Dear all,
I bought a Harmonic Drive gear with this motor attached to
it:
EC
60 flat with MILE Encoder and Protection Class IP 54
http://www.aviton.spb.ru/files/doc/pdf/maxon/ec_60_flat_en.pdf
I want to build a 4th axis from it.
The whole gear-motor-combination is a coordinated system,
meaning that its not easy to exchange the motor (which was
my initial plan: exchange for NEMA stepper motor).
So my question is: do you have an idea if this motor can
"easily" be connected to my KSTEP/KFLOP?
If this helps, I could easily only use it in stepper mode
(even prefer, since I guess its much less hassle).
The above linked PDF shows wiring information, I hope this
helps..
Thank you already in advance!
Kind regards,
Johannes
