Hi Bengt,
The cabling looks reasonable to me.
Sorry there are no PWM outputs available on JP7.
It might be possible to use a Step output on JP7 as a PWM. We helped a User do this in a case where he needed more than the available number of PWMS. There is an example called: StepAsPWM.c which shows how to do this. Of course the frequency becomes variable rather than at a fixed frequency like a normal PWM.
Message: 763 |
Date: 11/23/2010 |
| Subject: Re: Kflop to my lathe |
Thanks Tom,
I'll stick to JP6 for PWM as it is only 1 cable. More questions will come later on. Will try to take some pictures as well.
Cheers Bengt
> Hi Bengt,
> Sent: Mon, November 22, 2010 1:43:18 PM
> Subject: [DynoMotion] Kflop to my lathe
> Hi Tom,
> Just uploaded a pdf file in Files section. Can you have a look at this please
> and see if I am on the right path here.
> I have one old connectorbox that was connected to Mach/printerport and need to
> make use of this box so I have made a list of pins in printerport to pins on
> Kflop JP7 and JP6. Is this OK or is there a way I can connect PWM to JP7 as this
> would make it easier to connect via one flat cable to DSUB on the box. This
> connectorbox also has +5VDC and +12VDC PSU built in (old external CD driver box)
> Been offline for a while but now I will try to continue with my Milling machine
> as well as this lathe of mine.
> Cheers
> Bengt
