OK, here we go.
Uninstall does not sweep all folders/files, manual deleting is necessary. Shortcuts on desktop and quick menu as well manually deleted.
New install, new shortcuts = starts install process again! when trying to start from the new shortcuts.
Only start from within MM3 folder works OK after deleting file in Config/Layout, saving my layout does not help either.
So there is something that is not as it should be in the Install/Uninstall process.
Cheers
Bengt
ps KMotion is not started
--- In DynoMotion@yahoogroups.com, "Bengt Sjoelund" <cnc@...> wrote:
> Hi Brad,
> obviously the uninstall process is not working as it leaves traces of the old install. The shortcut on the desktop was also faulty, so I deleted those and start directly from the directory.
> I will try to uninstall the latest functioning MM3 and look for residual files after that and then install again.
> Cheers
> Bengt
> > It sounds like possibly there is an old shorcut in your program files?
> > Does the shortcut on your Desktop work?
> > Good news in getting past the fish scales though!
> > -Brad Murry
> > --- In DynoMotion@yahoogroups.com, "Bengt Sjoelund" <cnc@> wrote:
> > > Hi Brad,
> > > I have good news and bad news.
> > > Bad news is that the install must be faulty, the thing in Program menu/Machine Manager is pointing wrong so a new install starts up and is crippled as it does not find the .msi package.
> > > If I start up from C:/MM3/ with Machine manager.exe all is well and I get it working with all View Items.
> > > Hope this helps to get install to behave as it should, maybe this is foreign language OS playing tricks but should not.
> > > Cheers
> > > Bengt
> > > > That is terrible news.
> > > > There are a few people reporting they are able to use it without issue, I would like to know what is going wrong with your installation.
> > > > I just removed the install package from this site- it was a bit silly to keep both updated....
> > > > To be sure: You installed the latest update I made available last night yes?
> > > > You can try to delete your layout file, it is the xml inside the Config\LAYOUT folder and should be named MMLayout.xml
> > > > Try killing that and then toggling various View Items and see if anything pops into view.
> > > > (fingers crossed)
> > > > Brad Murry
> > > > > Hi Brad,
> > > > > Still no joy here, same old grey fishscale background.
> > > > > Cheers
> > > > > Bengt
> > > > > > Hello,
> > > > > > A new MM build is available here::
> > > > > > http://sourceforge.net/projects/cnctw/files/Machine%20Manager/Install/Machine%20Manager%20III.zip/download
> > > > > > There were some minor bug fixes and performance enhancements. Some of the GUI controls were updated for improved scalability and stretching. This should make it more usable on lower resolution displays.
> > > > > > -Brad Murry
