Group: DynoMotion Message: 7204 From: ricochetproducts Date: 4/7/2013
Subject: Help Getting Started
I have a mill with 3 axis. I am using Kflop, & Kanalog.
My Motors are Brushed servos, and +/- 10 vdc drives. I have glass scales for encoders.
When I go to the Configuration screen I am lost. under axis mode (Input) I selected encoder (Output) DO I SELECT DC SERVO or DAC SERVO? what is the difference? I have tried several different settings but cannot get it to work. I have tried Init3Analog.c when I down loaded it my X axis moved to the right till I disabled the drive. Is this a good file to start with? I am looking to at least be able to jog my axis Kmotion
At the moment I have no limit switches wired. If the init file has these already then I can wire them to Kanalog JP15
I am sure these questions may seem dumb to most but they are real problems for me.
Regards, Steve
Group: DynoMotion Message: 7205 From: Tom Kerekes Date: 4/7/2013
Subject: Re: Help Getting Started
Hi Steve,
To send the Servo Output to the Kanalog DACs select DAC SERVO.  (DC Servo is for a DC Motor connected to SnapAmp).
For Kanalog there is an example starting configuration called: KanalogInitialPID.mot
Load that as a starting point using the Config Screen | Load Channel.
First get your axis configured and tuned using the KMotion Screens (Config, Step Response, Filters) before creating a C Program.
Test that your Amplifier is driving by using DAC commands on the Console (ie DAC0=200).
Test whether your Encoder is working by observing the Axis Screen
Then Enable the Servo.
Group: DynoMotion Message: 7207 From: ricochetproducts Date: 4/7/2013
Hi Tom, Thanks for your quick response. I will check it.
> Hi Steve,
> HTH
> From: ricochetproducts <steveklemp@...>
> Sent: Sunday, April 7, 2013 1:03 PM
> Subject: [DynoMotion] Help Getting Started
> Regards, Steve
