Group: DynoMotion Message: 11832 From: lmp582002 Date: 6/30/2015
Subject: KFlop - Flashed Program
I have read on many of your posts that it is better not to flash C programs into the KFlop board. Is there a way to load the INIT file from a push button with a blank board?
I am currently having KMotionCNC boot up with the computer and it is hidden in the background. By loading the INIT file on the board the operator can use the machine without knowing KMotionCNC is even running.
Scott
Group: DynoMotion Message: 11853 From: Tom Kerekes Date: 7/2/2015
Subject: Re: KFlop - Flashed Program
Hi Scott,
The later Versions offer an option to launch an Action on Program Startup.  You might make use of that.
If you need to Flash an Initialization Program into KFLOP you may do so.  It only means that you must keep track of what was Flashed into each board and complicates matters when replacing boards, swapping around boards, upgrading Firmware and Versions, etc...
