Group: DynoMotion Message: 14796 From: Sam Marrocco Date: 5/21/2017
Subject: KFlop 4.34i and Visual studio compatibilities....
Is the newest KFlop 4.34i software still compatible with Visual Studio
2012 using the dotnet framework 4.7?
Group: DynoMotion Message: 14797 From: Tom Kerekes Date: 5/22/2017
Subject: Re: KFlop 4.34i and Visual studio compatibilities....
Versions 4.34a - 4.34i are built with VS2015 Community.  Prior Versions are VS2008 which in most cases could be upgraded to VS2012 without too much difficulty.  Id suggest switching to VS2015.
V4.34i targets .NET 4.5.  .NET should be backward compatible so .NET 4.7 should be compatible.
KMotionCNC, KMotion, and the C++ examples don't use .NET
Group: DynoMotion Message: 14800 From: Sam Marrocco Date: 5/22/2017
Thanks. The reason I ask is this:
I've attempted to update my current working app from vb.net/vs 2012/dotnet framework 4.5/KMotion 433q
to
vb.net/vs2012/dotnet framework 4.7/KMotion 434i.
As I usually do with an update of the KFlop, I've updated the firmware of the KFlop and included the newest versions of these files with my application:
DSP_KFLOP (everything in the folder)
KMotion.exe
KMotion_dotNet.dll
KMotion_dotNet_interop.dll
KMotionDLL.dll
KMotionServer.exe
GCodeInterpreter.dll
TCC67.exe
emc.var
....placing these into the debug folder of my updated project.
My app starts, then stops when I attempt
Public WithEvents ThisController As New KM_Controller,
failing with the error:
An exception of type 'KMotion_dotNet.DMException' occurred in KMotion_dotNet.dll but was not handled in user code
Looking into the details of the exception reveals:
{"Unable to load DLL 'KMotion_dotNet_Interop.dll': The specified module could not be found. (Exception from HRESULT: 0x8007007E)"}
Could it be a new dependency of the KMotion_dotNet.dll introduced since KMotion v433q?
Group: DynoMotion Message: 14801 From: Tom Kerekes Date: 5/22/2017
I don't recall any new dependencies.  Do the Dynomotion .NET Apps run?
to
KMotion.exe
KMotion_dotNet.dll
KMotionDLL.dll
KMotionServer.exe
TCC67.exe
emc.var
Group: DynoMotion Message: 14802 From: Sam Marrocco Date: 5/22/2017
All of the \release apps seems to run fine.
However, none of the \debug versions seem to run.
Debug\KMotionCNC.exe returns dialogs with:
"......can't start because mfc140d.dll is missing from your computer...."
".....can't start because VCRUNTIME140D.dll is missing ....."
".....can't start because ucrtbased.dll is missing......"
as do several other \debug versions of the apps.
JoggerNET.exe fails with "Unable to load DLL 'KMViaVB": The specified module could not be found.
I vaguely recall this being an issue in a distant previous version, something to do with the installations of debugging libraries with certain versions of Visual Studio.....? Does that sound familiar?
to
KMotion.exe
KMotion_dotNet.dll
KMotionDLL.dll
KMotionServer.exe
TCC67.exe
emc.var
Group: DynoMotion Message: 14803 From: Tom Kerekes Date: 5/22/2017
Those are VS2015 Debug libraries.  To run VS2015 debug code you need to have VS2015 installed.
When trying to run your app what version of VS are you using?  Are you trying to run debug code or release code?  Are you re-compiling your code against the newer libraries?
to
KMotion.exe
KMotion_dotNet.dll
KMotionDLL.dll
KMotionServer.exe
TCC67.exe
emc.var
Group: DynoMotion Message: 14804 From: Sam Marrocco Date: 5/22/2017
I'm using VS2012 and recompiling  my code in debug mode with dotnet framework 4.7 using the KMotion 434i release libraries. I'm guessing that the debug versions of the Kmotion libraries must be requiring the vs2015 debugging libraries, which would suggest that I cannot use the 434i release with vb2012? If so, would this be cured moving to vs2017?
to
KMotion.exe
KMotion_dotNet.dll
KMotionDLL.dll
KMotionServer.exe
TCC67.exe
emc.var
Group: DynoMotion Message: 14805 From: Tom Kerekes Date: 5/22/2017
I'd recommend trying VS2015 to eliminate that issue.
to
KMotion.exe
KMotion_dotNet.dll
KMotionDLL.dll
KMotionServer.exe
TCC67.exe
emc.var
Group: DynoMotion Message: 14812 From: Sam Marrocco Date: 5/23/2017
I've installed/upgraded to VS2015 (from VS2012).
This cures the issue with the debug libraries. I also installed VS2017 and promoted my code to that. The code still runs fine without the issue. I was not able to test a VS2017 installation *without* VS2015 installed.
I'd like to suggest adding some documentation somewhere to indicate that v434i has a prerequisite of VS2015 or higher for dotnet development if it doesn't already exist.
Thanks for the help!
to
KMotion.exe
KMotion_dotNet.dll
KMotionDLL.dll
KMotionServer.exe
TCC67.exe
emc.var
