Group: DynoMotion Message: 3365 From: himykabibble Date: 1/23/2012
Subject: MainStatus.AllAxisEnabled
Brad,
Are these working? I always read 0... I'm assuming this should be a bit-mapped array of enables, with axis 0 at bit 0, axis 1 at bit 1, etc.?
Ray L.
Group: DynoMotion Message: 3366 From: Brad Murry Date: 1/23/2012
Subject: Re: MainStatus.AllAxisEnabled
0 would indicate all are disabled I think.
-Brad
From: DynoMotion@yahoogroups.com [mailto:DynoMotion@yahoogroups.com] On Behalf Of himykabibble
Sent: Monday, January 23, 2012 12:03 PM
Subject: [DynoMotion] MainStatus.AllAxisEnabled
Brad,
Ray L.
Group: DynoMotion Message: 3369 From: himykabibble Date: 1/23/2012
Brad,
Yes, it would. But it doesn't matter whether they actually ARE enabled or not - it ALWAYS returns 0 for all axes, even when the machine is actually moving.
Ray L.
> -Brad
> Brad,
> Regards,
> Ray L.
Group: DynoMotion Message: 3371 From: Tom Kerekes Date: 1/23/2012
Brad/Ray,
BTW I think the off-by-one and the Enables not working is due to a bug here:
#define GET_VALUE(source_value, start, length) ((source_value >> (start - 1)) & ((1 << length) - 1))
in KMotion_dotNet_Interop.cpp  should be
#define GET_VALUE(source_value, start, length) ((source_value >> start) & ((1 << length) - 1))
Also the Enables come back individually returning the one requested not a word of bits.
Group: DynoMotion Message: 3376 From: himykabibble Date: 1/23/2012
Brad,
Have you posted MM source somewhere? I'd probably ask fewer stupid questions if I had some good examples to follow.... Trying to find things in KMotion, then guess how they map into dotNet is really tedious and time-consuming.
Ray L.
> Brad,
> Regards,
> Ray L.
> > -Brad
> > Brad,
> > Regards,
> > Ray L.
Group: DynoMotion Message: 3377 From: Brad Murry Date: 1/23/2012
Ray,
MM is no longer open-source, sorry.  You could use .net reflector to peek though.
The new HTML CNC controller is almost complete and the source will be completely open.
-Brad Murry
Sent: Monday, January 23, 2012 10:08 PM
Subject: [DynoMotion] Re: MainStatus.AllAxisEnabled
Brad,
Ray L.
> Brad,
> Regards,
> Ray L.
> > -Brad
> > Brad,
> > Regards,
> > Ray L.
Group: DynoMotion Message: 3392 From: Brad Murry Date: 1/24/2012
Hello Tom,
I believe I see the issue, does this mean you fixed the issue? Has anyone tested this?
-Brad
Group: DynoMotion Message: 3393 From: Tom Kerekes Date: 1/24/2012
Hi Brad,
I made the change on my end and tested the Enables and they seem to work ok.
But haven't given this to anyone.
