I am using a touch-screen monitor with the PC for the kflop on my 3-axis mill. I'm running KMotionCNC, and the whole thing is a very simple setup and works great! Michael Rosenfield
Message: 10526 |
Date: 11/20/2014 |
| Subject: Re: HMI Touchscreen for KFlop |
Thanks Dan.
I have little knowledge of C programming, but in following some of
the recent posts regarding Modbus I was pretty much lost. Most
likely I will find a used unit and do some experimenting.
David.
I would think any that allow you to use RS232
Modbus RTU at a compatible data rate could be made to
work. Without knowing your experience in C programming
or programming industrial controls it might be steep
learning curve, or it might be a piece of cake for
you.
I have a KFLOP/KANALOG connected to a Automation
Direct Do-More PLC and that is connected to a
Automation Direct C-More Micro 6” HMI. I am using this
setup because the price was right. I would use a
Automation Direct CLICK PLC if I were to be buying the
parts new. I am doing this because I needed additional
I/O and the PLC currently has 4 serial ports and is
plenty fast to hand being the “middle man”. I am not
using the HMI for any functions yet, just some testing
because I have no place to mount it yet.
Dan
Sent: Wednesday, November 19, 2014
8:17 PM
Subject: [DynoMotion] HMI Touchscreen
for KFlop
Hello Everyone,
I am looking for a touchscreen HMI unit which
would be a good fit for a KFlop/SnapAmp-controlled
lathe. Has anyone come across one that you would
recommend?
What kind of features should I watch for with
regard to connectivity?
David.
Message: 10527 |
Date: 11/20/2014 |
Hi Michael,
I wonder if the PC is the key. Does KFlop need the PC to run custom
routines? I do use a couple of Windows based special programs.
David.
On 11/19/2014 10:46 PM, Michael
Michael Rosenfield
Message: 10528 |
Date: 11/20/2014 |
David, I'm a little rusty on this - have to wake up the old brain cells! The KFlop itself doesn't specifically need a pc (after it has been configured) but it does need something to tell it what to do. So, for the milling application, something needs to organize the motion commands and then send them to the KFlop. For that, I use DynoMotion's KMotionCNC software, which runs on the PC. Lots of people use another PC-based set of software called Mach3. Both of these allow custom routines to be fed to the KFlop, and both allow varying amounts of customization to the operating console display screen, which is the PC monitor. The beauty of the KFlop is that it can be easily customized for any application, as long as you have someone to write the software for it. For common machine tools, many people have already written this, so there's a lot out there to use. Dynomotion's tech support is second to none, and the user group is also fantastic. KMotionCNC supports custom routines with a screen button press, and they are very straightforward to implement, as long as you can do some C programming. As I said, lots of help is available in this area! Customizing the screen look of KMotionCNC is more limited (as of a year ago; I haven't looked at any changes since then) unless you want to do some heavy C programming under Windows. But I found it more than adequate for dealing with my mill. Of course, the HMI is just another computer that has been pre-programmed to make user-customization of the look very easy. I looked into one for my mill, but I found them to be very expensive - close to $1000, as I recall. I ended up finding a used touch-screen monitor on EBay for $250, and although it is not as compact as many of the HMI's, functionally it is perfect. One still needs a keyboard for the PC for some applications - especially PC maintenance and file handling - but it's generally not used while making parts. A bit long winded, but I hope this helps! Michael
Message: 10529 |
Date: 11/20/2014 |
Hi David,
I think you need a Windows PC for your application (rather than a PLC type HMI). Our GCode Interpreter, Trajectory Planner, Coordinated Motion Libraries, KMotionCNC GUI, and the TeachMotion Program you use all currently require to run on a Microsoft Windows PC. KFLOP is capable of running in stand-alone mode without a PC for some simpler applications but I don't think that applies to you.
I'd suggest a Windows PC with a reasonably sized touch screen monitor. I had a W8 Laptop that had a Keyboard Failure. I found that I could operate everything quite nicely with the pop-up on-screen keyboard.
Let us know what you decide and how it works out.
Message: 10530 |
Date: 11/20/2014 |
Hi TK, That is a good news for me. I have a project for a Automatic Glue Applicator and it will be excellent if the path can be loaded through USB/RS232 interface and run without any additional hardware (PC & monitor). So, could you be more detailed about how you can run a simple app direct from KFLOP? Thanks, Adrian From: DynoMotion@yahoogroups.com [mailto:DynoMotion@yahoogroups.com] Sent: November 20, 2014 12:20 PM To: DynoMotion@yahoogroups.com Subject: Re: [DynoMotion] HMI Touchscreen for KFlop I think you need a Windows PC for your application (rather than a PLC type HMI). Our GCode Interpreter, Trajectory Planner, Coordinated Motion Libraries, KMotionCNC GUI, and the TeachMotion Program you use all currently require to run on a Microsoft Windows PC. KFLOP is capable of running in stand-alone mode without a PC for some simpler applications but I don't think that applies to you. I'd suggest a Windows PC with a reasonably sized touch screen monitor. I had a W8 Laptop that had a Keyboard Failure. I found that I could operate everything quite nicely with the pop-up on-screen keyboard. Let us know what you decide and how it works out.
From: "Michael Rosenfield mrosenfield@... [DynoMotion]" <DynoMotion@yahoogroups.com> To: "DynoMotion@yahoogroups.com" <dynomotion@yahoogroups.com> Sent: Thursday, November 20, 2014 7:21 AM Subject: RE: [DynoMotion] HMI Touchscreen for KFlop David, I'm a little rusty on this - have to wake up the old brain cells! The KFlop itself doesn't specifically need a pc (after it has been configured) but it does need something to tell it what to do. So, for the milling application, something needs to organize the motion commands and then send them to the KFlop. For that, I use DynoMotion's KMotionCNC software, which runs on the PC. Lots of people use another PC-based set of software called Mach3. Both of these allow custom routines to be fed to the KFlop, and both allow varying amounts of customization to the operating console display screen, which is the PC monitor. The beauty of the KFlop is that it can be easily customized for any application, as long as you have someone to write the software for it. For common machine tools, many people have already written this, so there's a lot out there to use. Dynomotion's tech support is second to none, and the user group is also fantastic. KMotionCNC supports custom routines with a screen button press, and they are very straightforward to implement, as long as you can do some C programming. As I said, lots of help is available in this area! Customizing the screen look of KMotionCNC is more limited (as of a year ago; I haven't looked at any changes since then) unless you want to do some heavy C programming under Windows. But I found it more than adequate for dealing with my mill. Of course, the HMI is just another computer that has been pre-programmed to make user-customization of the look very easy. I looked into one for my mill, but I found them to be very expensive - close to $1000, as I recall. I ended up finding a used touch-screen monitor on EBay for $250, and although it is not as compact as many of the HMI's, functionally it is perfect. One still needs a keyboard for the PC for some applications - especially PC maintenance and file handling - but it's generally not used while making parts. A bit long winded, but I hope this helps! Michael
To: DynoMotion@yahoogroups.com From: DynoMotion@yahoogroups.com Date: Thu, 20 Nov 2014 06:26:58 -0500 Subject: Re: [DynoMotion] HMI Touchscreen for KFlop
Hi Michael,
I wonder if the PC is the key. Does KFlop need the PC to run custom routines? I do use a couple of Windows based special programs.
Thanks, David. On 11/19/2014 10:46 PM, Michael Rosenfield mrosenfield@... [DynoMotion] wrote: I am using a touch-screen monitor with the PC for the kflop on my 3-axis mill. I'm running KMotionCNC, and the whole thing is a very simple setup and works great! Michael Rosenfield
To: DynoMotion@yahoogroups.com From: DynoMotion@yahoogroups.com Date: Wed, 19 Nov 2014 21:29:03 -0600 Subject: Re: [DynoMotion] HMI Touchscreen for KFlop
I would think any that allow you to use RS232 Modbus RTU at a compatible data rate could be made to work. Without knowing your experience in C programming or programming industrial controls it might be steep learning curve, or it might be a piece of cake for you. I have a KFLOP/KANALOG connected to a Automation Direct Do-More PLC and that is connected to a Automation Direct C-More Micro 6” HMI. I am using this setup because the price was right. I would use a Automation Direct CLICK PLC if I were to be buying the parts new. I am doing this because I needed additional I/O and the PLC currently has 4 serial ports and is plenty fast to hand being the “middle man”. I am not using the HMI for any functions yet, just some testing because I have no place to mount it yet. Sent: Wednesday, November 19, 2014 8:17 PM Subject: [DynoMotion] HMI Touchscreen for KFlop Hello Everyone,
I am looking for a touchscreen HMI unit which would be a good fit for a KFlop/SnapAmp-controlled lathe. Has anyone come across one that you would recommend?
What kind of features should I watch for with regard to connectivity?
Thanks, David.
Message: 10531 |
Date: 11/20/2014 |
Hi Adrian,
Could you give more details on your application? If or how often would the pattern change? How complex would the Pattern be? Are you capable of writing a Windows Program to send the Pattern to KFLOP via USB? What is your background?
Message: 10532 |
Date: 11/20/2014 |
Hi TK, The job requirements is to change the path, that consists of lines and arcs, once in a while. My background is in electronics, I know a bit of C ( C for microcontrollers ) but finding someone to help me with a windows program won't be a problem if I can define very well the requirements. I am thinking of a KFLOP ( microcontroller) interface, to be able to transfer the path info from an external memory, like USB or SD card. Will be this approach a good one or is it to much headache for something that can be done with a cheap PC ? Thanks, Adrian From: DynoMotion@yahoogroups.com [mailto:DynoMotion@yahoogroups.com] Sent: November 20, 2014 1:46 PM To: DynoMotion@yahoogroups.com Subject: Re: [DynoMotion] HMI Touchscreen for KFlop Could you give more details on your application? If or how often would the pattern change? How complex would the Pattern be? Are you capable of writing a Windows Program to send the Pattern to KFLOP via USB? What is your background?
From: "'Adrian Balan' adrian@... [DynoMotion]" <DynoMotion@yahoogroups.com> To: DynoMotion@yahoogroups.com Sent: Thursday, November 20, 2014 10:31 AM Subject: RE: [DynoMotion] HMI Touchscreen for KFlop That is a good news for me. I have a project for a Automatic Glue Applicator and it will be excellent if the path can be loaded through USB/RS232 interface and run without any additional hardware (PC & monitor). So, could you be more detailed about how you can run a simple app direct from KFLOP? From: DynoMotion@yahoogroups.com [mailto:DynoMotion@yahoogroups.com] Sent: November 20, 2014 12:20 PM To: DynoMotion@yahoogroups.com Subject: Re: [DynoMotion] HMI Touchscreen for KFlop I think you need a Windows PC for your application (rather than a PLC type HMI). Our GCode Interpreter, Trajectory Planner, Coordinated Motion Libraries, KMotionCNC GUI, and the TeachMotion Program you use all currently require to run on a Microsoft Windows PC. KFLOP is capable of running in stand-alone mode without a PC for some simpler applications but I don't think that applies to you. I'd suggest a Windows PC with a reasonably sized touch screen monitor. I had a W8 Laptop that had a Keyboard Failure. I found that I could operate everything quite nicely with the pop-up on-screen keyboard. Let us know what you decide and how it works out.
Hi Michael,
Thanks, David.
Message: 10533 |
Date: 11/20/2014 |
Hi Adrian,
You didn't really answer how complex the pattern would be. How many lines and arcs would be required to describe the path? Would the Lines and Arcs be sufficiently long such that the acceleration/decelleration could be performed entirely within one Line or Arc? Or would more complicated trajectory planning be required?
KFLOP has ~ 1MByte of Flash memory. Would that be sufficient to describe the path?
KFLOP is a USB client. It isn't a Host that can read USB Thumb Drives. You might write a PC program to download an Flash the pattern data to KFLOP's memory.
You might look at the example CoordMotionInKFLOPTest.c
I recall one user made a Cake Decorating machine that was repeatedly used to dispense "Happy Birthday" onto cakes. He used a trick where he used KMotionCNC to download the motion to KFLOP's Coordinated motion Buffer and run the pattern once. He then simply Flashed an image of the Coordinated Motion Buffer Memory. On the next Power Up cycle he just restored the image.
Message: 10534 |
Date: 11/21/2014 |
Thanks very much to everyone.
It looks like I had better stick to the PC and I will certainly let
you know what I come up with.
Best regards,
David.
On 11/20/2014 12:19 PM, Tom Kerekes
tk@... [DynoMotion] wrote:
Hi David,
I think you need
you.
I'd suggest a
Let us know what
Message: 10535 |
Date: 11/21/2014 |
Hi TK, That's a good news. My application is less complex than a "Happy Birthday" text, so it is possible and I will start experimenting. Thanks for guidance and support, Adrian From: DynoMotion@yahoogroups.com [mailto:DynoMotion@yahoogroups.com] Sent: November 20, 2014 7:53 PM To: DynoMotion@yahoogroups.com Subject: Re: [DynoMotion] HMI Touchscreen for KFlop You didn't really answer how complex the pattern would be. How many lines and arcs would be required to describe the path? Would the Lines and Arcs be sufficiently long such that the acceleration/decelleration could be performed entirely within one Line or Arc? Or would more complicated trajectory planning be required?
KFLOP is a USB client. It isn't a Host that can read USB Thumb Drives. You might write a PC program to download an Flash the pattern data to KFLOP's memory. You might look at the example CoordMotionInKFLOPTest.c I recall one user made a Cake Decorating machine that was repeatedly used to dispense "Happy Birthday" onto cakes. He used a trick where he used KMotionCNC to download the motion to KFLOP's Coordinated motion Buffer and run the pattern once. He then simply Flashed an image of the Coordinated Motion Buffer Memory. On the next Power Up cycle he just restored the image.
From: "'Adrian Balan' adrian@... [DynoMotion]" <DynoMotion@yahoogroups.com> To: DynoMotion@yahoogroups.com Sent: Thursday, November 20, 2014 11:46 AM Subject: RE: [DynoMotion] HMI Touchscreen for KFlop The job requirements is to change the path, that consists of lines and arcs, once in a while. My background is in electronics, I know a bit of C ( C for microcontrollers ) but finding someone to help me with a windows program won't be a problem if I can define very well the requirements. I am thinking of a KFLOP ( microcontroller) interface, to be able to transfer the path info from an external memory, like USB or SD card. Will be this approach a good one or is it to much headache for something that can be done with a cheap PC ? From: DynoMotion@yahoogroups.com [mailto:DynoMotion@yahoogroups.com] Sent: November 20, 2014 1:46 PM To: DynoMotion@yahoogroups.com Subject: Re: [DynoMotion] HMI Touchscreen for KFlop Could you give more details on your application? If or how often would the pattern change? How complex would the Pattern be? Are you capable of writing a Windows Program to send the Pattern to KFLOP via USB? What is your background?
Hi Michael,
Thanks, David.
Message: 10536 |
Date: 11/21/2014 |
Message: 10538 |
Date: 11/21/2014 |
Hi David,
I have Shuttle X50V2 all-in-one PCs on both of my
mills running Mach3 and KFlop. They got big enough resistive touch screen
so that screen buttons
can be made big. Since they are Intel Atom based
PCs I have stripped down WinXp's on them.
If You happen to end up with one of these remember
to install a scratch resistant screen cover/foil.
Rgds,
Tapio
----- Original Message -----
Sent: Friday, November 21, 2014 1:35
PM
for KFlop
the PC and I will certainly let you know what I come up with.
Best
regards, David.
On 11/20/2014 12:19 PM, Tom Kerekes tk@... [DynoMotion]
wrote:
Hi David,
you.
works out.
Message: 10540 |
Date: 11/21/2014 |
Hi Tapio,
I didn't even realize there was an all-in-one PC, but it looks like
a great solution and they seem to be priced not to badly.
Thanks for the pointer regarding the screen protector... sounds like
great advice!
Best regards,
David.
Hi David,
all-in-one PCs on both of my mills running Mach3 and
KFlop. They got big enough resistive touch screen so
that screen buttons
are Intel Atom based PCs I have stripped down WinXp's on
them.
with one of these remember to install a scratch
Rgds,
Tapio
Sent: Friday,
November 21, 2014 1:35 PM
Subject: Re:
Best regards,
David.
Kerekes tk@...
[DynoMotion] wrote:
Hi
David,
I think
you.
I'd
Let us
Message: 10543 |
Date: 11/21/2014 |
