Very easy -click on the Tool Setup button on the main screen, then click on the Tool/Setup Files tab, and then change the selection under Main Dialog Face. Michael Rosenfield
Message: 6297 |
Date: 12/18/2012 |
| Subject: Re: KMotion screen |
Click Tool Setup (above Gcode to the right) then Tool/Setup Files tab. Main Dialog Face drop down menu.
Troy
--- In DynoMotion@yahoogroups.com, "b_adrian@..." wrote:
KMotion has the Main screen with three axes while in the help page it is presented with 6 axes. How can I change the existing 3 axes screen to 6 axes?
Adrian
Message: 6298 |
Date: 12/19/2012 |
It was very easy, indeed. Checking the Help page related to this issue I found that the Main Dialog Face can be altered by using Windows Resource Editor or Resource Hacker Editor. The question is where are located the KMotionCNC resource files? Is there a way to make the screens resizable? Thanks, Adrian From: DynoMotion@yahoogroups.com [mailto:DynoMotion@yahoogroups.com] On Behalf Of Michael Rosenfield Sent: Tuesday, December 18, 2012 10:43 AM To: dynomotion@yahoogroups.com Subject: RE: [DynoMotion] KMotion screen Very easy -click on the Tool Setup button on the main screen, then click on the Tool/Setup Files tab, and then change the selection under Main Dialog Face. Michael Rosenfield
To: DynoMotion@yahoogroups.com From: adrian@... Date: Tue, 18 Dec 2012 15:19:45 +0000 Subject: [DynoMotion] KMotion screen
Thanks, Adrian
Message: 6299 |
Date: 12/19/2012 |
Hi Adrian,
Windows binary Resources are embedded right in the executable (KMotionCNC.exe). It is somewhat complicated to do if you are not familiar with Windows and you wil need to re-do the changes for each new Version if you upgrade. You can make the screens any size you wish, but they won't be re-sizable without changing the KMotionCNC source code and re-compiling. Which screen type do you like. We may be able to make a resizable version for you.
Message: 6300 |
Date: 12/20/2012 |
I was asking for the resizable version because I have ordered a touch screen. When I will get it installed and tested I will ask for help if I will need it. Always is uplifting when you know that there is someone ready to jump and help you. Thank you, Adrian From: DynoMotion@yahoogroups.com [mailto:DynoMotion@yahoogroups.com] On Behalf Of Tom Kerekes Sent: Wednesday, December 19, 2012 6:31 PM To: DynoMotion@yahoogroups.com Subject: Re: [DynoMotion] KMotion screen Windows binary Resources are embedded right in the executable (KMotionCNC.exe). It is somewhat complicated to do if you are not familiar with Windows and you wil need to re-do the changes for each new Version if you upgrade. You can make the screens any size you wish, but they won't be re-sizable without changing the KMotionCNC source code and re-compiling. Which screen type do you like. We may be able to make a resizable version for you. It was very easy, indeed. Checking the Help page related to this issue I found that the Main Dialog Face can be altered by using Windows Resource Editor or Resource Hacker Editor. The question is where are located the KMotionCNC resource files? Is there a way to make the screens resizable? Very easy -click on the Tool Setup button on the main screen, then click on the Tool/Setup Files tab, and then change the selection under Main Dialog Face. Michael Rosenfield KMotion has the Main screen with three axes while in the help page it is presented with 6 axes. How can I change the existing 3 axes screen to 6 axes?
Thanks, Adrian
Message: 6303 |
Date: 12/21/2012 |
Out of interest, what is the resolution of your screen?
Al.
> Thank you,
> Adrian
> Hi Adrian,
> From: Adrian Balan <adrian@...>
> Sent: Wednesday, December 19, 2012 12:32 PM
> Thanks,
> Adrian
> Michael Rosenfield
> From: adrian@...
> Thanks,
> Adrian
Message: 6304 |
Date: 12/21/2012 |
It is a TFT 7”/800x480 USB powered. From: DynoMotion@yahoogroups.com [mailto:DynoMotion@yahoogroups.com] On Behalf Of oxforduniv Sent: Friday, December 21, 2012 10:29 AM To: DynoMotion@yahoogroups.com Subject: [DynoMotion] Re: KMotion screen Out of interest, what is the resolution of your screen? Al.
--- In DynoMotion@yahoogroups.com, "Adrian Balan" <adrian@...> wrote: > > I was asking for the resizable version because I have ordered a touch screen. When I will get it installed and tested I will ask for help if I will need it. > > Always is uplifting when you know that there is someone ready to jump and help you. > > > > Thank you, > > Adrian > > > > From: DynoMotion@yahoogroups.com [mailto:DynoMotion@yahoogroups.com] On Behalf Of Tom Kerekes > Sent: Wednesday, December 19, 2012 6:31 PM > To: DynoMotion@yahoogroups.com > Subject: Re: [DynoMotion] KMotion screen > > > > Hi Adrian, > > > > Windows binary Resources are embedded right in the executable (KMotionCNC.exe). It is somewhat complicated to do if you are not familiar with Windows and you wil need to re-do the changes for each new Version if you upgrade. You can make the screens any size you wish, but they won't be re-sizable without changing the KMotionCNC source code and re-compiling. Which screen type do you like. We may be able to make a resizable version for you. > > > > Regards > > TK > > > > From: Adrian Balan <adrian@...> > To: DynoMotion@yahoogroups.com > Sent: Wednesday, December 19, 2012 12:32 PM > Subject: RE: [DynoMotion] KMotion screen > > > > It was very easy, indeed. Checking the Help page related to this issue I found that the Main Dialog Face can be altered by using Windows Resource Editor or Resource Hacker Editor. The question is where are located the KMotionCNC resource files? Is there a way to make the screens resizable? > > > > Thanks, > > Adrian > > > > From: DynoMotion@yahoogroups.com [mailto:DynoMotion@yahoogroups.com] On Behalf Of Michael Rosenfield > Sent: Tuesday, December 18, 2012 10:43 AM > To: dynomotion@yahoogroups.com > Subject: RE: [DynoMotion] KMotion screen > > > > > > Very easy -click on the Tool Setup button on the main screen, then click on the Tool/Setup Files tab, and then change the selection under Main Dialog Face. > > Michael Rosenfield > > > To: DynoMotion@yahoogroups.com > From: adrian@... > Date: Tue, 18 Dec 2012 15:19:45 +0000 > Subject: [DynoMotion] KMotion screen > > > > KMotion has the Main screen with three axes while in the help page it is presented with 6 axes. How can I change the existing 3 axes screen to 6 axes? > > Thanks, > Adrian >
