2*(Pos-PosNoWrap) + (Change2+Change1);
> > > ÃâÃÂ
> > > ÃâÃÂ
> > > to
> > > ÃâàDiffX2 = 2*(Pos-PosNoWrap);
> > > ÃâÃÂ
> > > ÃâÃÂ
> > > ÃâÃÂ
> > > Regards
> > > ÃâÃÂ
> > > ÃâÃÂ
> > > ÃâÃÂ
> > > ÃâÃÂ
> > > Regards,
> > > Ray L.
Message: 2583 |
Date: 12/3/2011 |
You indicated earlier that I DO know where the axis is, but now you seem to be saying I don't, that I just know where it's going. Do I know what its current position is or not. If so, then how??
Ray L.
> Hi Ray,
> Tom,
> Regards,
> Ray L.
> > Hi Ray,
> > ÃÂ
> > ÃÂ
> > ÃÂ
> > ÃÂ
> > ÃÂ
> > ÃÂ
> > ÃÂ
> > ÃÂ
> > ÃÂ
> > Tom,
> > Regards,
> > Ray L.
> > > Hi Ray,
> > > ÃâÃÂ
> > > ÃâÃÂ
> > > ÃâÃÂ
> > > ÃâÃÂ
> > > to
> > > ÃâÃÂ
> > > ÃâÃÂ
> > > ÃâÃÂ
> > > Regards
> > > ÃâÃÂ
> > > ÃâÃÂ
> > > ÃâÃÂ
> > > ÃâÃÂ
> > > Regards,
> > > Ray L.
Message: 2584 |
Date: 12/3/2011 |
Hi Ray,
You know both. The terminology is probably confusing. It is more geared toward servos. Where the "Destination" is where the servo is trying to be - which may or may not be a moving target depeding on if a trajectory is in progress.
So the variables are:
Position = where you really are right now (only valid with a feedback device)
Dest = where you are supposed to be right now
LastMotionDest = Final dest of the last motion command
LastMotionType = Type of last Trajectory commanded
#define LAST_MOTION_JOG 0 // type of last independent motion was a jog
#define LAST_MOTION_MOVE 1 // type of last independent motion was a move
#define LAST_MOTION_MULTI 2 // type of last independent motion was a multi axis move (G0 type)
#define LAST_MOTION_EXP 3 // type of last independent motion was an exponential
These are all declared and commented in KMotionDef.h.
Message: 2586 |
Date: 12/3/2011 |
The "only valid with a feedback device" - is the killer. I'm using Geckos, so the encoders are not connected to the KFlop.
Ray L.
> Hi Ray,
> You know both. The terminology is probably confusing. It is more geared toward servos. Where the "Destination" is where the servo is trying to be - which may or may not be a moving target depeding on if a trajectory is in progress.Â
> Â LastMotionDest = Final dest of the last motion command
>  LastMotionType = Type of last Trajectory commandedLAST_MOTION_JOG 0 // type of last independent motion was a jog   #defineLAST_MOTION_MOVE 1 // type of last independent motion was a move   #defineLAST_MOTION_MULTI 2 // type of last independent motion was a multi axis move (G0 type)   #defineLAST_MOTION_EXP 3 // type of last independent motion was an exponential
> Â Â Â #define
> Sent: Saturday, December 3, 2011 3:07 PM
> Tom,
> Regards,
> Ray L.
> > Hi Ray,
> > ÃÂ
> > ÃÂ
> > Sounds like you have a bug and are corrupting something.ÃÂ If you send me your code I can look it over.
> > ÃÂ
> > ÃÂ
> > Tom,
> > Regards,
> > Ray L.
> > > Hi Ray,
> > > ÃâÃÂ
> > > ÃâÃÂ
> > > ÃâÃÂ
> > > An exponential move takes forever to get to a final position.ÃâàIt just keeps converging closer and closer as time passes.ÃâàSo after some specified time of no encoder motion it just does a linear move of the last tiny bit so the move completes.
> > > ÃâÃÂ
> > > I guess by "User Stopped" you mean less than a certain movement (1 count) over a certain period of time?ÃâàThere really is no such thing as exactly "Stopped".ÃâàBut if you decide based on someÃâàcriteria that you wish to suddenly stopÃâàyou can issue a Jog(0,0); to stop without needing to know where you are.ÃâàBut also btw you do know where you are at all times.
> > > ÃâÃÂ
> > > A better solution might be to put a limit on the target position.ÃâàThe way an exponential move works is that as the target position moves around more or less randomly at the whim of the Operator the exponential move will always be trying to move toward the target at a speed that is proportional to how far the target is away.ÃâàSo by putting a clamp on the target position to within some tolerance of the current position (maybe 1 inch) then if the Operator suddenly flicks the position 10 inches away 9 inches of the change will be ignored.
> > > ÃâÃÂ
> > > Regards
> > > ÃâÃÂ
> > > ÃâÃÂ
> > > ÃâÃÂ
> > > Tom,
> > > Regards,
> > > Ray L.
> > > > Hi Ray,
> > > > ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > I think we discussed this before when you had the Mach3 arrow key runaway.ÃÆ'ââ¬Å¡ÃâàButÃÆ'ââ¬Å¡Ãâàthe standard software MPG method hasÃÆ'ââ¬Å¡Ãâàa technique to handle very high speed encoders however it gets confused if your wiring has noise.ÃÆ'ââ¬Å¡ÃâàTo defeat the speed enhancement change:ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > ÃÆ'ââ¬Å¡ÃâàDiffX2 = 2*(Pos-PosNoWrap) + (Change2+Change1);
> > > > ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > to
> > > > ÃÆ'ââ¬Å¡ÃâàDiffX2 = 2*(Pos-PosNoWrap);
> > > > ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > Regards
> > > > TK
> > > > ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > Regards,
> > > > Ray L.
Message: 2587 |
Date: 12/3/2011 |
Hi Ray,
Well for your purposes you would probably want to use the Commanded Dest anyways. So I don't get your point.
Message: 2591 |
Date: 12/4/2011 |
The point was you indicated that I DID know the current machine position, so I could limit the jog distance "look-ahead" to prevent over-run. But, it appears that without encoders connected to the KFlop, I do NOT know the *current* machine position while it is in motion, right? But how do YOU track position, if there is no current position variable?
I seem to have the MPG all working nicely now. I'd like to think I simplified the code a bit. I couldn't make sense of the MPG wrap-around logic you had, so I just put in my own very simple (if, perhaps, a bit brute force) code, which seems to work perfectly:
int MPGPos, LastMPGPos, MPGChange;
char QuadTbl[16] =
// Gives delta from last MPG pos
// Rows are by last MPG Pos
// Columns are by current MPG Pos
0, 1, 0, -1, // LastPos = 0
-1, 0, 1, 0, // LastPos = 1
0, -1, 0, 1, // LastPos = 2
1, 0, -1, 0 // LastPos = 3
LastMPGPos = MPGPos;
// Gives 0,1,2,3 or 3,2,1,0 sequence
MPGPos = (MPGBitB << 1) | (MPGBitB ^ MPGBitA);
// Accounts for wrap-around
MPGChange = QuadTbl[(LastMPGPos << 2) + MPGPos];
Am I missing something your code does that this doesn't?
Ray L.
> Hi Ray,
> Sent: Saturday, December 3, 2011 8:16 PM
> Tom,
> Regards,
> Ray L.
> > Hi Ray,
> > ÃÂ
> > You know both.ÃÂ The terminology is probably confusing.ÃÂ It is more geared toward servos. Where the "Destination" is where the servo is trying to beÃÂ - which may or may not be a moving target depeding on if a trajectory is in progress.ÃÂ
> > ÃÂ
> > ÃÂ
> > PositionÃÂ = where youÃÂ really are right now (only valid with a feedback device)
> > ÃÂ
> > ÃÂ LastMotionDest = Final dest of the last motion command
> > ÃÂ LastMotionType = Type of last Trajectory commandedLAST_MOTION_JOG 0 // type of last independent motion was a jogÃÂ ÃÂ ÃÂ #defineLAST_MOTION_MOVE 1 // type of last independent motion was a moveÃÂ ÃÂ ÃÂ #defineLAST_MOTION_MULTI 2 // type of last independent motion was a multi axis move (G0 type)ÃÂ ÃÂ ÃÂ #defineLAST_MOTION_EXP 3 // type of last independent motion was an exponential
> > ÃÂ ÃÂ ÃÂ #define
> > ÃÂ
> > ÃÂ
> > ÃÂ
> > Tom,
> > Regards,
> > Ray L.
> > > Hi Ray,
> > > ÃâÃÂ
> > > ÃâÃÂ
> > > Sounds like you have a bug and are corrupting something.ÃâàIf you send me your code I can look it over.
> > > ÃâÃÂ
> > > Regards
> > > ÃâÃÂ
> > > Tom,
> > > Regards,
> > > Ray L.
> > > > Hi Ray,
> > > > ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > An exponential move takes forever to get to a final position.ÃÆ'ââ¬Å¡ÃâàIt just keeps converging closer and closer as time passes.ÃÆ'ââ¬Å¡ÃâàSo after some specified time of no encoder motion it just does a linear move of the last tiny bit so the move completes.
> > > > ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > I guess by "User Stopped" you mean less than a certain movement (1 count) over a certain period of time?ÃÆ'ââ¬Å¡ÃâàThere really is no such thing as exactly "Stopped".ÃÆ'ââ¬Å¡ÃâàBut if you decide based on someÃÆ'ââ¬Å¡Ãâàcriteria that you wish to suddenly stopÃÆ'ââ¬Å¡Ãâàyou can issue a Jog(0,0); to stop without needing to know where you are.ÃÆ'ââ¬Å¡ÃâàBut also btw you do know where you are at all times.
> > > > ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > A better solution might be to put a limit on the target position.ÃÆ'ââ¬Å¡ÃâàThe way an exponential move works is that as the target position moves around more or less randomly at the whim of the Operator the exponential move will always be trying to move toward the target at a speed that is proportional to how far the target is away.ÃÆ'ââ¬Å¡ÃâàSo by putting a clamp on the target position to within some tolerance of the current position (maybe 1 inch) then if the Operator suddenly flicks the position 10 inches away 9 inches of the change will be ignored.
> > > > ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > Regards
> > > > TK
> > > > ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > Tom,
> > > > Regards,
> > > > Ray L.
> > > > > Hi Ray,
> > > > > ÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > > I think we discussed this before when you had the Mach3 arrow key runaway.ÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡ÃâàButÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡Ãâàthe standard software MPG method hasÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡Ãâàa technique to handle very high speed encoders however it gets confused if your wiring has noise.ÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡ÃâàTo defeat the speed enhancement change:ÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > > ÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > > ÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡ÃâàDiffX2 = 2*(Pos-PosNoWrap) + (Change2+Change1);
> > > > > ÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > > ÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > > to
> > > > > ÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡ÃâàDiffX2 = 2*(Pos-PosNoWrap);
> > > > > ÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > > ÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > > ÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > > Regards
> > > > > TK
> > > > > ÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > > ÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > > ÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > > ÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > > Regards,
> > > > > Ray L.
Message: 2592 |
Date: 12/4/2011 |
Hi Ray,
Again it seems we have a terminology/communication issue. Obviously without encoder feedback connected to KFLOP it is impossible for KFLOP to truely know the current machine position. However it does know the current position it commanded the servos. If nothing catastrophic happened the Commanded Destination and the Actual Position should match except a small servo following error. So for the purposes of limiting jog motion we can use chan[x].Dest to know where we are. In fact for purposes of limiting the trajectory rate that might even be more logical.
The MPG Code you have looks great (although a subtract with sign extend might be slightly faster than the table lookup approach).
The original code did more than simple quadrature counting. Your code is limited to counting at 5.555KHz because every quadrature transition must be observed by the algorithm and the code only runs 5,555 times per second (one time slice every 180us). I've tested the other algorithm at over 100KHz by feeding the same encoder signals into both a hardware encoder input and the software routine and the counts match perfectly. The technique allows more than just one encoder count per sample. It keeps track of the last two deltas and uses that to predict the next. So for example at 100KHz the last two deltas might have been 19 and 20 counts. So it assumes the next delta should be close to 19.5 counts. As long as the real change is within +/- 1 count of the prediction it works. It works well because a change in speed of 5% in a small fraction of a
millisecond would correspond to ramp up to full speed in several milliseconds which for most systems is far beyond possibility. However the big disadvantage of the algorithm is that it gets confused with any noise inputs. The prediction stuff can be eliminated most simply by substituting zero for the last two deltas so then it just picks the delta closest to zero or -1, 0 , +1 counts. Change:
to
BTW how you were able to monitor an MPG under a Mach3 Macro pump running at ~ 10Hz is totally beyond me.
Message: 2596 |
Date: 12/4/2011 |
I'm not sure I can agree with that.... If I home the machine, then do a MoveExp(0, 1000000000) then chan[0].Dest is NOT going to show me where the machine IS, but where it WILL be at some (unknown to me) time in the future. The whole problem I'm having with the smooth MPG is that if I turn the MPG quickly, while a large Factor is in effect, I can command a very large move, which will only complete many seconds AFTER I've stopped moving the MPG. This will likely result in the machine running into its limits. It's impossible for me to know how far it WILL move until it's done, since there is no feedback to the user. Your suggestion, as I understood it, was to limit how far ahead I command moves(i.e. - clamp the delta between where the machine IS, and where the MPG code is telling it to go, to something like an inch or two), but I can't do that without knowing where the machine IS NOW, rather than where it WILL BE when it stops moving. Am I missing something here? It seems to me the smooth MPG mode is really only suitable for relatively small/slow moves, where Factor is kept to a low value, no? I think what I'm looking for is a hybrid jog, where it uses MoveExp for small values of Factor, and Jog for larger ones, so the jog speed transitions from a small increment step jog at very low MPG rotation rates, to a high-speed continuous Jog, ideally at rapid speed, at high MPG rotation rates.
The other controllers I've worked with all keep an internal counter, be it hardware (SmoothStepper) or software (Mach3), that tracks the current commanded position, which will differ from the physical machine position only by any physical and servo lag. So, for all practical purposes, I can KNOW, to within a fairly small error, where the machine actually SHOULD be at any time.
I suspected your MPG code was doing something predictive like that, but couldn't follow the logic. I've been unable to spin my MPG fast enough to come close to losing steps with the simple logic - Spinning as fast as I can, I average 20 passes, or about 4 mSec, between input changes, so I never see a count change of other than +/-1 or 0. I can see how this would be different with a higher resolution encoder - I think mine is about 50 counts/rev.
In Mach3, Mach3 itself monitors the MPG inputs, and maintains a position DRO, and my macropump simply looks at the DRO. Mach3 also handles all the high-rate jogging control, I simply have to tell it when to enable jogging, on what axis, at what speed, and in what mode, and it does the rest. As I said, my pendant is connected through a serial Modbus controller, and it works perfectly like this. It works identically when connected to SmoothStepper inputs, whether the SS I/F is USB or Ethernet. So, the 10Hz macropump rate is more than adequate for controlling jogging in the way I need to. The only place where the 10Hz update rate affects me at all is in handling double-clicks on the pendant button. Due to the 10Hz macropump rate, the user can pretty easily double click too quickly for it to be captured properly.
I believe (but I'm not sure) the SmoothStepper likely implements the MPG counter in hardware in the FPGA, and simply refreshes the Mach3 MPG counter at its normal update rate of 50Hz. It's entirely possible the ModIO does the same thing. But, the point is, that's all transparent to the user, who simply has to properly configure the MPGA/B inputs to the correct "pins", and the rest is handled in the plug-ins and device firmware, so it all looks exactly like an MPG connected to a parallel port to the user.
I believe the Mach3 interface used for jogging is essentially what you have in the Jog() function - Mach3 tells the device to "move this axis at this speed, in this direction", and then comes back later and tells it when it's time to stop. There is also a "failsafe", at least in the SS code, that will stop a jog if it fails to receive a periodic update from Mach3, to prevent runaways.
If you wanted to make life MUCH easier for Mach3 users, it seems to me there's no reason essentially the same functionality could not be implemented in the KFlop plug-in. I'd be willing to bet you could also implement a set of canned DSP code for Mach3 users that would support at least 99% of the most-used Mach3 functionality with no programming required on the users part, beyond perhaps axis configuration init, and a few other minor things in the plug-in configuration. Virtually all other needed information should be available through the plug-in from the standard Mach3 configuration dialogs. This is basically how the SS works, and makes the change from parallel port to SS incredibly painless - it took me mere minutes the first time I did it.
Ray L.
> Hi Ray,
> The original code did more than simple quadrature counting. Your code is limited to counting at 5.555KHz because every quadrature transition must be observed by the algorithm and the code only runs 5,555 times per second (one time slice every 180us). I've tested the other algorithm at over 100KHz by feeding the same encoder signals into both a hardware encoder input and the software routine and the counts match perfectly. The technique allows more than just one encoder count per sample. It keeps track of the last two deltas and uses that to predict the next. So for example at 100KHz the last two deltas might have been 19 and 20 counts. So it assumes the next delta should be close to 19.5 counts. As long as the real change is within +/- 1 count of the prediction it works. It works well because a change in speed of 5% in a small fraction of a millisecond would correspond to ramp up to full speed in several milliseconds which for most
> Â Â DiffX2 = 2*(Pos-PosNoWrap) + (Change2+Change1);
> to
> Â Â DiffX2 = 2*(Pos-PosNoWrap);
> Sent: Sunday, December 4, 2011 10:32 AM
> Tom,
> char QuadTbl[16] =
> Regards,
> Ray L.
> > Hi Ray,
> > ÃÂ
> > Well for your purposes you would probably want to use the Commanded Dest anyways.ÃÂ So I don't get your point.
> > ÃÂ
> > ÃÂ
> > ÃÂ
> > Tom,
> > Regards,
> > Ray L.
> > > Hi Ray,
> > > ÃâÃÂ
> > > You know both.ÃâàThe terminology is probably confusing.ÃâàIt is more geared toward servos. Where the "Destination" is where the servo is trying to beÃâà- which may or may not be a moving target depeding on if a trajectory is in progress.ÃâÃÂ
> > > ÃâÃÂ
> > > ÃâÃÂ
> > > PositionÃâà= where youÃâàreally are right now (only valid with a feedback device)
> > > ÃâÃÂ
> > > ÃâàLastMotionDest = Final dest of the last motion command
> > > ÃâàLastMotionType = Type of last Trajectory commandedLAST_MOTION_JOG 0 // type of last independent motion was a jogÃâàÃâàÃâà#defineLAST_MOTION_MOVE 1 // type of last independent motion was a moveÃâàÃâàÃâà#defineLAST_MOTION_MULTI 2 // type of last independent motion was a multi axis move (G0 type)ÃâàÃâàÃâà#defineLAST_MOTION_EXP 3 // type of last independent motion was an exponential
> > > ÃâàÃâàÃâà#define
> > > ÃâÃÂ
> > > ÃâÃÂ
> > > Regards
> > > ÃâÃÂ
> > > Tom,
> > > Regards,
> > > Ray L.
> > > > Hi Ray,
> > > > ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > Sounds like you have a bug and are corrupting something.ÃÆ'ââ¬Å¡ÃâàIf you send me your code I can look it over.
> > > > ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > Regards
> > > > TK
> > > > ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > Tom,
> > > > Regards,
> > > > Ray L.
> > > > > Hi Ray,
> > > > > ÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > > ÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > > ÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > > An exponential move takes forever to get to a final position.ÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡ÃâàIt just keeps converging closer and closer as time passes.ÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡ÃâàSo after some specified time of no encoder motion it just does a linear move of the last tiny bit so the move completes.
> > > > > ÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > > I guess by "User Stopped" you mean less than a certain movement (1 count) over a certain period of time?ÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡ÃâàThere really is no such thing as exactly "Stopped".ÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡ÃâàBut if you decide based on someÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡Ãâàcriteria that you wish to suddenly stopÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡Ãâàyou can issue a Jog(0,0); to stop without needing to know where you are.ÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡ÃâàBut also btw you do know where you are at all times.
> > > > > ÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > > A better solution might be to put a limit on the target position.ÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡ÃâàThe way an exponential move works is that as the target position moves around more or less randomly at the whim of the Operator the exponential move will always be trying to move toward the target at a speed that is proportional to how far the target is away.ÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡ÃâàSo by putting a clamp on the target position to within some tolerance of the current position (maybe 1 inch) then if the Operator suddenly flicks the position 10 inches away 9 inches of the change will be ignored.
> > > > > ÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > > Regards
> > > > > TK
> > > > > ÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > > ÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > > ÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > > Tom,
> > > > > Regards,
> > > > > Ray L.
> > > > > > Hi Ray,
> > > > > > ÃÆ'Ã'Ãâ 'ÃÆ'ââââ¬Å¡Ã¬Ãâ¦ÃÂ¡ÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > > > I think we discussed this before when you had the Mach3 arrow key runaway.ÃÆ'Ã'Ãâ 'ÃÆ'ââââ¬Å¡Ã¬Ãâ¦ÃÂ¡ÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡ÃâàButÃÆ'Ã'Ãâ 'ÃÆ'ââââ¬Å¡Ã¬Ãâ¦ÃÂ¡ÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡Ãâàthe standard software MPG method hasÃÆ'Ã'Ãâ 'ÃÆ'ââââ¬Å¡Ã¬Ãâ¦ÃÂ¡ÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡Ãâàa technique to handle very high speed encoders however it gets confused if your wiring has noise.ÃÆ'Ã'Ãâ 'ÃÆ'ââââ¬Å¡Ã¬Ãâ¦ÃÂ¡ÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡ÃâàTo defeat the speed enhancement change:ÃÆ'Ã'Ãâ 'ÃÆ'ââââ¬Å¡Ã¬Ãâ¦ÃÂ¡ÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > > > to
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > > > Regards
> > > > > > TK
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > > > Regards,
> > > > > > Ray L.
Message: 2597 |
Date: 12/4/2011 |
"It seems to me the smooth MPG mode is really only suitable for relatively small/slow moves, where Factor is kept to a low value" - Actually, it just occurred to me that the trick is to keep the maximum
allowed "Factor" to a value that will induce a move at JUST slightly below rapid speed at the maximum possible MPG update rate. Then any lag should remain small.
Ray L.
> Tom,
> Regards,
> Ray L.
> > Hi Ray,
> > Â
> > Â
> > Â
> > Â
> > to
> > Â
> > Â
> > Â
> > Â
> > Â
> > Tom,
> > char QuadTbl[16] =
> > Regards,
> > Ray L.
> > > Hi Ray,
> > > ÃÂ
> > > ÃÂ
> > > Regards
> > > ÃÂ
> > > ÃÂ
> > > Tom,
> > > Regards,
> > > Ray L.
> > > > Hi Ray,
> > > > ÃâÃÂ
> > > > ÃâÃÂ
> > > > ÃâÃÂ
> > > > ÃâÃÂ
> > > > ÃâàÃâàÃâà#define
> > > > ÃâÃÂ
> > > > ÃâÃÂ
> > > > Regards
> > > > TK
> > > > ÃâÃÂ
> > > > Tom,
> > > > Regards,
> > > > Ray L.
> > > > > Hi Ray,
> > > > > ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > > ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > > ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > > Regards
> > > > > TK
> > > > > ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > > Tom,
> > > > > Regards,
> > > > > Ray L.
> > > > > > Hi Ray,
> > > > > > ÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > > > ÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > > > ÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > > > ÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > > > ÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > > > ÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > > > Regards
> > > > > > TK
> > > > > > ÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > > > ÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > > > ÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > > > Tom,
> > > > > > Regards,
> > > > > > Ray L.
> > > > > > > Hi Ray,
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > > > > to
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > > > > Regards
> > > > > > > TK
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > > > > Regards,
> > > > > > > Ray L.
Message: 2598 |
Date: 12/4/2011 |
Hi Ray,
Thanks for the expaination. That makes perfect sense. You are reading a hardware MPG counter in the Macro Pump rather than the AB Quadrature inputs.
A number of Users have commented on how much more responsive the MPG is under KFLOP control rather than in their previous controller. This is because it is all performed within KFLOP with sub millisecond response. The PC application running at 10Hz (occasionally worse) plus USB delays are not in the loop. I'm surprised your experience is different. Maybe it is because your MPG has lower resolution?
Regarding the chan[0].Dest : it will tell you where the axis is on an instantaneous basis which is exactly what you need. On the KMotion Axis Screen the "Dest" column is exactly this variable displayed. I don't know how to explain it any clearer than I did in my last email. Please try using it to convince yourself.
And share your MPG code with this new feature after it is working :}
Message: 2601 |
Date: 12/4/2011 |
OK, I'll try using Dest. I thought you had indicated previously that it did not give instantaneous position. Now it makes a lot more sense.
I can see where a high-resolution MPG might get sluggish over USB, but aren't they typically pretty low-resolution, like 50-100 counts/rev? I've only ever used a couple.... Clearly having it run entirely on the KFlop has advantages, but I'm just suggesting for ease of setup, supporting the "Mach3 way" in the plug-in would make life a LOT simpler for non-programmer Mach3 users (and most people who mess with these machines are NOT programmers - Most of them struggle with even very simple VB macros!) I would think it could significantly expand your potential market, and reduce hand-holding.
Heck, I've spent several days of my spare time over the last few weeks getting to the point where I have enough functionality to finally be able to consider switching out my SS for the KFLop. That's compared to, quite literally, only about 10-15 minutes to get my SmoothStepper up and running the first time with ALL the same functionality (actually a bit more...). VERY few of the CNC guys I know would've ever been able to make it to this point.
I plan to hook the KFlop up to the machine tomorrow, so we'll see how badly I've screwed things up. :-)
Ray L.
> Hi Ray,
> Sent: Sunday, December 4, 2011 1:15 PM
> Tom,
> Regards,
> Ray L.
> > Hi Ray,
> > ÃÂ
> > Again it seems we have a terminology/communication issue.ÃÂ Obviously without encoder feedback connected to KFLOP it is impossible for KFLOP to truely know the current machine position.ÃÂ However it does know the current position it commanded the servos.ÃÂ If nothing catastrophic happened the Commanded Destination and the Actual Position should match except a small servo following error.ÃÂ So for the purposes of limiting jog motion we can use chan[x].Dest to know where we are.ÃÂ In fact for purposes of limiting the trajectory rate that might even be more logical.
> > ÃÂ
> > ÃÂ
> > The original code did more than simple quadrature counting.ÃÂ Your code is limited to counting at 5.555KHz because every quadrature transition must be observed by the algorithm and the code only runs 5,555 times per second (one time slice every 180us).ÃÂ I've tested the other algorithm at over 100KHz by feeding the same encoder signals into both a hardware encoder input and the software routine and the counts match perfectly.ÃÂ The techniqueÃÂ allows more than just one encoder count per sample.ÃÂ It keeps track of the last two deltas and uses that to predict the next.ÃÂ So for example at 100KHz the last two deltas might have been 19 and 20 counts.ÃÂ So it assumes the next delta should be close to 19.5 counts.ÃÂ As long as the real change is within +/- 1 count of the prediction it works.ÃÂ It works well becauseÃÂ a change in speed of 5% inÃÂ a small fraction of a millisecond would correspond toÃÂ ramp up to full speed in several
> > systems is far beyond possibility.ÃÂ However the big disadvantage of the algorithm is that it gets confusedÃÂ with any noise inputs.ÃÂ The prediction stuff can be eliminated most simply by substitutingÃÂ zero for the last two deltas so then it just picks the delta closest to zero or -1, 0 , +1ÃÂ ÃÂ counts.ÃÂ Change:
> > ÃÂ
> > ÃÂ ÃÂ DiffX2 = 2*(Pos-PosNoWrap) + (Change2+Change1);
> > to
> > ÃÂ
> > ÃÂ ÃÂ DiffX2 = 2*(Pos-PosNoWrap);
> > ÃÂ
> > ÃÂ
> > ÃÂ
> > ÃÂ
> > Tom,
> > char QuadTbl[16] =
> > Regards,
> > Ray L.
> > > Hi Ray,
> > > ÃâÃÂ
> > > Well for your purposes you would probably want to use the Commanded Dest anyways.ÃâàSo I don't get your point.
> > > ÃâÃÂ
> > > Regards
> > > ÃâÃÂ
> > > ÃâÃÂ
> > > Tom,
> > > Regards,
> > > Ray L.
> > > > Hi Ray,
> > > > ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > You know both.ÃÆ'ââ¬Å¡ÃâàThe terminology is probably confusing.ÃÆ'ââ¬Å¡ÃâàIt is more geared toward servos. Where the "Destination" is where the servo is trying to beÃÆ'ââ¬Å¡Ãâà- which may or may not be a moving target depeding on if a trajectory is in progress.ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > PositionÃÆ'ââ¬Å¡Ãâà= where youÃÆ'ââ¬Å¡Ãâàreally are right now (only valid with a feedback device)
> > > > ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > ÃÆ'ââ¬Å¡ÃâàLastMotionDest = Final dest of the last motion command
> > > > ÃÆ'ââ¬Å¡ÃâàLastMotionType = Type of last Trajectory commandedLAST_MOTION_JOG 0 // type of last independent motion was a jogÃÆ'ââ¬Å¡ÃâÃÂ ÃÆ'ââ¬Å¡ÃâÃÂ ÃÆ'ââ¬Å¡Ãâà#defineLAST_MOTION_MOVE 1 // type of last independent motion was a moveÃÆ'ââ¬Å¡ÃâÃÂ ÃÆ'ââ¬Å¡ÃâÃÂ ÃÆ'ââ¬Å¡Ãâà#defineLAST_MOTION_MULTI 2 // type of last independent motion was a multi axis move (G0 type)ÃÆ'ââ¬Å¡ÃâÃÂ ÃÆ'ââ¬Å¡ÃâÃÂ ÃÆ'ââ¬Å¡Ãâà#defineLAST_MOTION_EXP 3 // type of last independent motion was an exponential
> > > > ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > Regards
> > > > TK
> > > > ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > Tom,
> > > > Regards,
> > > > Ray L.
> > > > > Hi Ray,
> > > > > ÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > > ÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > > Sounds like you have a bug and are corrupting something.ÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡ÃâàIf you send me your code I can look it over.
> > > > > ÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > > Regards
> > > > > TK
> > > > > ÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > > Tom,
> > > > > Regards,
> > > > > Ray L.
> > > > > > Hi Ray,
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > > > An exponential move takes forever to get to a final position.ÃÆ'Ã'Ãâ 'ÃÆ'ââââ¬Å¡Ã¬Ãâ¦ÃÂ¡ÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡ÃâàIt just keeps converging closer and closer as time passes.ÃÆ'Ã'Ãâ 'ÃÆ'ââââ¬Å¡Ã¬Ãâ¦ÃÂ¡ÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > > > I guess by "User Stopped" you mean less than a certain movement (1 count) over a certain period of time?ÃÆ'Ã'Ãâ 'ÃÆ'ââââ¬Å¡Ã¬Ãâ¦ÃÂ¡ÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡ÃâàThere really is no such thing as exactly "Stopped".ÃÆ'Ã'Ãâ 'ÃÆ'ââââ¬Å¡Ã¬Ãâ¦ÃÂ¡ÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡ÃâàBut if you decide based on someÃÆ'Ã'Ãâ 'ÃÆ'ââââ¬Å¡Ã¬Ãâ¦ÃÂ¡ÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡Ãâàcriteria that you wish to suddenly stopÃÆ'Ã'Ãâ 'ÃÆ'ââââ¬Å¡Ã¬Ãâ¦ÃÂ¡ÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡Ãâàyou can issue a Jog(0,0); to stop without needing to know where you are.ÃÆ'Ã'Ãâ 'ÃÆ'ââââ¬Å¡Ã¬Ãâ¦ÃÂ¡ÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > > > A better solution might be to put a limit on the target position.ÃÆ'Ã'Ãâ 'ÃÆ'ââââ¬Å¡Ã¬Ãâ¦ÃÂ¡ÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡ÃâàThe way an exponential move works is that as the target position moves around more or less randomly at the whim of the Operator the exponential move will always be trying to move toward the target at a speed that is proportional to how far the target is away.ÃÆ'Ã'Ãâ 'ÃÆ'ââââ¬Å¡Ã¬Ãâ¦ÃÂ¡ÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > > > Regards
> > > > > > TK
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > > > Tom,
> > > > > > Regards,
> > > > > > Ray L.
> > > > > > > Hi Ray,
> > > > > > > ÃÆ'Ã'Ãâ 'ÃÆ'ââ¬Â 'ÃÆ'Ã'ÃâÃÂ¢ÃÆ'ââââ¬Ã
¡ÃâÃÂ¬ÃÆ'ââ¬Â¦ÃâÃÂ¡ÃÆ'Ã'Ãâ 'ÃÆ'ââââ¬Å¡Ã¬Ãâ¦ÃÂ¡ÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > > > > I think we discussed this before when you had the Mach3 arrow key runaway.ÃÆ'Ã'Ãâ 'ÃÆ'ââ¬Â 'ÃÆ'Ã'ÃâÃÂ¢ÃÆ'ââââ¬Ã
Â¡ÃÆ'ââ¬Å¡ÃâàButÃÆ'Ã'Ãâ 'ÃÆ'ââ¬Â 'ÃÆ'Ã'ÃâÃÂ¢ÃÆ'ââââ¬Ã
Â¡ÃÆ'ââ¬Å¡Ãâàthe standard software MPG method hasÃÆ'Ã'Ãâ 'ÃÆ'ââ¬Â 'ÃÆ'Ã'ÃâÃÂ¢ÃÆ'ââââ¬Ã
Â¡ÃÆ'ââ¬Å¡Ãâàa technique to handle very high speed encoders however it gets confused if your wiring has noise.ÃÆ'Ã'Ãâ 'ÃÆ'ââ¬Â 'ÃÆ'Ã'ÃâÃÂ¢ÃÆ'ââââ¬Ã
> enhancement change:ÃÆ'Ã'Ãâ 'ÃÆ'ââ¬Â 'ÃÆ'Ã'ÃâÃÂ¢ÃÆ'ââââ¬Ã
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > > > > to
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > > > > Regards
> > > > > > > TK
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > > > > Regards,
> > > > > > > Ray L.
Message: 2602 |
Date: 12/4/2011 |
Limiting the distance I command ahead of current position appears to work very nicely. I clamp MPGTarget to no more than 1" from the current Dest. It appears I can get up to full rapid speed, and when I stop the MPG, the machine stops within about an inch - quite acceptable. This, of course, is in simulation. If it works as well on the actual machine tomorrow I'll be in business.
Ray L.
> Tom,
> Regards,
> Ray L.
> > Hi Ray,
> > Â
> > Â
> > Â
> > Â
> > Â
> > Â
> > Â
> > Â
> > Tom,
> > Regards,
> > Ray L.
> > > Hi Ray,
> > > ÃÂ
> > > ÃÂ
> > > ÃÂ
> > > ÃÂ
> > > to
> > > ÃÂ
> > > ÃÂ
> > > ÃÂ
> > > Regards
> > > ÃÂ
> > > ÃÂ
> > > Tom,
> > > char QuadTbl[16] =
> > > Regards,
> > > Ray L.
> > > > Hi Ray,
> > > > ÃâÃÂ
> > > > ÃâÃÂ
> > > > Regards
> > > > TK
> > > > ÃâÃÂ
> > > > ÃâÃÂ
> > > > Tom,
> > > > Regards,
> > > > Ray L.
> > > > > Hi Ray,
> > > > > ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > > ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > > ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > > ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > > ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > > ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > > Regards
> > > > > TK
> > > > > ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > > Tom,
> > > > > Regards,
> > > > > Ray L.
> > > > > > Hi Ray,
> > > > > > ÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > > > ÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > > > ÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > > > Regards
> > > > > > TK
> > > > > > ÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > > > Tom,
> > > > > > Regards,
> > > > > > Ray L.
> > > > > > > Hi Ray,
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > > > > Regards
> > > > > > > TK
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > > > > Tom,
> > > > > > > Regards,
> > > > > > > Ray L.
> > > > > > > > Hi Ray,
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > > > > > to
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > > > > > Regards
> > > > > > > > TK
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > > > > > Regards,
> > > > > > > > Ray L.
Message: 2603 |
Date: 12/5/2011 |
Hehe. Stop in about an inch. This is why I don't use my SS on my other machine and run it parallel with Mach. It isn't that the SS does not move the machine well but the moves which are fast do not keep up with my pendant so there is always movement after I stop rooting. I suspect when moving slower there still will be. Only really worrys me when setting z zero but.
True the SS is about a drop in though. But really no where near what. The k is
The pendant movement on the k is great in my opinion. Having it in my program to select different speeds for moving is very cool to. Aaa all the io!!
Ray L.
> Tom,
> Regards,
> Ray L.
> > Hi Ray,
> > Â
> > Â
> > Â
> > Â
> > Â
> > Â
> > Â
> > Â
> > Tom,
> > Regards,
> > Ray L.
> > > Hi Ray,
> > > ÂÂ
> > > ÂÂ
> > > ÂÂ
> > > ÂÂ
> > > to
> > > ÂÂ
> > > ÂÂ
> > > ÂÂ
> > > Regards
> > > ÂÂ
> > > ÂÂ
> > > Tom,
> > > char QuadTbl[16] =
> > > Regards,
> > > Ray L.
> > > > Hi Ray,
> > > > ÂÂÂ
> > > > ÂÂÂ
> > > > Regards
> > > > TK
> > > > ÂÂÂ
> > > > ÂÂÂ
> > > > Tom,
> > > > Regards,
> > > > Ray L.
> > > > > Hi Ray,
> > > > > ÃÆ'‚ÂÂÂ
> > > > > You know both.ÃÆ'‚ The terminology is probably confusing.ÃÆ'‚ It is more geared toward servos. Where the "Destination" is where the servo is trying to beÃÆ'‚ - which may or may not be a moving target depeding on if a trajectory is in progress.ÃÆ'‚ÂÂÂ
> > > > > ÃÆ'‚ÂÂÂ
> > > > > ÃÆ'‚ÂÂÂ
> > > > > PositionÃÆ'‚ = where youÃÆ'‚ really are right now (only valid with a feedback device)
> > > > > ÃÆ'‚ÂÂÂ
> > > > > ÃÆ'‚ LastMotionDest = Final dest of the last motion command
> > > > > ÃÆ'‚ LastMotionType = Type of last Trajectory commandedLAST_MOTION_JOG 0 // type of last independent motion was a jogÃÆ'‚ ÃÆ'‚ ÃÆ'‚ #defineLAST_MOTION_MOVE 1 // type of last independent motion was a moveÃÆ'‚ ÃÆ'‚ ÃÆ'‚ #defineLAST_MOTION_MULTI 2 // type of last independent motion was a multi axis move (G0 type)ÃÆ'‚ ÃÆ'‚ ÃÆ'‚ #defineLAST_MOTION_EXP 3 // type of last independent motion was an exponential
> > > > > ÃÆ'‚ÂÂÂ
> > > > > ÃÆ'‚ÂÂÂ
> > > > > Regards
> > > > > TK
> > > > > ÃÆ'‚ÂÂÂ
> > > > > Tom,
> > > > > Regards,
> > > > > Ray L.
> > > > > > Hi Ray,
> > > > > > ÃÆ'Æ'‚ÃÆ'‚ÂÂÂ
> > > > > > ÃÆ'Æ'‚ÃÆ'‚ÂÂÂ
> > > > > > Sounds like you have a bug and are corrupting something.ÃÆ'Æ'‚ÃÆ'‚ If you send me your code I can look it over.
> > > > > > ÃÆ'Æ'‚ÃÆ'‚ÂÂÂ
> > > > > > Regards
> > > > > > TK
> > > > > > ÃÆ'Æ'‚ÃÆ'‚ÂÂÂ
> > > > > > Tom,
> > > > > > Regards,
> > > > > > Ray L.
> > > > > > > Hi Ray,
> > > > > > > ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡ÃÆ'Æ'‚ÃÆ'‚ÂÂÂ
> > > > > > > An exponential move takes forever to get to a final position.ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡ÃÆ'Æ'‚ÃÆ'‚ It just keeps converging closer and closer as time passes.ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡ÃÆ'Æ'‚ÃÆ'‚ So after some specified time of no encoder motion it just does a linear move of the last tiny bit so the move completes.
> > > > > > > I guess by "User Stopped" you mean less than a certain movement (1 count) over a certain period of time?ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡ÃÆ'Æ'‚ÃÆ'‚ There really is no such thing as exactly "Stopped".ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡ÃÆ'Æ'‚ÃÆ'‚ But if you decide based on someÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡ÃÆ'Æ'‚ÃÆ'‚ criteria that you wish to suddenly stopÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡ÃÆ'Æ'‚ÃÆ'‚ you can issue a Jog(0,0); to stop without needing to know where you are.ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡ÃÆ'Æ'‚ÃÆ'‚ But also btw you do know where you are at all times.
> > > > > > > A better solution might be to put a limit on the target position.ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡ÃÆ'Æ'‚ÃÆ'‚ The way an exponential move works is that as the target position moves around more or less randomly at the whim of the Operator the exponential move will always be trying to move toward the target at a speed that is proportional to how far the target is away.ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡ÃÆ'Æ'‚ÃÆ'‚ So by putting a clamp on the target position to within some tolerance of the current position (maybe 1 inch) then if the Operator suddenly flicks the position 10 inches away 9 inches of the change will be ignored.
> > > > > > > Regards
> > > > > > > TK
> > > > > > > Tom,
> > > > > > > Regards,
> > > > > > > Ray L.
> > > > > > > > Hi Ray,
> > > > > > > > ÃÆ'Æ'Æ'ÃÆ'†'ÃÆ'Æ'¢ÃÆ'¢â€šÂ¬ÃÆ'…¡ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡ÃÆ'Æ'‚ÃÆ'‚ÂÂÂ
> > > > > > > > I think we discussed this before when you had the Mach3 arrow key runaway.ÃÆ'Æ'Æ'ÃÆ'†'ÃÆ'Æ'¢ÃÆ'¢â€šÂ¬ÃÆ'…¡ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡ÃÆ'Æ'‚ÃÆ'‚ ButÃÆ'Æ'Æ'ÃÆ'†'ÃÆ'Æ'¢ÃÆ'¢â€šÂ¬ÃÆ'…¡ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡ÃÆ'Æ'‚ÃÆ'‚ the standard software MPG method hasÃÆ'Æ'Æ'ÃÆ'†'ÃÆ'Æ'¢ÃÆ'¢â€šÂ¬ÃÆ'…¡ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡ÃÆ'Æ'‚ÃÆ'‚ a technique to handle very high speed encoders however it gets confused if your wiring has noise.ÃÆ'Æ'Æ'ÃÆ'†'ÃÆ'Æ'¢ÃÆ'¢â€šÂ¬ÃÆ'…¡ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡ÃÆ'Æ'‚ÃÆ'‚ To defeat the speed
> > enhancement change:ÃÆ'Æ'Æ'ÃÆ'†'ÃÆ'Æ'¢ÃÆ'¢â€šÂ¬ÃÆ'…¡ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡ÃÆ'Æ'‚ÃÆ'‚ÂÂÂ
> > > > > > > > ÃÆ'Æ'Æ'ÃÆ'†'ÃÆ'Æ'¢ÃÆ'¢â€šÂ¬ÃÆ'…¡ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡ÃÆ'Æ'‚ÃÆ'‚ DiffX2 = 2*(Pos-PosNoWrap) + (Change2+Change1);
> > > > > > > > to
> > > > > > > > ÃÆ'Æ'Æ'ÃÆ'†'ÃÆ'Æ'¢ÃÆ'¢â€šÂ¬ÃÆ'…¡ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡ÃÆ'Æ'‚ÃÆ'‚ DiffX2 = 2*(Pos-PosNoWrap);
> > > > > > > > Regards
> > > > > > > > TK
> > > > > > > > Regards,
> > > > > > > > Ray L.
