Group: DynoMotion Message: 12321 From: dms.davidstevenson Date: 9/26/2015
Subject: Jog Speed System Variable
I have a c program within which I would like to temporarily change the Joystick/Jog jog speed settings from the KMotionCNC  Trajectory Planner screen.
Could I bother you to tell me which system variable the X and Y jog speeds relate to?
Thank you,
David.
Group: DynoMotion Message: 12322 From: Tom Kerekes Date: 9/26/2015
Subject: Re: Jog Speed System Variable
Hi David,
Not sure what you mean by "Joystick"?  Do you mean Gamepad?
Not sure what you mean by Temporarily?
I can't think of an easy way to do that from KFLOP C Code.
Jogging is all handled by KMotionCNC in the Tool Setup : Trajectory Planner Parameters running on the PC.
A related variable on the PC is: m_JogSlowPercent but new KFLOP to PC Commands would be needed to set it in the PC and make use of it.
Jog Speeds gets embedded in all the buttons when they are created so if changed the screen needs to be re-created with:
DestroyWindow();
Create(IDD_KMOTIONCNC_0_ORIGINAL+m_DialogFace); // put up the real main window
You might read the documents created by Troy here:
Specifically the:
Adding Jog Percent Cell to Main Dialog Face.pdf
Group: DynoMotion Message: 12323 From: David Stevenson Date: 9/26/2015
The Trajectory Planner screen in KMCNC has boxes where we set the jog speed settings for the various axis. The box is labeled Joystick/Jog. For most aspects of my usage those setting are great. I have an application where I would like to reduce that number while something is done, because the gamepad motion is too fast and then I was hoping to reset that variable back to the original figure in the KMCNC trajectory planner window. So my dream is to read that number into a variable to store it, reduce it for the c program's purpose and then set it back to the original value before the c program terminates.
Hope this makes sense,
David.
On 9/26/2015 7:03 PM, Tom Kerekes tk@... [DynoMotion] wrote:
Hi David,
DestroyWindow();
Specifically the:
Group: DynoMotion Message: 12324 From: Tom Kerekes Date: 9/26/2015
Hi David,
Temporarily changing the KMotionCNC Trajectory Planner Setting doesn't seem like a good idea because if they somehow don't get set back (by an unexpected program exit) then they can get modified in a confusing manner.  So it seems like a temporary Jog Speed Override is a better idea.  That avoids reading/saving/restoring the settings.  To cancel the override set the factor back to 1.0 which is the reset value when KMotionCNC starts up.
Here is a patch to add the new Jog Override to KMotionCNC.exe.  You will also need to copy in the PC-DSP.h file that has the new command codes definitions for KFLOP to send.
Here is an example showing KFLOP setting the override factors for X and Y
    DoPCFloat(PC_COMM_SET_JOG_OVERRIDE_X, 0.25);
    DoPCFloat(PC_COMM_SET_JOG_OVERRIDE_Y, 0.50);
From: "David Stevenson david.m.stevenson@... [DynoMotion]" <DynoMotion@yahoogroups.com>
Sent: Saturday, September 26, 2015 4:43 PM
Subject: Re: [DynoMotion] Jog Speed System Variable
David.
Hi David,
DestroyWindow();
Specifically the:
Group: DynoMotion Message: 12326 From: David Stevenson Date: 9/27/2015
That worked beautifully! Thank you very much for your help with this!
Best regards,
David.
On 9/27/2015 1:16 AM, Tom Kerekes tk@... [DynoMotion] wrote:
Hi David,
David.
Hi David,
DestroyWindow();
Specifically the:
