Azed,
Run the Kmotion.exe program. Since
you have a KMotion board. Make sure the KFLOP option is not checked under
the option menu.
Open the Axis Screen. Does the
Position of Axis #0 change when you rotate the encoder?
You should also be able to see the two
input bits #0 and #1 change randomly on the Digital IO screen when you rotate
the encoder.
If all this works you can print the
encoder position from a C program with something like:
printf(“Encoder
0 = %f\n”,ch0->Position);
Message: 11 |
Date: 12/30/2008 |
| Subject: Re: Kmotion: how to read current position using c parogram |
Thanks TK for your reply I ve tried this itw orsk with the SnapAmp but not with the Kmotion. could it be that the default setup of the IO pins is digital output , not encoder?? thanks Azed
--- On Wed, 12/31/08, TK <tk@...> wrote:
From: TK <tk@...> Subject: RE: [DynoMotion] Kmotion: how to read current position using c parogram To: DynoMotion@yahoogroups.com Date: Wednesday, December 31, 2008, 2:25 PM
Azed,
the option menu.
the encoder.
printf(“Encoder
DynoMotion@yahoogro ups.com [mailto:DynoMotion@ yahoogroups. com] On Behalf Of azken98
Sent: Tuesday, December 30, 2008
9:29 PM
To: DynoMotion@yahoogro ups.com
Subject: [DynoMotion] Kmotion: how
I ve just started with KMotion, i ve KMotion board .
I ve connected the encoder channels A and B to the KMotion JP3 pins 15
and 16.
Now I want to test the Encoder position, any help?
thanks
Azed
Checked by AVG - http://www.avg. com
Version: 8.0.176 / Virus Database: 270.10.1/1868 - Release Date: 12/30/2008 12:06 PM
Message: 12 |
Date: 12/31/2008 |
Hi Azed,
All IO pins should default as
inputs. You can verify this on the Digital IO Screen.
Axis channel #0 defaults to read encoder
channel #0 which would be KMotion Encoder #0
Axis channel #4 defaults to read encoder
channel #4 which would be SnapAmp0 Encoder #0
Are you connecting a ground and +5V to the
encoder? (sorry had to ask).
SnapAmp has differential encoder inputs
(A, /A, B, /B) where KMotion only has single ended encoder inputs (A and B).
Do you understand the difference? For single ended just connect 2 of the
4 signal wires. Can you see the IO bits toggle on the Digital IO Screen?
Message: 13 |
Date: 1/2/2009 |
HI TK with Snap Amp its working fine, however with KMotion, some times i have to dbl click on the OUTPUTS before it works, I dont know why!. The other thing is that, with the Kflop and Kanalog configuration the encoder input channels can not tolerate "my" 5V encoder signals as stated in the spec, when i used 74ls245 buffer IC they also fine. Sure u can ask anything, I have a basic knowlege on this stuff. but as far as Dynomotion is concerned, I am new.
Have a nice day.
Azed
Thursday, January 1, 2009, 6:01 AM
Hi Azed,
DynoMotion@yahoogro ups.com [mailto:DynoMotion@ yahoogroups. com] On Behalf Of Azd Md
10:46 PM
Thanks TK
for your reply
encoder??
thanks
Azed
--- On Wed, 12/31/08, TK <tk@dynomotion. com>
parogram
Azed,
Run the Kmotion.exe program. Since you have a KMotion
board. Make sure the KFLOP option is not checked under the option menu.
Open the Axis Screen. Does the Position of Axis #0
You should also be able to see the two input bits #0 and #1
change randomly on the Digital IO screen when you rotate the encoder.
If all this works you can print the encoder position from a
printf(“Encoder 0 = %f\n”,ch0->Position);
Behalf Of azken98
9:29 PM
I ve
and 16.
thanks
Azed
Checked
12:06 PM
Version: 8.0.176 / Virus Database: 270.10.1/1870 - Release Date: 12/31/2008 8:44 AM
Message: 14 |
Date: 1/5/2009 |
Hi Azed,
Regarding Encoder connected to KMotion: A single click should change the IO to an output (not a double click). It's not a good idea to connect two outputs together as they will "fight" each other. Maybe your encoders have open collector outputs that require a pullup resistor?
Regarding Kanalog: The requirement is a differential signal. Kanalog has on board 400ohm termination resistors (SnapAmp does not). It may be that your encoder doesn't have enough current drive for the 400 ohm termination.
The way to diagnose these issues is to use a oscilloscope (or even a
voltmeter) and check what voltage levels you have before and after you make the connection.
I hope this helps TK
