Also there is a "Settings" file for the Interpreter that can force the Initial Interpreter settings to a default state. The Settings file is specified in:
KMotionCNC | Tool Setup | Tool Setup Files | Setup File
These can include Inch/mm mode, XY Plane, etc... and also G92 Axis Offsets. If it contains the following lines to force the Axis Offsets to zero, try removing them.
axis_offset_x 0.0 any real number
axis_offset_y 0.0 any real number
axis_offset_z 0.0 any real number
Message: 10663 |
Date: 12/8/2014 |
| Subject: Re: How To - Fixture Offsets |
Is the best way to edit these to change the file format to .txt and open them up in notepad? Then when complete change the name back to .set?
Scott
Message: 10664 |
Date: 12/8/2014 |
Scott, you should be able to load the files using Notepad by changing the file type drop down menu to 'All files'. However, personally I'd suggest downloading and installing Notepad++. You can then either associate .set file types to Notepad++, or just drag the file you want to open into an open Notepad++ window. The main benefit of Notepad++ is it will maintain the file extension and format, unlike Notepad which will usually keep trying to change the extension to .txt and often change the symbol for new lines so everything ends up on a single line. Moray
Message: 10674 |
Date: 12/15/2014 |
Moray,
Thanks, looks like a good program. I see that there is a place to put values for the X, Y, and Z axis. I would also like to keep the position for the "A" axis. Do you know if I can modify the .Set file to include the A axis as well?
Scott
