Good.then I think it might have to do with the dwell in mach. And I think my xml got corrupted some how in mach 3. After I replaced and reconfigured modbus, all appears to be working, but I have just started using as of about an hour ago.
One more, my encoders Ports and pins in mach are 0. Is that correct?
Hi Troy,
I don't think so. The Dynomotion Plugin takes over Ports #1 and #2.
Message: 5317 |
Date: 6/24/2012 |
| Subject: Re: Mach3 Spindle Modbus and KFLOP |
Hi Troy,
That should be ok. Encoder inputs are handled by KFLOP so there is no need to configure them in Mach3. I normally recommend setting pins to port0 as that is unused. But now you tell me that is for ModBus??
Message: 5319 |
Date: 6/24/2012 |
Yup. Found that out on one of the video tutorials on machs website.Should i change ports to something other than 0 while using KFLOP?
Troy
> Hi Troy,
> From: Troy D <brotroy7@...>
> Sent: Sunday, June 24, 2012 3:36 PM
> Subject: Re: [DynoMotion] Mach3 Spindle Modbus and KFLOP
> Troy
> Sent from Android
Message: 5321 |
Date: 6/24/2012 |
Hi Troy,
To be safe I would set them to any unused port so they don't interfere with anything. KFLOP only handles port #1 and #2. So using port #0 would cause no problem with KFLOP, but I don't know if it would cause Mach3 to do something to the modbus.
