Hi Luis,
I don't see any elephants. The only thing I question is why you are using Step/Dir Generators 0,2,4,6 rather than 0,1,2,3.
Each Step/Dir axis only needs to specify one output device so only OutputChan0 is used.
You can check if your hardware is working and wired correctly by toggling bits on the Digital I/O screen. Cycle KFlop power so all bits are still configured as General Purpose I/O. Then set the bit associated with the pin as an Output and Set the bit low, Toggle the bit from an Input to an Output to step the axis.
Good luck,
Message: 664 |
Date: 9/23/2010 |
| Subject: Re: Help need |
Can anybody tell me where the elephants
are?
Best Regards / M.vr.gr
Cees
C.J. Olgers
Message: 665 |
Date: 9/24/2010 |
Thanks a lot the output channels were the problem
Now the 3 motors are moving, no problem in wiring it was just the output channel settings.
Regards, and thanks for the fast advice.
As soon i finish the project will put a video of the robot working it is almost finish
L. R.
--- In DynoMotion@yahoogroups.com, "cees" <c.olgers@...> wrote:
> Can anybody tell me where the elephants are?
> Cees
> C.J. Olgers
Message: 666 |
Date: 9/24/2010 |
Please don't forget the video!
...if I had $0.05 for each promise of a video... :}
Message: 681 |
Date: 10/1/2010 |
Hi Tom
I guess that means I owe you about 2.00$
plus compound interest for what,? 4 years??
CB
> From: lrapso <lrapso@...>
> Sent: Fri, September 24, 2010 8:55:07 AM
> Subject: [DynoMotion] Re: Help need
> settings.
> finish
> L. R.
> > Cees
> > C.J. Olgers
