Group: DynoMotion Message: 12559 From: frank_19_88 Date: 12/2/2015
Subject: Konnect 32 inputs and 16 outputs visable on Mach3 screen.
 Hi TK,
Is it possible to make the 32 inputs and 16 outputs visible within a mach3 screen?
What I know so far:
I can use Mach3 OEMLED 1000-2250
Kflop code:
#define DROIN 7
#define DROOUT 8
double *pin = (double *)&persist.UserData[(DROIN -1)*2];
double *pout = (double *)&persist.UserData[(DROOUT-1)*2];
for(;;)
Delay_sec(2);
*pout = VirtualBitsEx[0]>>0;
printf("DROIN %d = %f DROOUT %d = %f\n",DROIN,*pin,DROOUT,*pout);
Mach3 code:
NotifyPlugins(18008) 'Read the result from KFLOP
x=GetOEMDRO(1008) 'Check the value passed back
Now I have a GetOEMDRO with an number representive to the In/Output data.
1 = input 0
2 = input 1
3 = input 0 & 1
How can I convert this number to the OEMLED's?
Or is there any better solution?
With kind regards,
Frank
Group: DynoMotion Message: 12562 From: TK Date: 12/2/2015
Subject: Re: Konnect 32 inputs and 16 outputs visable on Mach3 screen.
Hi Frank,
You might do something like:
Dim x As Integer
Dim Bit As Integer
x=32+256  ' set bit 5 and 8 as an example
Bit0 = GetBit(x,0)
Bit1 = GetBit(x,1)
Bit2 = GetBit(x,2)
Bit3 = GetBit(x,3)
Bit4 = GetBit(x,4)
Bit5 = GetBit(x,5)
Bit6 = GetBit(x,6)
Bit7 = GetBit(x,7)
Bit8 = GetBit(x,8)
Bit9 = GetBit(x,9)
On 12/2/2015 4:28 AM, frank_19_88@... [DynoMotion] wrote:
 Hi TK,
What I know so far:
Kflop code:
#define DROIN 7
#define DROOUT 8
for(;;)
Delay_sec(2);
Mach3 code:
1 = input 0
2 = input 1
3 = input 0 & 1
With kind regards,
Frank
Group: DynoMotion Message: 12565 From: TK Date: 12/3/2015
Hi Frank,
Oops.  Just realized I left out the GetBit Bunction:
Function GetBit(Value as Integer, Bit as Integer) as Boolean
    GetBit = (Value And (2^Bit)) <> 0
End Function
On 12/2/2015 1:19 PM, TK tk@... [DynoMotion] wrote:
Hi Frank,
Dim x As Integer
Dim Bit As Integer
Bit0 = GetBit(x,0)
Bit1 = GetBit(x,1)
Bit2 = GetBit(x,2)
Bit3 = GetBit(x,3)
Bit4 = GetBit(x,4)
Bit5 = GetBit(x,5)
Bit6 = GetBit(x,6)
Bit7 = GetBit(x,7)
Bit8 = GetBit(x,8)
Bit9 = GetBit(x,9)
 Hi TK,
What I know so far:
Kflop code:
#define DROIN 7
#define DROOUT 8
for(;;)
Delay_sec(2);
Mach3 code:
1 = input 0
2 = input 1
3 = input 0 & 1
With kind regards,
Frank
