Hi Kevin,
Strange. What Application are you using to make the Call? Specificlly which class are you deleting and re-newing? Are you registering call backs?
Message: 3004 |
Date: 1/8/2012 |
| Subject: Re: Interpreter Slows down over time /w KMotion_dotNet |
I have C# program that is communicating to the board via KMotion_dotNet.dll. I'm calling _Controller.Interpreter.Interpret(filename) to start the gCode. I'm registering the InterpreterCompleted callback to stop my timer. After each run, it will take longer to complete the same task.
If I issue the follow and re-initialize my variables, the run will be fast again.
_Controller.Disconnect();
_Controller = null;
_Controller = new KMotion_dotNet.KM_Controller();
Kevin
> Hi Kevin,
> Thanks
> Sent: Sunday, January 8, 2012 12:07 PM
> Subject: [DynoMotion] Interpreter Slows down over time /w KMotion_dotNet
> I've noticed the Interpreter execution time slows down over repeated runs of large GCode files. Even in simulation mode a GCode of about 15,000 lines (ear.ngc) will first take about 1 seconds to run. Then repeated run of the same GCode will increase by 0.05 to 0.1 seconds each time. Has anyone else experienced this? The only work-around I have at the moment is to kill the instance and re-initialize the class.
> Kevin
Message: 3005 |
Date: 1/8/2012 |
Never mind, I found my problem. I was re-registering the same callback every time I hit the run button. I only need to do it once.. duh :)
> _Controller = null;
> Kevin
> > Hi Kevin,
> > Â
> > Â
> > Thanks
> > From: fireup_kev <kliboon@>
> > Â
> > Kevin
