Hi Tapio,
I assume you tried this with Stop
When Low checked or unchecked?
One remote possibility is
that noise is causing the signal to be both high and low (with a small duty
cycle so it may not be seen on the Digital I/O Screen).
Try running these two test routines to check for that and report
the results (test in the inactive state):
// Simple check for Glitch on Input Pin
while
(!ReadBit(1106)) ; // tight loop while input is low
printf("Input was high!!\n");
#include
"KMotionDef.h"
Pin
while (ReadBit(46)) ; // tight loop while
input is low
printf("Input was low!!\n");
Message: 11800 |
Date: 6/27/2015 |
| Subject: Re: Limit switch options?-SOLVED |
Hi Tapio,
Any Init file that runs at power up would indeed change parameters. But if it only changes them once and if you download new parameters from KMotion Screens (ie "Move") those should set new values. So I'm not sure why you see this effect unless your Init.c program is continuously executing in a loop or something. What is the program you are flashing in KFLOP? We don't recommend you have Launch on Power up programs as it can be confusing what was flashed in each board. It is usually better to leave KFLOP in a completely default state and just Initialize it from the PC with an Initialize Button.
Message: 11807 |
Date: 6/27/2015 |
It ends up the cause was me not seeing the obvious,
once again.
I have virtual bit stated based limit options in
for;; loop at the end of my init.c file. I have these so that hitting the limit
will trip mach reset but to allow jogging off the limit once limits are
deactivated.
Thank you once again,
Tapio
----- Original Message -----
Sent: Saturday, June 27, 2015 9:05
PM
Subject: Re: [DynoMotion] Limit switch
options?-SOLVED
Hi Tapio,
