Group: DynoMotion Message: 1490 From: morgtod Date: 7/11/2011
Subject: More Tool changer questions
I've included my toolchanger.c below the questions.
1- I cannot make Reboot! work in console.
2- How do you make the g43's and other offsets automatic with the tool change?
3- How do you make KCNC wait for the toolchange to completely finish before it continues executing code?
4- Is it possible to make the printf's print to a popup screen instead of to console?
The code below is working nicely, I just need to work out a few kinks for fully automatic toolchanges.
Todd
#define toolarm 152
#define arm_retracted 136
#define arm_extended 137
#define low_drawbar 155
#define low_drawbar_sensor 138
#define CNTS_PER_INCH_X 127000
#define CNTS_PER_INCH_Y -127000
#define CNTS_PER_INCH_Z 127000
#define CNTS_PER_TOOL_A 1666.6666666666666666666
#define X 0
#define Y 1
#define Z 2
#define A 3
#define HIGH 1
#define LOW 0
void MoveX(double v); // define sub functions
void MoveY(double v);
void MoveZ(double v);
void MoveA(double v);
int WaitBit(int bit, int state);
int Tool = persist.UserData[9]; // value stored is actually a float
//printf("Tool Set to %d\n",tool); // print the desired speed
MoveZ(-3.750); //move table to tool change position
MoveX(0.0);
MoveY(-2.0);
SetBit(toolarm); // extend the tool arm
Delay_sec(1.0);
if (WaitBit(arm_extended,HIGH)) return; // check the tool arm extended sensor
printf("Tool Arm Extended \n");
MoveZ(-4.0); // good tool release height
Delay_sec(1.0);
SetBit(low_drawbar); // release the tool into the tray
Delay_sec(1.0);
if (WaitBit(low_drawbar_sensor,LOW)) return;
printf("Tool dropped \n"); // check tool dropped sensor
MoveZ(-.500); // move up to clear tool shanks
MoveA(Tool); // spin to new tool
MoveZ(-4.050); // lower to tool pickup level
ClearBit(low_drawbar); // pickup new tool
Delay_sec(1.0);
if (WaitBit(low_drawbar_sensor,HIGH)) return;
printf("Tool picked \n");
MoveZ(-3.75); // raise to clear tool tray
ClearBit(toolarm); // retract tool arm
if (WaitBit(arm_retracted,HIGH)) return; // check tool arm retractd sensor
printf("Tool arm Retracted\n");
// wait for a bit to go to a state
// return 0 if ok, 1 if timed ouut
double T0=Time_sec();
while (ReadBit(bit) != state)
WaitNextTimeSlice();
if (Time_sec() > T0 + 20.0)
DisableAxis(0);
DisableAxis(1);
DisableAxis(2);
return 1;
return 0;
Move(X,v * CNTS_PER_INCH_X);
while (!CheckDone(X));
Move(Y,v * CNTS_PER_INCH_Y);
while (!CheckDone(Y));
Move(Z,v * CNTS_PER_INCH_Z);
while (!CheckDone(Z));
Move(A,v * CNTS_PER_TOOL_A);
while (!CheckDone(A));
Group: DynoMotion Message: 1491 From: Tom Kerekes Date: 7/11/2011
Subject: Re: More Tool changer questions
Hi Todd,
#1 there are some cases where Reboot! from the console may not work.  You will need to cycle power in those cases.
#2 I'm not sure what you mean by automatic.  There is an example GCode file called ToolLengthOffsetsDemo.ngc that shows how to specify G43 and an H parameter to select parameters in the Tool Table.
#3  In the KMotionCNC ToolSetup M6 option select Exec/Wait/Sync rather than Execute Prog
#4 Not currently.  We will consider that for a future option
--- On Mon, 7/11/11, morgtod <todmorg@...> wrote:
Subject: [DynoMotion] More Tool changer questions
Date: Monday, July 11, 2011, 3:49 PM
Todd
#define toolarm 152
#define X 0
#define Y 1
#define Z 2
#define A 3
#define HIGH 1
#define LOW 0
MoveX(0.0);
MoveY(-2.0);
Delay_sec(1.0);
Delay_sec(1.0);
Delay_sec(1.0);
Delay_sec(1.0);
DisableAxis(0);
DisableAxis(1);
DisableAxis(2);
return 1;
return 0;
