Many Thanks for all your advices,
Before change anythings on the motor configuration, I make some test and I try to run GCode on the KMotion menu, instead of KMotionCNC, attached here some picture.
On KMotion menu, the GCode was working well and I saw the servo motor turn, But when I run the GCode on the KMotionCNC, the message " G Code error" appear.
Is there any file or some configuration on the KMotionCNC need some setting?
Anyway, I will change the configuration of the motor set up and the C program follow your advice first, I will let you know the result of the test.
Thanks again for all your assist,
ASM
