Hi Stephen,
That would indicate some sort of invalid motion command or motion parameter. Please provide more information on how things are configured and what steps you are doing to cause this.
Are you seeing this on the Axis Screen? Cycle power on KFLOP to set everything to the default configuration. Then observe that the Axis Screen shows 0 for the Destination. Then observe what step causes it to become invalid.
Message: 5624 |
Date: 8/29/2012 |
| Subject: Re: KMotion Help |
When I open up the axis screen all read 0. The NAN shows when I try to move the axis via my machine manager program. You may now of Machine Manager. Designed by Brad Murry. When machine manager is started up, the program loads the motion parameters. I am able to clear the destination out to 0 by disabeling and enabeling the motor. When I try and run the Home C program it fails on the first of six axis and gives me the NAN on the destination.
This is the home c program.
// Homing program for a 3 axis System
// Limit switches are disabled and used as a home switch
// then they are re-enabled
#define XHOME 168
#define YHOME 169
#define ZHOME 170
void DoHome(int axis, float speed, int dir, int bit, int polarity, float sensoroffset);
DoHome( 0, // axis Laser #4
100, // speed steps/sec
1, // direction to home
171, // home input bit
1, // bit polarity (0 or 1) when tripped
10); // amount to move back inside (counts)
DoHome( 1, // Laser #3
-1, // direction to home
170, // home input bit
DoHome( 2, // Laser #2
169, // home input bit
DoHome( 3, // Laser #1
168, // home input bit
DoHome( 4, // Laser #6
173, // home input bit
DoHome( 5, // Laser #5
172, // home input bit
float oppdir = dir * -1;
EnableAxis(axis);
if(ReadBit(bit)==polarity)
Jog(axis, speed * oppdir); // start moving
while (ReadBit(bit) == polarity) ; // wait for switch (input #8) to change
Jog(axis,0); // stop
MoveRelAtVel(axis,sensoroffset * oppdir,speed);
Jog(axis, speed * dir); // start moving
while (ReadBit(bit) != polarity) ; // wait for switch (input #8) to change
while (!CheckDone(axis)) ;
EnableAxisDest(axis,0);
This is the c program that loads the paramaters on startup.
// Defines axis 0, 1, 2 as simple step dir TTL outputs for KSTEP
// enables them
// sets them as an xyz coordinate system for GCode
int main()
double T0, LastX=0, LastY=0, LastZ=0, Tau;
KStepPresent=TRUE; // enable KSTEP input multiplexing
//FPGA(STEP_PULSE_LENGTH_ADD) = 0x80 + 32; // set inverted and to 2us
FPGA(STEP_PULSE_LENGTH_ADD) = 0x80 + 63;
ch0->InputMode=NO_INPUT_MODE;
ch0->Vel=80000;
ch0->Accel=80000;
ch0->Jerk=4e+006;
ch0->P=0;
ch0->I=0.01;
ch0->D=0;
ch0->FFAccel=0;
ch0->FFVel=0;
ch0->MaxI=200;
ch0->MaxErr=1e+006;
ch0->MaxOutput=200;
ch0->DeadBandGain=1;
ch0->DeadBandRange=0;
ch0->InputChan0=0;
ch0->InputChan1=0;
ch0->OutputChan0=8;
ch0->OutputChan1=0;
ch0->MasterAxis=-1;
ch0->LimitSwitchOptions=0x0;
ch0->InputGain0=1;
ch0->InputGain1=1;
ch0->InputOffset0=0;
ch0->InputOffset1=0;
ch0->OutputGain=1;
ch0->OutputOffset=0;
ch0->SlaveGain=1;
ch0->BacklashAmount=0;
ch0->BacklashRate=0;
ch0->invDistPerCycle=1;
ch0->Lead=0;
ch0->StepperAmplitude=20;
ch0->iir[0].B0=1;
ch0->iir[0].B1=0;
ch0->iir[0].B2=0;
ch0->iir[0].A1=0;
ch0->iir[0].A2=0;
ch0->iir[1].B0=1;
ch0->iir[1].B1=0;
ch0->iir[1].B2=0;
ch0->iir[1].A1=0;
ch0->iir[1].A2=0;
ch0->iir[2].B0=0.000769;
ch0->iir[2].B1=0.001538;
ch0->iir[2].B2=0.000769;
ch0->iir[2].A1=1.92076;
ch0->iir[2].A2=-0.923833;
EnableAxisDest(0,0);
ch1->InputMode=NO_INPUT_MODE;
ch1->Vel=80000;
ch1->Accel=80000;
ch1->Jerk=4e+006;
ch1->P=0;
ch1->I=0.01;
ch1->D=0;
ch1->FFAccel=0;
ch1->FFVel=0;
ch1->MaxI=200;
ch1->MaxErr=1e+006;
ch1->MaxOutput=200;
ch1->DeadBandGain=1;
ch1->DeadBandRange=0;
ch1->InputChan0=0;
ch1->InputChan1=0;
ch1->OutputChan0=13;//9;
ch1->OutputChan1=0;
ch1->MasterAxis=-1;
ch1->LimitSwitchOptions=0x0;
ch1->InputGain0=1;
ch1->InputGain1=1;
ch1->InputOffset0=0;
ch1->InputOffset1=0;
ch1->OutputGain=1;
ch1->OutputOffset=0;
ch1->SlaveGain=1;
ch1->BacklashAmount=0;
ch1->BacklashRate=0;
ch1->invDistPerCycle=1;
ch1->Lead=0;
ch1->StepperAmplitude=20;
ch1->iir[0].B0=1;
ch1->iir[0].B1=0;
ch1->iir[0].B2=0;
ch1->iir[0].A1=0;
ch1->iir[0].A2=0;
ch1->iir[1].B0=1;
ch1->iir[1].B1=0;
ch1->iir[1].B2=0;
ch1->iir[1].A1=0;
ch1->iir[1].A2=0;
ch1->iir[2].B0=1;
ch1->iir[2].B1=0;
ch1->iir[2].B2=0;
ch1->iir[2].A1=0;
ch1->iir[2].A2=0;
EnableAxisDest(1,0);
ch2->InputMode=NO_INPUT_MODE;
ch2->Vel=80000;
ch2->Accel=80000;
ch2->Jerk=4e+006;
ch2->P=0;
ch2->I=0.01;
ch2->D=0;
ch2->FFAccel=0;
ch2->FFVel=0;
ch2->MaxI=200;
ch2->MaxErr=1e+006;
ch2->MaxOutput=200;
ch2->DeadBandGain=1;
ch2->DeadBandRange=0;
ch2->InputChan0=0;
ch2->InputChan1=0;
ch2->OutputChan0=10;
ch2->OutputChan1=0;
ch2->MasterAxis=-1;
ch2->LimitSwitchOptions=0x0;
ch2->InputGain0=1;
ch2->InputGain1=1;
ch2->InputOffset0=0;
ch2->InputOffset1=0;
ch2->OutputGain=-1;
ch2->OutputOffset=0;
ch2->SlaveGain=1;
ch2->BacklashAmount=0;
ch2->BacklashRate=0;
ch2->invDistPerCycle=1;
ch2->Lead=0;
ch2->MaxFollowingError=1000000000;
ch2->StepperAmplitude=20;
ch2->iir[0].B0=1;
ch2->iir[0].B1=0;
ch2->iir[0].B2=0;
ch2->iir[0].A1=0;
ch2->iir[0].A2=0;
ch2->iir[1].B0=1;
ch2->iir[1].B1=0;
ch2->iir[1].B2=0;
ch2->iir[1].A1=0;
ch2->iir[1].A2=0;
ch2->iir[2].B0=1;
ch2->iir[2].B1=0;
ch2->iir[2].B2=0;
ch2->iir[2].A1=0;
ch2->iir[2].A2=0;
EnableAxisDest(2,0);
ch3->InputMode=NO_INPUT_MODE;
ch3->OutputMode=STEP_DIR_MODE;
ch3->Vel=80000;
ch3->Accel=80000;
ch3->Jerk=4e+006;
ch3->P=0;
ch3->I=0.01;
ch3->D=0;
ch3->FFAccel=0;
ch3->FFVel=0;
ch3->MaxI=200;
ch3->MaxErr=1e+006;
ch3->MaxOutput=200;
ch3->DeadBandGain=1;
ch3->DeadBandRange=0;
ch3->InputChan0=0;
ch3->InputChan1=0;
ch3->OutputChan0=11;
ch3->OutputChan1=0;
ch3->MasterAxis=-1;
ch3->LimitSwitchOptions=0x0;
ch3->InputGain0=1;
ch3->InputGain1=1;
ch3->InputOffset0=0;
ch3->InputOffset1=0;
ch3->OutputGain=-1;
ch3->OutputOffset=0;
ch3->SlaveGain=1;
ch3->BacklashMode=BACKLASH_OFF;
ch3->BacklashAmount=0;
ch3->BacklashRate=0;
ch3->invDistPerCycle=1;
ch3->Lead=0;
ch3->MaxFollowingError=1000000000;
ch3->StepperAmplitude=20;
ch3->iir[0].B0=1;
ch3->iir[0].B1=0;
ch3->iir[0].B2=0;
ch3->iir[0].A1=0;
ch3->iir[0].A2=0;
ch3->iir[1].B0=1;
ch3->iir[1].B1=0;
ch3->iir[1].B2=0;
ch3->iir[1].A1=0;
ch3->iir[1].A2=0;
ch3->iir[2].B0=1;
ch3->iir[2].B1=0;
ch3->iir[2].B2=0;
ch3->iir[2].A1=0;
ch3->iir[2].A2=0;
EnableAxisDest(3,0);
ch4->InputMode=NO_INPUT_MODE;
ch4->OutputMode=STEP_DIR_MODE;
ch4->Vel=80000;
ch4->Accel=80000;
ch4->Jerk=4e+006;
ch4->P=0;
ch4->I=0.01;
ch4->D=0;
ch4->FFAccel=0;
ch4->FFVel=0;
ch4->MaxI=200;
ch4->MaxErr=1e+006;
ch4->MaxOutput=200;
ch4->DeadBandGain=1;
ch4->DeadBandRange=0;
ch4->InputChan0=0;
ch4->InputChan1=0;
ch4->OutputChan0=14;
ch4->OutputChan1=0;
ch4->MasterAxis=-1;
ch4->LimitSwitchOptions=0x0;
ch4->InputGain0=1;
ch4->InputGain1=1;
ch4->InputOffset0=0;
ch4->InputOffset1=0;
ch4->OutputGain=-1;
ch4->OutputOffset=0;
ch4->SlaveGain=1;
ch4->BacklashMode=BACKLASH_OFF;
ch4->BacklashAmount=0;
ch4->BacklashRate=0;
ch4->invDistPerCycle=1;
ch4->Lead=0;
ch4->MaxFollowingError=1000000000;
ch4->StepperAmplitude=20;
ch4->iir[0].B0=1;
ch4->iir[0].B1=0;
ch4->iir[0].B2=0;
ch4->iir[0].A1=0;
ch4->iir[0].A2=0;
ch4->iir[1].B0=1;
ch4->iir[1].B1=0;
ch4->iir[1].B2=0;
ch4->iir[1].A1=0;
ch4->iir[1].A2=0;
ch4->iir[2].B0=1;
ch4->iir[2].B1=0;
ch4->iir[2].B2=0;
ch4->iir[2].A1=0;
ch4->iir[2].A2=0;
EnableAxisDest(4,0);
ch5->InputMode=NO_INPUT_MODE;
ch5->OutputMode=STEP_DIR_MODE;
ch5->Vel=80000;
ch5->Accel=80000;
ch5->Jerk=4e+006;
ch5->P=0;
ch5->I=0.01;
ch5->D=0;
ch5->FFAccel=0;
ch5->FFVel=0;
ch5->MaxI=200;
ch5->MaxErr=1e+006;
ch5->MaxOutput=200;
ch5->DeadBandGain=1;
ch5->DeadBandRange=0;
ch5->InputChan0=0;
ch5->InputChan1=0;
ch5->OutputChan0=15;
ch5->OutputChan1=0;
ch5->MasterAxis=-1;
ch5->LimitSwitchOptions=0x0;
ch5->InputGain0=1;
ch5->InputGain1=1;
ch5->InputOffset0=0;
ch5->InputOffset1=0;
ch5->OutputGain=-1;
ch5->OutputOffset=0;
ch5->SlaveGain=1;
ch5->BacklashMode=BACKLASH_OFF;
ch5->BacklashAmount=0;
ch5->BacklashRate=0;
ch5->invDistPerCycle=1;
ch5->Lead=0;
ch5->MaxFollowingError=1000000000;
ch5->StepperAmplitude=20;
ch5->iir[0].B0=1;
ch5->iir[0].B1=0;
ch5->iir[0].B2=0;
ch5->iir[0].A1=0;
ch5->iir[0].A2=0;
ch5->iir[1].B0=1;
ch5->iir[1].B1=0;
ch5->iir[1].B2=0;
ch5->iir[1].A1=0;
ch5->iir[1].A2=0;
ch5->iir[2].B0=1;
ch5->iir[2].B1=0;
ch5->iir[2].B2=0;
ch5->iir[2].A1=0;
ch5->iir[2].A2=0;
EnableAxisDest(5,0);
DefineCoordSystem6(0,1,2,3,4,5);
SetBitDirection(45,1); // set Enable Signal as Output
SetBit(45); // Enable the amplifiers
return 0;
> Hi Stephen,
> From: stephen_lamarr <stephen_lamarr@...>
> Sent: Wednesday, August 29, 2012 12:25 PM
> Subject: [DynoMotion] KMotion Help
> I am getting a 1.#QNAN on my destination reading on my axis. Using stepper motors. I was told to post here for a resolution. I checked all of my accels; decels, velocity's, ect. all looks good. Not sure where to go from here. Any info would help.
Message: 5625 |
Date: 8/29/2012 |
Tau not defined:
int main()
> #include "KMotionDef.h"
> #define XHOME 168
> #define YHOME 169
> #define ZHOME 170
> main()
> EnableAxis(axis);
> // enables them
> int main()
> ch0->Vel=80000;
> ch0->Accel=80000;
> ch0->Jerk=4e+006;
> ch0->P=0;
> ch0->I=0.01;
> ch0->D=0;
> ch0->FFAccel=0;
> ch0->FFVel=0;
> ch0->MaxI=200;
> ch0->MaxErr=1e+006;
> ch0->MaxOutput=200;
> ch0->InputChan0=0;
> ch0->InputChan1=0;
> ch0->OutputChan0=8;
> ch0->OutputChan1=0;
> ch0->MasterAxis=-1;
> ch0->InputGain0=1;
> ch0->InputGain1=1;
> ch0->OutputGain=1;
> ch0->SlaveGain=1;
> ch0->BacklashMode=BACKLASH_OFF;
> ch0->Lead=0;
> ch0->MaxFollowingError=1000000000;
> ch0->iir[0].B0=1;
> ch0->iir[0].B1=0;
> ch0->iir[0].B2=0;
> ch0->iir[0].A1=0;
> ch0->iir[0].A2=0;
> ch0->iir[1].B0=1;
> ch0->iir[1].B1=0;
> ch0->iir[1].B2=0;
> ch0->iir[1].A1=0;
> ch0->iir[1].A2=0;
> ch1->Vel=80000;
> ch1->Accel=80000;
> ch1->Jerk=4e+006;
> ch1->P=0;
> ch1->I=0.01;
> ch1->D=0;
> ch1->FFAccel=0;
> ch1->FFVel=0;
> ch1->MaxI=200;
> ch1->MaxErr=1e+006;
> ch1->MaxOutput=200;
> ch1->InputChan0=0;
> ch1->InputChan1=0;
> ch1->OutputChan1=0;
> ch1->MasterAxis=-1;
> ch1->InputGain0=1;
> ch1->InputGain1=1;
> ch1->OutputGain=1;
> ch1->SlaveGain=1;
> ch1->BacklashMode=BACKLASH_OFF;
> ch1->Lead=0;
> ch1->MaxFollowingError=1000000000;
> ch1->iir[0].B0=1;
> ch1->iir[0].B1=0;
> ch1->iir[0].B2=0;
> ch1->iir[0].A1=0;
> ch1->iir[0].A2=0;
> ch1->iir[1].B0=1;
> ch1->iir[1].B1=0;
> ch1->iir[1].B2=0;
> ch1->iir[1].A1=0;
> ch1->iir[1].A2=0;
> ch1->iir[2].B0=1;
> ch1->iir[2].B1=0;
> ch1->iir[2].B2=0;
> ch1->iir[2].A1=0;
> ch1->iir[2].A2=0;
> ch2->Vel=80000;
> ch2->Accel=80000;
> ch2->Jerk=4e+006;
> ch2->P=0;
> ch2->I=0.01;
> ch2->D=0;
> ch2->FFAccel=0;
> ch2->FFVel=0;
> ch2->MaxI=200;
> ch2->MaxErr=1e+006;
> ch2->MaxOutput=200;
> ch2->InputChan0=0;
> ch2->InputChan1=0;
> ch2->OutputChan1=0;
> ch2->MasterAxis=-1;
> ch2->InputGain0=1;
> ch2->InputGain1=1;
> ch2->OutputGain=-1;
> ch2->SlaveGain=1;
> ch2->BacklashMode=BACKLASH_OFF;
> ch2->Lead=0;
> ch2->iir[0].B0=1;
> ch2->iir[0].B1=0;
> ch2->iir[0].B2=0;
> ch2->iir[0].A1=0;
> ch2->iir[0].A2=0;
> ch2->iir[1].B0=1;
> ch2->iir[1].B1=0;
> ch2->iir[1].B2=0;
> ch2->iir[1].A1=0;
> ch2->iir[1].A2=0;
> ch2->iir[2].B0=1;
> ch2->iir[2].B1=0;
> ch2->iir[2].B2=0;
> ch2->iir[2].A1=0;
> ch2->iir[2].A2=0;
> ch3->Vel=80000;
> ch3->Accel=80000;
> ch3->Jerk=4e+006;
> ch3->P=0;
> ch3->I=0.01;
> ch3->D=0;
> ch3->FFAccel=0;
> ch3->FFVel=0;
> ch3->MaxI=200;
> ch3->MaxErr=1e+006;
> ch3->MaxOutput=200;
> ch3->InputChan0=0;
> ch3->InputChan1=0;
> ch3->OutputChan1=0;
> ch3->MasterAxis=-1;
> ch3->InputGain0=1;
> ch3->InputGain1=1;
> ch3->OutputGain=-1;
> ch3->SlaveGain=1;
> ch3->Lead=0;
> ch3->iir[0].B0=1;
> ch3->iir[0].B1=0;
> ch3->iir[0].B2=0;
> ch3->iir[0].A1=0;
> ch3->iir[0].A2=0;
> ch3->iir[1].B0=1;
> ch3->iir[1].B1=0;
> ch3->iir[1].B2=0;
> ch3->iir[1].A1=0;
> ch3->iir[1].A2=0;
> ch3->iir[2].B0=1;
> ch3->iir[2].B1=0;
> ch3->iir[2].B2=0;
> ch3->iir[2].A1=0;
> ch3->iir[2].A2=0;
> ch4->Vel=80000;
> ch4->Accel=80000;
> ch4->Jerk=4e+006;
> ch4->P=0;
> ch4->I=0.01;
> ch4->D=0;
> ch4->FFAccel=0;
> ch4->FFVel=0;
> ch4->MaxI=200;
> ch4->MaxErr=1e+006;
> ch4->MaxOutput=200;
> ch4->InputChan0=0;
> ch4->InputChan1=0;
> ch4->OutputChan1=0;
> ch4->MasterAxis=-1;
> ch4->InputGain0=1;
> ch4->InputGain1=1;
> ch4->OutputGain=-1;
> ch4->SlaveGain=1;
> ch4->Lead=0;
> ch4->iir[0].B0=1;
> ch4->iir[0].B1=0;
> ch4->iir[0].B2=0;
> ch4->iir[0].A1=0;
> ch4->iir[0].A2=0;
> ch4->iir[1].B0=1;
> ch4->iir[1].B1=0;
> ch4->iir[1].B2=0;
> ch4->iir[1].A1=0;
> ch4->iir[1].A2=0;
> ch4->iir[2].B0=1;
> ch4->iir[2].B1=0;
> ch4->iir[2].B2=0;
> ch4->iir[2].A1=0;
> ch4->iir[2].A2=0;
> ch5->Vel=80000;
> ch5->Accel=80000;
> ch5->Jerk=4e+006;
> ch5->P=0;
> ch5->I=0.01;
> ch5->D=0;
> ch5->FFAccel=0;
> ch5->FFVel=0;
> ch5->MaxI=200;
> ch5->MaxErr=1e+006;
> ch5->MaxOutput=200;
> ch5->InputChan0=0;
> ch5->InputChan1=0;
> ch5->OutputChan1=0;
> ch5->MasterAxis=-1;
> ch5->InputGain0=1;
> ch5->InputGain1=1;
> ch5->OutputGain=-1;
> ch5->SlaveGain=1;
> ch5->Lead=0;
> ch5->iir[0].B0=1;
> ch5->iir[0].B1=0;
> ch5->iir[0].B2=0;
> ch5->iir[0].A1=0;
> ch5->iir[0].A2=0;
> ch5->iir[1].B0=1;
> ch5->iir[1].B1=0;
> ch5->iir[1].B2=0;
> ch5->iir[1].A1=0;
> ch5->iir[1].A2=0;
> ch5->iir[2].B0=1;
> ch5->iir[2].B1=0;
> ch5->iir[2].B2=0;
> ch5->iir[2].A1=0;
> ch5->iir[2].A2=0;
> return 0;
>> Hi Stephen,
>> Â
>> Â
>> Â
>> Regards
>> TK
>> Â
> Yahoo! Groups Links
Message: 5626 |
Date: 8/29/2012 |
No, I don't think I'm correct there. sorry
On 8/29/2012 2:22 PM, Lee Studley wrote:
> Tau not defined:
> int main()
>> #define XHOME 168
>> #define YHOME 169
>> #define ZHOME 170
>> main()
>> EnableAxis(axis);
>> // enables them
>> int main()
>> ch0->Vel=80000;
>> ch0->Accel=80000;
>> ch0->Jerk=4e+006;
>> ch0->P=0;
>> ch0->I=0.01;
>> ch0->D=0;
>> ch0->FFAccel=0;
>> ch0->FFVel=0;
>> ch0->MaxI=200;
>> ch0->MaxErr=1e+006;
>> ch0->MaxOutput=200;
>> ch0->InputChan0=0;
>> ch0->InputChan1=0;
>> ch0->OutputChan0=8;
>> ch0->OutputChan1=0;
>> ch0->MasterAxis=-1;
>> ch0->InputGain0=1;
>> ch0->InputGain1=1;
>> ch0->OutputGain=1;
>> ch0->SlaveGain=1;
>> ch0->Lead=0;
>> ch0->iir[0].B0=1;
>> ch0->iir[0].B1=0;
>> ch0->iir[0].B2=0;
>> ch0->iir[0].A1=0;
>> ch0->iir[0].A2=0;
>> ch0->iir[1].B0=1;
>> ch0->iir[1].B1=0;
>> ch0->iir[1].B2=0;
>> ch0->iir[1].A1=0;
>> ch0->iir[1].A2=0;
>> ch1->Vel=80000;
>> ch1->Accel=80000;
>> ch1->Jerk=4e+006;
>> ch1->P=0;
>> ch1->I=0.01;
>> ch1->D=0;
>> ch1->FFAccel=0;
>> ch1->FFVel=0;
>> ch1->MaxI=200;
>> ch1->MaxErr=1e+006;
>> ch1->MaxOutput=200;
>> ch1->InputChan0=0;
>> ch1->InputChan1=0;
>> ch1->OutputChan1=0;
>> ch1->MasterAxis=-1;
>> ch1->InputGain0=1;
>> ch1->InputGain1=1;
>> ch1->OutputGain=1;
>> ch1->SlaveGain=1;
>> ch1->Lead=0;
>> ch1->iir[0].B0=1;
>> ch1->iir[0].B1=0;
>> ch1->iir[0].B2=0;
>> ch1->iir[0].A1=0;
>> ch1->iir[0].A2=0;
>> ch1->iir[1].B0=1;
>> ch1->iir[1].B1=0;
>> ch1->iir[1].B2=0;
>> ch1->iir[1].A1=0;
>> ch1->iir[1].A2=0;
>> ch1->iir[2].B0=1;
>> ch1->iir[2].B1=0;
>> ch1->iir[2].B2=0;
>> ch1->iir[2].A1=0;
>> ch1->iir[2].A2=0;
>> ch2->Vel=80000;
>> ch2->Accel=80000;
>> ch2->Jerk=4e+006;
>> ch2->P=0;
>> ch2->I=0.01;
>> ch2->D=0;
>> ch2->FFAccel=0;
>> ch2->FFVel=0;
>> ch2->MaxI=200;
>> ch2->MaxErr=1e+006;
>> ch2->MaxOutput=200;
>> ch2->InputChan0=0;
>> ch2->InputChan1=0;
>> ch2->OutputChan1=0;
>> ch2->MasterAxis=-1;
>> ch2->InputGain0=1;
>> ch2->InputGain1=1;
>> ch2->OutputGain=-1;
>> ch2->SlaveGain=1;
>> ch2->Lead=0;
>> ch2->iir[0].B0=1;
>> ch2->iir[0].B1=0;
>> ch2->iir[0].B2=0;
>> ch2->iir[0].A1=0;
>> ch2->iir[0].A2=0;
>> ch2->iir[1].B0=1;
>> ch2->iir[1].B1=0;
>> ch2->iir[1].B2=0;
>> ch2->iir[1].A1=0;
>> ch2->iir[1].A2=0;
>> ch2->iir[2].B0=1;
>> ch2->iir[2].B1=0;
>> ch2->iir[2].B2=0;
>> ch2->iir[2].A1=0;
>> ch2->iir[2].A2=0;
>> ch3->Vel=80000;
>> ch3->Accel=80000;
>> ch3->Jerk=4e+006;
>> ch3->P=0;
>> ch3->I=0.01;
>> ch3->D=0;
>> ch3->FFAccel=0;
>> ch3->FFVel=0;
>> ch3->MaxI=200;
>> ch3->MaxErr=1e+006;
>> ch3->MaxOutput=200;
>> ch3->InputChan0=0;
>> ch3->InputChan1=0;
>> ch3->OutputChan1=0;
>> ch3->MasterAxis=-1;
>> ch3->InputGain0=1;
>> ch3->InputGain1=1;
>> ch3->OutputGain=-1;
>> ch3->SlaveGain=1;
>> ch3->Lead=0;
>> ch3->iir[0].B0=1;
>> ch3->iir[0].B1=0;
>> ch3->iir[0].B2=0;
>> ch3->iir[0].A1=0;
>> ch3->iir[0].A2=0;
>> ch3->iir[1].B0=1;
>> ch3->iir[1].B1=0;
>> ch3->iir[1].B2=0;
>> ch3->iir[1].A1=0;
>> ch3->iir[1].A2=0;
>> ch3->iir[2].B0=1;
>> ch3->iir[2].B1=0;
>> ch3->iir[2].B2=0;
>> ch3->iir[2].A1=0;
>> ch3->iir[2].A2=0;
>> ch4->Vel=80000;
>> ch4->Accel=80000;
>> ch4->Jerk=4e+006;
>> ch4->P=0;
>> ch4->I=0.01;
>> ch4->D=0;
>> ch4->FFAccel=0;
>> ch4->FFVel=0;
>> ch4->MaxI=200;
>> ch4->MaxErr=1e+006;
>> ch4->MaxOutput=200;
>> ch4->InputChan0=0;
>> ch4->InputChan1=0;
>> ch4->OutputChan1=0;
>> ch4->MasterAxis=-1;
>> ch4->InputGain0=1;
>> ch4->InputGain1=1;
>> ch4->OutputGain=-1;
>> ch4->SlaveGain=1;
>> ch4->Lead=0;
>> ch4->iir[0].B0=1;
>> ch4->iir[0].B1=0;
>> ch4->iir[0].B2=0;
>> ch4->iir[0].A1=0;
>> ch4->iir[0].A2=0;
>> ch4->iir[1].B0=1;
>> ch4->iir[1].B1=0;
>> ch4->iir[1].B2=0;
>> ch4->iir[1].A1=0;
>> ch4->iir[1].A2=0;
>> ch4->iir[2].B0=1;
>> ch4->iir[2].B1=0;
>> ch4->iir[2].B2=0;
>> ch4->iir[2].A1=0;
>> ch4->iir[2].A2=0;
>> ch5->Vel=80000;
>> ch5->Accel=80000;
>> ch5->Jerk=4e+006;
>> ch5->P=0;
>> ch5->I=0.01;
>> ch5->D=0;
>> ch5->FFAccel=0;
>> ch5->FFVel=0;
>> ch5->MaxI=200;
>> ch5->MaxErr=1e+006;
>> ch5->MaxOutput=200;
>> ch5->InputChan0=0;
>> ch5->InputChan1=0;
>> ch5->OutputChan1=0;
>> ch5->MasterAxis=-1;
>> ch5->InputGain0=1;
>> ch5->InputGain1=1;
>> ch5->OutputGain=-1;
>> ch5->SlaveGain=1;
>> ch5->Lead=0;
>> ch5->iir[0].B0=1;
>> ch5->iir[0].B1=0;
>> ch5->iir[0].B2=0;
>> ch5->iir[0].A1=0;
>> ch5->iir[0].A2=0;
>> ch5->iir[1].B0=1;
>> ch5->iir[1].B1=0;
>> ch5->iir[1].B2=0;
>> ch5->iir[1].A1=0;
>> ch5->iir[1].A2=0;
>> ch5->iir[2].B0=1;
>> ch5->iir[2].B1=0;
>> ch5->iir[2].B2=0;
>> ch5->iir[2].A1=0;
>> ch5->iir[2].A2=0;
>> return 0;
>>> Hi Stephen,
>>> Â
>>> Â
>>> Â
>>> Regards
>>> TK
>>> Â
>> Yahoo! Groups Links
> Yahoo! Groups Links
Message: 5627 |
Date: 8/29/2012 |
What happens when you leave MM out of the equation?
Power cycle the kflop, start Kmotion, run unit file and then try homing. If you get errors, we know it is a bad c file setting, otherwise it will be a configuration issue with MM. Also, make sure to use latest Kmotion.dll's
-Brad Murry
stephen_lamarr
Sent:
8/29/2012 12:59 PM
To:
Subject:
[DynoMotion] Re: KMotion Help
#define XHOME 168
#define YHOME 169
#define ZHOME 170
EnableAxis(axis);
// enables them
int main()
ch0->Vel=80000;
ch0->Accel=80000;
ch0->Jerk=4e+006;
ch0->P=0;
ch0->I=0.01;
ch0->D=0;
ch0->FFAccel=0;
ch0->FFVel=0;
ch0->MaxI=200;
ch0->MaxErr=1e+006;
ch0->MaxOutput=200;
ch0->InputChan0=0;
ch0->InputChan1=0;
ch0->OutputChan0=8;
ch0->OutputChan1=0;
ch0->MasterAxis=-1;
ch0->InputGain0=1;
ch0->InputGain1=1;
ch0->OutputGain=1;
ch0->SlaveGain=1;
ch0->Lead=0;
ch0->iir[0].B0=1;
ch0->iir[0].B1=0;
ch0->iir[0].B2=0;
ch0->iir[0].A1=0;
ch0->iir[0].A2=0;
ch0->iir[1].B0=1;
ch0->iir[1].B1=0;
ch0->iir[1].B2=0;
ch0->iir[1].A1=0;
ch0->iir[1].A2=0;
ch1->Vel=80000;
ch1->Accel=80000;
ch1->Jerk=4e+006;
ch1->P=0;
ch1->I=0.01;
ch1->D=0;
ch1->FFAccel=0;
ch1->FFVel=0;
ch1->MaxI=200;
ch1->MaxErr=1e+006;
ch1->MaxOutput=200;
ch1->InputChan0=0;
ch1->InputChan1=0;
ch1->OutputChan1=0;
ch1->MasterAxis=-1;
ch1->InputGain0=1;
ch1->InputGain1=1;
ch1->OutputGain=1;
ch1->SlaveGain=1;
ch1->Lead=0;
ch1->iir[0].B0=1;
ch1->iir[0].B1=0;
ch1->iir[0].B2=0;
ch1->iir[0].A1=0;
ch1->iir[0].A2=0;
ch1->iir[1].B0=1;
ch1->iir[1].B1=0;
ch1->iir[1].B2=0;
ch1->iir[1].A1=0;
ch1->iir[1].A2=0;
ch1->iir[2].B0=1;
ch1->iir[2].B1=0;
ch1->iir[2].B2=0;
ch1->iir[2].A1=0;
ch1->iir[2].A2=0;
ch2->Vel=80000;
ch2->Accel=80000;
ch2->Jerk=4e+006;
ch2->P=0;
ch2->I=0.01;
ch2->D=0;
ch2->FFAccel=0;
ch2->FFVel=0;
ch2->MaxI=200;
ch2->MaxErr=1e+006;
ch2->MaxOutput=200;
ch2->InputChan0=0;
ch2->InputChan1=0;
ch2->OutputChan1=0;
ch2->MasterAxis=-1;
ch2->InputGain0=1;
ch2->InputGain1=1;
ch2->OutputGain=-1;
ch2->SlaveGain=1;
ch2->Lead=0;
ch2->iir[0].B0=1;
ch2->iir[0].B1=0;
ch2->iir[0].B2=0;
ch2->iir[0].A1=0;
ch2->iir[0].A2=0;
ch2->iir[1].B0=1;
ch2->iir[1].B1=0;
ch2->iir[1].B2=0;
ch2->iir[1].A1=0;
ch2->iir[1].A2=0;
ch2->iir[2].B0=1;
ch2->iir[2].B1=0;
ch2->iir[2].B2=0;
ch2->iir[2].A1=0;
ch2->iir[2].A2=0;
ch3->Vel=80000;
ch3->Accel=80000;
ch3->Jerk=4e+006;
ch3->P=0;
ch3->I=0.01;
ch3->D=0;
ch3->FFAccel=0;
ch3->FFVel=0;
ch3->MaxI=200;
ch3->MaxErr=1e+006;
ch3->MaxOutput=200;
ch3->InputChan0=0;
ch3->InputChan1=0;
ch3->OutputChan1=0;
ch3->MasterAxis=-1;
ch3->InputGain0=1;
ch3->InputGain1=1;
ch3->OutputGain=-1;
ch3->SlaveGain=1;
ch3->Lead=0;
ch3->iir[0].B0=1;
ch3->iir[0].B1=0;
ch3->iir[0].B2=0;
ch3->iir[0].A1=0;
ch3->iir[0].A2=0;
ch3->iir[1].B0=1;
ch3->iir[1].B1=0;
ch3->iir[1].B2=0;
ch3->iir[1].A1=0;
ch3->iir[1].A2=0;
ch3->iir[2].B0=1;
ch3->iir[2].B1=0;
ch3->iir[2].B2=0;
ch3->iir[2].A1=0;
ch3->iir[2].A2=0;
ch4->Vel=80000;
ch4->Accel=80000;
ch4->Jerk=4e+006;
ch4->P=0;
ch4->I=0.01;
ch4->D=0;
ch4->FFAccel=0;
ch4->FFVel=0;
ch4->MaxI=200;
ch4->MaxErr=1e+006;
ch4->MaxOutput=200;
ch4->InputChan0=0;
ch4->InputChan1=0;
ch4->OutputChan1=0;
ch4->MasterAxis=-1;
ch4->InputGain0=1;
ch4->InputGain1=1;
ch4->OutputGain=-1;
ch4->SlaveGain=1;
ch4->Lead=0;
ch4->iir[0].B0=1;
ch4->iir[0].B1=0;
ch4->iir[0].B2=0;
ch4->iir[0].A1=0;
ch4->iir[0].A2=0;
ch4->iir[1].B0=1;
ch4->iir[1].B1=0;
ch4->iir[1].B2=0;
ch4->iir[1].A1=0;
ch4->iir[1].A2=0;
ch4->iir[2].B0=1;
ch4->iir[2].B1=0;
ch4->iir[2].B2=0;
ch4->iir[2].A1=0;
ch4->iir[2].A2=0;
ch5->Vel=80000;
ch5->Accel=80000;
ch5->Jerk=4e+006;
ch5->P=0;
ch5->I=0.01;
ch5->D=0;
ch5->FFAccel=0;
ch5->FFVel=0;
ch5->MaxI=200;
ch5->MaxErr=1e+006;
ch5->MaxOutput=200;
ch5->InputChan0=0;
ch5->InputChan1=0;
ch5->OutputChan1=0;
ch5->MasterAxis=-1;
ch5->InputGain0=1;
ch5->InputGain1=1;
ch5->OutputGain=-1;
ch5->SlaveGain=1;
ch5->Lead=0;
ch5->iir[0].B0=1;
ch5->iir[0].B1=0;
ch5->iir[0].B2=0;
ch5->iir[0].A1=0;
ch5->iir[0].A2=0;
ch5->iir[1].B0=1;
ch5->iir[1].B1=0;
ch5->iir[1].B2=0;
ch5->iir[1].A1=0;
ch5->iir[1].A2=0;
ch5->iir[2].B0=1;
ch5->iir[2].B1=0;
ch5->iir[2].B2=0;
ch5->iir[2].A1=0;
ch5->iir[2].A2=0;
return 0;
> Hi Stephen,
Message: 5628 |
Date: 8/29/2012 |
Hi Stephan,
Please do as Brad suggests as I don't see anything wrong with the programs and they work ok for me.
If the C programs are Compiled/Linked using a different DSPKFLOP.out file than what is flashed in KFLOP then memory addresses will be incorrect and unpredictable results.
The location of the KMotionDLL.dll is used to find the DSPKFLOP.out file to be used (they are within the same directory)
