Hi Rob,
Does your C program enable the Axes? See:
http://dynomotion.com/Help/Mach3Plugin/Mach3.htmIt is normal that after a Step/Dir Generator is configured and enabled to drive the Step and Dir pins you will no longer be able to toggle them as General Purpose IO.
Message: 9373 |
Date: 3/26/2014 |
| Subject: Re: Motors disabled on start, enable them then steps go high |
Hi Rob,
The Step signal requires an edge transition (change) to cause the the drive to advance the motor one microstep. Remaining high or low will not cause the drive to move the motor. The signal needs to be toggling high and low to cause the motor to move. KFLOP can be configured for the Step to remain normally high and pulse low to advance the motor or to remain normally low and pulse high to advance the
motor. These pulses are hard to see without a scope because they are only microseconds (or less) long. See also:
http://dynomotion.com/Help/StepAndDirection/StepAndDir.htm
Message: 9374 |
Date: 3/27/2014 |
Thanks for setting me straight!! Makes sense.
Rob On Mar 26, 2014, at 5:12 PM, Tom Kerekes <tk@...> wrote:
Hi Rob,
