Hi Alex,
Sorry to hear this. It sounds like the board was damaged. Did you make any changes? What do you have connected? What was happening when it failed?
All you can really do is disconnect everything from KFLOP and apply only +5V power. If the LEDS don't flash then the board is bad and you will need to send it to us for analysis and repair. It is important to find out what happened or it is likely to happen again.
If necessary send to:
c/o Tom Kerekes RMA#14
3532 Adamsville Ave
Calabasas, CA 91302
Message: 4044 |
Date: 2/22/2012 |
| Subject: Re: Kflop-Kanalog not working |
thanks for quick reply
i was in step of connecting inputs through JP12
thanks,
Alex
> Hi Alex,
> Dynomotion, Inc.
> 3532 Adamsville Ave
> Calabasas, CA 91302
> From: Alexander <customcnc@...>
> Sent: Wednesday, February 22, 2012 7:28 AM
> Subject: [DynoMotion] Kflop-Kanalog not working
> Hi!
> I'm retrofitting Cincinnati Arrow500
> after many hours of successful advancing
> suddenly kflop-Kanalog stopped ,
> I have no power LED's.
> tried PC power supply and USB(with J3). ,the same result.
> any suggestion?
> thanks in advance,
> Alex
Message: 4047 |
Date: 2/22/2012 |
do you think it's damaged kflop only or kanalog too ?
i need to send both cards?
meanwhile i ordered another set ,please send it ASAP
thank you very much,
Alex
> Hi Alex,
> Sorry to hear this.� It sounds like the board was damaged.� Did you make any changes?� What do you have connected?� What was happening when it failed?
> All you can really do is disconnect everything from KFLOP and apply only +5V power.� If the LEDS don't flash then the board is bad and you will need to send it to us for analysis and repair.� It is important to find out what happened or it is likely to happen again.
> Dynomotion, Inc.
> 3532 Adamsville Ave
> Calabasas, CA 91302
Message: 4048 |
Date: 2/22/2012 |
Hi Alex,
You might as well send both boards. Any possibility you shorted or miswired something on Kanalog JP12? That connector has all the supplies +15, -15, +5, 3.3, Analog signals, IO, etc... Shorts have a good chance of damage.
