Hi Ross,
start with your lathe profile, go into ports and pins in config.
set axis X and Z disable Y - copy your Y settings to Z SAVE
Restart Mach3 and you should be OK, are you using the lathe 1024.lset
screen? Cheers Bengt
--- In DynoMotion@yahoogroups.com,
"fermanz" <ferman@...> wrote:
> I have the lathe controls all working correctly but I have a bit
of a problem with Mach3 coming up with Dynomotion Status - Z axis
disabled.
> I must admit that when I first started Mach3, for this machine, I
created a profile and I was sure that was a turning profile but I got a
mill screen up and, as we were only looking to see if the DROs worked,
at that stage, I left it that way for the trial.
> The DROs worked perfectly on the X and Y axes, with the Y axes
reacting to the Z input.
> I changed the profile to a MachTurn and now Mach3 tells me that
the Z axis is disabled, although it is working okay.
> The DROs still seem to be reading as the had in the milling
interface, with the X axis DRO reading the Z axis handwheel movement.
> I can get no readout on the X axis DRO although both axes are
responding to their handwheel encoders correctly.
> Z is Channel 0 and X is Channel 1 and they work correctly in
KMotion.
> Is it possible that there is a Mach3 file that has remembered the
original mill format and just carried it over to the turning profile?
> If I delete both mill and turn xml files will they regenerate?
> Ross
