Group: DynoMotion Message: 5025 From: Fouijar Date: 5/22/2012
Subject: Re: Mosfet NDS9956A
I received the Mosfets and replaced SW2&3 this works as new.
Jerome
--- In DynoMotion@yahoogroups.com, "Fouijar" <fouijar@...> wrote:
> Hi Lee,
> I read a part of your link, and effectively it could be a nice upgrade. I'm not the electronic guru but for sure It seems a good point to me.
> Where I'm more uncomfortable is the adaptation on the board, this a very different configuration than the 8 pin mosfet.
> The ZVN4306GVCT-ND sot223 is rated at 2.1 amps/60V 2W max continuous,
> probably the most adapted. When I was reading the datasheet, It's also indicated for stepper driving. This leaded me to: why not a 8 pin SM driver for coils like H bridges and so. I made at school a control card using such devices, maybe are they well suited too, what do you think?
> My opinion is that it should be something "easy to implement" on the actual setup or to be mounted on an external control board and use extra outputs available on Kflop to add functionalities.
> Your advice would be valuable.
> Regards,
> Jerome
> --- In DynoMotion@yahoogroups.com, Lee Studley <indigo_red@> wrote:
> > Hi Jerome,
> > I simulated your setup using LTSpice and a inductor of 600ohm/24vdc and
> > an estimated 1-to-4Henries.
> > Wow, without a good *fast*, diode you can easily get a few Kvolts of
> > inductive flyback on turnoff.
> > I'll post a writeup in the files section on my mentioned Cascode setup.
> > The article I mentioned before doesn't cover the variations. You can use
> > 2 mosfets stacked instead of just a BJT.
> > I uploaded a good Zetex appnote in the files section under"Driving
> > Relays". On page 2 I added a note about the surface mount version of the
> > part
> > avalanche mfet ZVN4206AV that will work perfectly to complement the
> > Kflop drive if a cascode is called for. Its a tough part that can take
> > over-voltages nicely.
> > -Lee
> > On 5/11/2012 6:24 AM, Fouijar wrote:
> > > Hi Lee,
> > > I checked the wiring and it's right as you mentioned. I did a test
> > > diode procedure and the diode seems to be working as it should.
> > > Your explanation isn't muddy, I understand clearly what you mean.
> > > Anyway, sometimes things aren't working like they should. As a
> > > security measure I'll replace the diodes, I bought more than necessary
> > > diodes in prevision of such case.
> > > I'll now check for temporary control solution, I.e. Opto outs.
> > > Thanks for your attention and for the useful link.
> > > Regards,
> > > J.
> > > <mailto:DynoMotion%40yahoogroups.com>, "studleylee" <indigo_red@>
> > > wrote:
Group: DynoMotion Message: 5103 From: Lee Studley Date: 5/30/2012
Hi Jerome,
I added the 28v/500mW zeners on my board. It looks alittle ugly, but it's on the back-side so not really visible. I made a small
bussbar that connected to the gnd large hole/via nearby. That mill in the youtube video is the one I'm reworking, so I also have
lots of relays to drive. This will protect me against any unforeseen-isms.
Did you ever find the root cause of the the mosfet failures, or did you add extra coil flyback diodes?
-Lee
Jerome
> Hi Lee,
> Regards,
> Jerome
> > Hi Jerome,
> > part
> > -Lee
> > > Hi Lee,
> > > Regards,
> > > J.
> > > wrote:
Group: DynoMotion Message: 5104 From: studleylee Date: 5/30/2012
This item was meant to be sent to Jerome, I accidentally sent it to the group.
These added zener diodes are not really needed, but in my case I wanted extra bullet-proofing because I'm driving some odd unknown characteristic relays in my system.
Loving the the KFLOP/Kanalog combination! -Lee Studley
--- In DynoMotion@yahoogroups.com, Lee Studley <indigo_red@...> wrote:
> Hi Jerome,
> Thanks,
> -Lee
> > Hi Tom,
> > Regards,
> > Jerome
> > <mailto:DynoMotion%40yahoogroups.com>, "Fouijar" <fouijar@> wrote:
> > > Hi Lee,
> > point to me.
> > think?
> > > Regards,
> > > Jerome
> > <mailto:DynoMotion%40yahoogroups.com>, Lee Studley <indigo_red@> wrote:
> > > > Hi Jerome,
> > 600ohm/24vdc and
> > setup.
> > can use
> > of the
> > > > part
> > > > -Lee
> > > > > Hi Lee,
> > necessary
> > > > > Regards,
> > > > > J.
> > > > > wrote:
Group: DynoMotion Message: 5117 From: Fouijar Date: 5/30/2012
Hi Lee,
I actually haven't found a real reason, but maybe as suggested the flyback diodes aren't making the job properly.
I actually use a supplementary optocoupled stage to drive the relays. I had those, that's why...
For the next steps, I'll follow your advice using the cascode setup.
I found that the chip is also existing in 8 pins,2 outputs versions.
This could be an advantageous replacement.
Jerome
> > Hi Jerome,
> > Thanks,
> > -Lee
> > > Hi Tom,
> > > Regards,
> > > Jerome
> > > > Hi Lee,
> > > point to me.
> > > think?
> > > > Regards,
> > > > Jerome
> > > > > Hi Jerome,
> > > 600ohm/24vdc and
> > > setup.
> > > can use
> > > of the
> > > > > part
> > > > > -Lee
> > > > > > Hi Lee,
> > > necessary
> > > > > > Regards,
> > > > > > J.
> > > > > > wrote:
Group: DynoMotion Message: 4885 From: Fouijar Date: 5/10/2012
Subject: Mosfet NDS9956A
I currently have the SW2, SW6 and SW7 outputs burned.
The SW2 died very soon after using the board, without any reason.
About the SW6, 7 it's something else.
I use them to drive a couple of relays with fly back diodes but I think the protection isn't working very well. This is not normal since it's coming from a major industrial manufacturer of automation components.
Anyway, this is too late to cry ;p.
So I plan to replace the two MOSFETS but are there some better alternatives?
I found some alternatives but I first prefer ask someone who knows that much better than me.
The end of the full story:
I was finishing my M6 program, I mean tuning the code to handle things securely. I wrote the last line and tested... first time OK!
A second one to check the tooling choice sequence in the opposite direction. And the last one before I get back to home... the SW7 burned ! :( WTF...
Nice story, isn't it?!
Jerome
Group: DynoMotion Message: 4886 From: studleylee Date: 5/10/2012
Hi Jerome,
Just replacing the fets might not solve your issue:
Could you post a drawing of your relay wiring to the files section.
information needed:
What **DC* voltage are you using for driving the relay coils?
What relay coil ohms/voltage?
What Flyback diodes and part number?
There has to be a reason why the 'power'(VA) used exceeded for the NDS9956A mosfets operating range. There's a SOA Figure 14. Maximum Safe Operating Area in the datasheet for that part. If your relays are large and needed >= 24VDC, you may need an intermediary relay or
a slaved device like either: a cascoded( spelling is correct) larger Nch device, or a larger P-channel device to pull the relay to a positive DC rail.
I can give you some examples, but need to know your voltages and currents being switched for the relays and loads.
-Lee
> Hi Tom,
Group: DynoMotion Message: 4889 From: Fouijar Date: 5/10/2012
Hi Tom, Lee,
Here's the link of the product's datasheet:
http://gfinder.findernet.com//assets/Series/41/S55EN.pdf
The Serial number is : 553390120040 (12V) (p.3) + protection module (p.9).
The wiring is made according to the datasheet.
I plan to use Optocoupled EMR relays to command the 3 phased relays, I already use this type of relay with the opto outs of Kanalog with great success. The brand is the same but the relays are used as interface modules:
http://gfinder.findernet.com//assets/Series/47/S38EN.pdf
If I understand, you suggest a kind of "Darlington pair"?
I'll try to find if I have a picture.
Thanks to remote control... I found one, lies in my folder.
Jerome
--- In DynoMotion@yahoogroups.com, "studleylee" <indigo_red@...> wrote:
> Hi Jerome,
> information needed:
> -Lee
> --- In DynoMotion@yahoogroups.com, "Fouijar" <fouijar@> wrote:
> > Hi Tom,
Group: DynoMotion Message: 4891 From: Tom Kerekes Date: 5/10/2012
Hi Jerome,
I don't know what could be blowing those FETS.  As you see those are rated for 30V 3.7A cont 15A peak and you are only driving then with 12V @ ~ 0.2A.
But I can't see where you specify the model number you are using.  The serial number doesn't help identify the device.
Those coils should be more than 12V/0.2A = 60 ohms.  I think you could check for the presence of a diode with an ohmmeter.
Group: DynoMotion Message: 4892 From: Fouijar Date: 5/10/2012
I made a mistake, the coils aren't 12V any more, I changed the relays to have 24V for every control system. Initially I had both 12 and 24V.
On page 5, the value of the coil R=600 ohms.
Maybe "breaking extra-current", for cars ignition coils it's about 20 times the nominal value. Difficult to model without good measures (ok, maybe Lenz's law).
I mentioned the number in my answer to Lee (#553390120040).
Correct # is: 553390240040
The serial number gives;
the model: 55.33
DC coil version:9
coil operating voltage: 024V (0040, not useful for this situation).
I already ordered 10 pieces from HK, more tests will tell us what's going on. Now I'll use Opto-out / opto-in controls.
J
> Hi Jerome,
> From: Fouijar <fouijar@...>
> Sent: Thursday, May 10, 2012 5:46 PM
> Subject: [DynoMotion] Re: Mosfet NDS9956A
> Hi Tom, Lee,
> Regards,
> Jerome
> --- In DynoMotion@yahoogroups.com, "studleylee" <indigo_red@> wrote:
> > Hi Jerome,
> > information needed:
> > -Lee
> > > Hi Tom,
Group: DynoMotion Message: 4894 From: studleylee Date: 5/10/2012
Hi Jerome,
I was looking over the datasheets and I agree with Tom that the diode
is suspect. Verify that the diode isn't popped-shorted, and cathode is pointing toward the 24vdc rail. So A1/13 is connected to the 24vdc rail, and A2/14 to the mosfet (sw to ground ). Another thing might be to add a diode across the mosfet( cathode toward the positive ) to protect against the drain bucking negative.
The dissapation goal is to never let the mosfet see over 30vdc( even if inductive coil spike), and that it never has to dissipate more then about 1 watt over more than seconds or minutes( unless there's alot of copper around the device )
The Cascode arrangement is similar, but not a gain like darlington. It allows the the lower mosfet operate well within it's SOA at a lower voltage. The upper device has its gate fixed to something like 5vdc( or 12vdc etc) and its source is switched to ground by the lower device. The lower device still has to handle the current, but now at a lower voltage Drain to source allowing less power dissapation. The upper device should be rated to handle the higher voltages.
By a really bizarre coincidence, this guy wrote it up well today! I learned of it years ago from a switching power supply guru.
http://electronicdesign.com/article/power/cascode-technology-enables-faster-switching-fequencies-losses-73901
> Hi Tom,
> the model: 55.33
> DC coil version:9
> Regards,
> J
> > Hi Jerome,
> > From: Fouijar <fouijar@>
> > Hi Tom, Lee,
> > Regards,
> > Jerome
> > > Hi Jerome,
> > > information needed:
> > > -Lee
> > > > Hi Tom,
Group: DynoMotion Message: 4895 From: studleylee Date: 5/10/2012
Also when I mean the mosfet dissipation, it's the (Rds * Id^2)
or the Vds * Ids that is being forced by the load condition. If the load current is causing the Rds to rise to a significant voltage, the SOA graph becomes critical over the time span this is occurring. This could occur if there was a overly large cap across the coil for example. Clear as mud huh :-)
> Hi Jerome,
> > Hi Tom,
> > the model: 55.33
> > DC coil version:9
> > Regards,
> > J
> > > Hi Jerome,
> > > Regards
> > > Hi Tom, Lee,
> > > Regards,
> > > Jerome
> > > > Hi Jerome,
> > > > information needed:
> > > > -Lee
> > > > > Hi Tom,
Group: DynoMotion Message: 4896 From: Martin Date: 5/11/2012
This all sounds like a bad flyback diode. You must have a snubber across any relay coil, as otherwise your drivers will see a big voltage spike. Double check that wiring with a meter.
The other possibility - too high a dI/dT - only happens with capacitor and filament loads. Those you fix with a tiny cap on the gate to slow the rise time.
> Hi Jerome,
> > Hi Tom,
> > the model: 55.33
> > DC coil version:9
> > Regards,
> > J
> > > Hi Jerome,
> > > Regards
> > > Hi Tom, Lee,
> > > Regards,
> > > Jerome
> > > > Hi Jerome,
> > > > information needed:
> > > > -Lee
> > > > > Hi Tom,
Group: DynoMotion Message: 4898 From: Fouijar Date: 5/11/2012
Hi Lee,
I checked the wiring and it's right as you mentioned. I did a test diode procedure and the diode seems to be working as it should.
Anyway, sometimes things aren't working like they should. As a security measure I'll replace the diodes, I bought more than necessary diodes in prevision of such case.
J.
> > Hi Jerome,
> > > Hi Tom,
> > > the model: 55.33
> > > DC coil version:9
> > > Regards,
> > > J
> > > > Hi Jerome,
> > > > Regards
> > > > TK
> > > > Hi Tom, Lee,
> > > > Regards,
> > > > Jerome
> > > > > Hi Jerome,
> > > > > information needed:
> > > > > -Lee
> > > > > > Hi Tom,
Group: DynoMotion Message: 4899 From: Fouijar Date: 5/11/2012
Hi Martin,
I checked the circuit and diodes, all ok. I think I'll use a temporary optocoupled circuit until I get the new Mosfets. Than I'll probably add caps.
Thanks for the suggestion.
J.
> time.
> > > Hi Jerome,
> > around the device )
> > > > Hi Tom,
> > maybe Lenz's law).
> > > > the model: 55.33
> > > > DC coil version:9
> > > > Regards,
> > > > J
> > > > > Hi Jerome,
> > @ ~ 0.2A.
> > > > > But I can't see where you specify the model number you are using.Â
> > > > > Regards
> > > > > TK
> > > > > Â
> > > > > Hi Tom, Lee,
> > (p.9).
> > > > > Regards,
> > > > > Jerome
> > > > > > Hi Jerome,
> > > > > > information needed:
> > positive DC rail.
> > > > > > -Lee
> > > > > > > Hi Tom,
> > opposite d
Group: DynoMotion Message: 4910 From: Lee Studley Date: 5/11/2012
Hi Jerome,
I simulated your setup using LTSpice and a inductor of 600ohm/24vdc and an estimated 1-to-4Henries.
Wow, without  a good *fast*, diode you can easily get a few Kvolts of inductive flyback on turnoff.
I'll post a writeup in the files section on my mentioned Cascode setup. The article I mentioned before doesn't cover the variations. You can use
I uploaded a good Zetex appnote in the files section under"Driving Relays". On page 2 I added a note about the surface mount version of the part
avalanche mfet ZVN4206AV that will work perfectly to complement the Kflop drive if a cascode is called for.  Its a tough part that can take
-Lee
Hi Lee,
J.
Group: DynoMotion Message: 4917 From: Fouijar Date: 5/11/2012
Hi Lee,
Jerome
> Hi Jerome,
> part
> -Lee
> > Hi Lee,
> > Regards,
> > J.
> > wrote:
