Hi Troy,
BTW I assume you are using Stepper Motors with a microstepping drive of 25 uSteps/step? Also I assume your Mach3 units are inches?
Actually you are correct. I forgot the Mach3 cont. jog speed is set as a percentage of the Max Motor Tuning Speed. Only the acceleration and Jerk of the Jogging are set in KMotion.
I don't see how KMotion Motion Profile Parameters would affect Mach3 GCode though.
The parameters are separate for a reason as they are two different motion techniques (2nd order vs 3rd order) that may possibly require significantly different settings. But it is confusing I'll admit. It makes more sense for KMotionCNC which does 3rd order Rapids and Jogs.
But hey it looks like your KMotion velocity is way too high at 4,000,000 steps/sec. This would be 12000RPM if your motors are 5000 steps/rev. Besides the max pulse rate of KFLOP is only 2,500,000 steps/sec and only to 250,000 steps/sec if you don't reduce the pulse length setting. That also comes out to almost 10,000ipm. I don't see how these settings can be working on the KMotion Step Response Screen unless you are only moving tiny distances where we can't get up to speed.
In Mach3 the max velocity of 200ipm is probably reasonable. That would be
200ipm / 60sec per min x 25000 steps/in = 83,333 steps/sec
But the acceleration of 200 in/sec3 is probably way too high. that is over 1/2 G
Try testing the motion in the KMotion Step Response Screen again using more reasonable values and with moves large enough to get up to full speed. There is also a plot mode that shows velocity. Then convert the numbers to Inches, seconds, minutes for Mach3.
The Init.c program also has problems. It is only configuring one axis channel 0, but then it enables axis channel 2, and then defines a 2 axes system of channels 0 and 1.
Hang in there - we'll get it eventually :}
--- On Mon, 8/29/11, Troy <groups@...> wrote:
From: Troy <groups@...> Subject: Re: [DynoMotion] MACH3 PLUGIN MOTOR SETUP To: DynoMotion@yahoogroups.com Date: Monday, August 29, 2011, 3:48 PM
Hmm, it seems like there is some interaction between the Mach3 motor tuning and the Kmotion paramaters. I am confused on"Jogging uses the independent axis settings in KMotion" because when I change mach3 motor tuning paramaters my jog speed changes. Likewise "Gcode uses the Mach3 Tuning paramters in units/min" when I change the kmotion paramaters, my gcode speeds change. So with Mach3 under gcode you can never get as smooth motor control as using just the kmotoion because mach3 is using the mach3 motor settings? Is there some way that both jogging and gcode can use the same motor settings? Currently my Mach 3 parameters are: steps per: 25075.82955 (roughly measured, I don't have the exact specs for my stages) velocity: 200 this can change depending on what the kmotion
paramaters are. acceleration: 200 I have my drives set to 5000 steps per revolution Thanks for your help. Troy bellow is my kmotion init file: #include "KMotionDef.h" // Defines axis 0 and 1 as simple steppers // enables them // sets them as an xy coordinate system for GCode int main() { ch0->InputMode=NO_INPUT_MODE; ch0->OutputMode=STEP_DIR_MODE; ch0->Vel=4000000; ch0->Accel=1000000; ch0->Jerk=10000000000; //trying to simulate 2nd order motion to match mach3 ch0->P=1; ch0->I=0; ch0->D=0; ch0->FFAccel=0; ch0->FFVel=0;
ch0->MaxI=200; ch0->MaxErr=200; ch0->MaxOutput=200; ch0->DeadBandGain=1; ch0->DeadBandRange=0; ch0->InputChan0=0; ch0->InputChan1=1; ch0->OutputChan0=0; ch0->OutputChan1=1; ch0->MasterAxis=-1; ch0->LimitSwitchOptions=0x0; ch0->InputGain0=1; ch0->InputGain1=1; ch0->InputOffset0=0; ch0->InputOffset1=0; ch0->OutputGain=1; ch0->OutputOffset=0; ch0->SlaveGain=1; ch0->BacklashMode=BACKLASH_OFF; ch0->BacklashAmount=0; ch0->BacklashRate=0;
ch0->invDistPerCycle=1; ch0->Lead=0; ch0->MaxFollowingError=1000000000; ch0->StepperAmplitude=250; ch0->iir[0].B0=1; ch0->iir[0].B1=0; ch0->iir[0].B2=0; ch0->iir[0].A1=0; ch0->iir[0].A2=0; ch0->iir[1].B0=1; ch0->iir[1].B1=0; ch0->iir[1].B2=0; ch0->iir[1].A1=0; ch0->iir[1].A2=0; ch0->iir[2].B0=1; ch0->iir[2].B1=0; ch0->iir[2].B2=0; ch0->iir[2].A1=0; ch0->iir[2].A2=0; EnableAxisDest(2,0); DefineCoordSystem(0,1,-1,-1);
return 0; }
Message: 1752 |
Date: 8/29/2011 |
| Subject: Re: MACH3 PLUGIN MOTOR SETUP |
Ok, I think I got it Mach 3 settings: Steps Per rev: 25075 Velocity (in/min): 300 = 125375 (steps/sec) Acceleration (in/min): 150=3761250 (steps/sec) Kflop settings: velocity (steps/sec) : 125375 Acceleration (steps/sec): 3761250 Jitter: 10000000000 // effectively disabled With using Jitter I was able to get much higher rapid speeds. velocity (steps/sec):200182 acceleration (steps/sec):4012000 jitter: 1.0e8 Just to see if I have it correct in my mind: with jitter on I can increase my jogging speed because mach3 is using the jitter variable but it will not increase my g00 rapid speeds because it is not using the 3rd order kmotion variables. If this were the case it seems it would be nice if mach3 could use the 3rd order variables for rapids the same as it does for jogging and use 2nd order for cutting. Minus that, things would be far less confusing and simple to set up if the mach3 plugin used the same 2nd order mach3 motor tuning variables for jogging the same way it does for cutting. It seems that is basically what I had to do: make the kmotion variables match the 2nd order variables in Mach3. Am I correct in that thinking or is there some reason I would want the jog speeds not to match the rapid speed. It also sounds like if I want things to move faster I need to use kmotioncnc, but then I don't get all the bells and whistles of mach3. Thanks for walking me through it all.
Message: 1756 |
Date: 8/29/2011 |
Hi Troy,
Sounds like we are basically on the same page.
2nd order motion has unlimited Jerk so that is the equivalent to slamming on the gas and slamming on the brakes in a car. It is "jerky". With 3rd order motion the gas and the brakes are applied more gradually (ramped) so there is less jerk and disturbance. Realize that it does take more time to stop if the brakes are applied gradually. However it is usually a net win to brake slowly but harder and come to a stop quicker with less shock and disturbance (that may cause a miss-step or other problem).
Mach3 just tells us (the plugin) to Jog at a certain speed so we are free to accelerate however we wish. But for Rapids Mach3 generates point by point motion that we have little choice other than to just execute as given.
You may set the higher performance Jerk limited settings in KMotion. The idea of unlimited Jerk was just to test motions of the type Mach would sometime do. It this case you should get the higher and smoother acceleration when Jogging in Mach3. Unfortunately you will still be limited to jog at 100% of the Motor Tuning Setting. It hadn't really occurred to me that the Rapid Speed and Jog Speed are tied together in Mach3. If you increased your Motor Tuning Speed so you could then Jog faster, then Rapids would likely stall. I do see there is a Rapid - FeedRate - Override on the Mach3 screen. So I suppose it would be possible to increase your Motor Tuning speed and then carefully always keep the Rapid Override at some value less than 100% to allow faster jogging. But it seems dangerous and awkward.
From: Troy <groups@...> Subject: Re: [DynoMotion] MACH3 PLUGIN MOTOR SETUP To: DynoMotion@yahoogroups.com Date: Monday, August 29, 2011, 6:46 PM
Mach 3 settings:
Kflop settings:
