Group: DynoMotion Message: 909 From: Allen Date: 2/9/2011
Subject: Mach3 IsMoving?
In the home program is there a way to let mach know there is motion? The DROs are moving but the actual the internal mach3 variable of "IsMoving" is not going true. Reason I ask is that I am using a brain in which several conditions must be meet to alert mach3 of a drive fault,etc.. and one of these conditions "IsMoving"?
Allen
Group: DynoMotion Message: 910 From: Tom Kerekes Date: 2/10/2011
Subject: Re: Mach3 IsMoving?
Hi Allen,
I think IsMoving is only set while Mach3 is executing G Code so it doesn't surprise me that it isn't set while KFlop is homing.
I can't think of a good solution.  Maybe you could describe exactly what you need to do.  One idea would be to have KFlop set a virtual bit while homing is active.
Group: DynoMotion Message: 911 From: Allen Date: 2/10/2011
I found a way around it, similiar to what you suggested. Using a UserLED I set to true while homing then to false when finished.
> Hi Allen,
> active.
> From: Allen <agray@...>
> Sent: Wed, February 9, 2011 1:33:06 PM
> Subject: [DynoMotion] Mach3 IsMoving?
> "IsMoving"?
> Thanks,
> Allen
