Ray,
G54-59 select different offset settings. Off all the fixture offsets are set to the same thing or zero then there won't be any change
Message: 3895 |
Date: 2/14/2012 |
| Subject: Re: Fixture Offsets - What Am I Missing? |
In Mach3, I would use G54-59 to select a fixture, then move the machine to the zero for that fixture, and zero the DROs. If I then change fixtures with G54-59, the DROs would change, to reflect the different offsets set for the different fixtures. I can't get that behavior at all with KMotionCNC. G54-G59 seem to have no effect whatsoever that I can see. The DROs NEVER change when I execute a G54-49, no matter what I've done to the DROs.
Ray L.
> Ray,
> Sent: Tuesday, February 14, 2012 3:52 PM
> Subject: [DynoMotion] Fixture Offsets - What Am I Missing?
> I'm confused by what I see when I try to use fixture offsets. If I fire up KMotionCNC, then set the DROS to X=1.0, Y=2.0, Z=3.0, A=4.0, then MDI "G55", I expect to see the DROs go back to all zeroes. But, instead they don't change at all. Why does changing fixtures with G54-G59 appear to have no effect?
> Regards,
> Ray L.
Message: 3896 |
Date: 2/14/2012 |
Hi Ray,
The only way to set the Fixture Offsets in KMotionCNC is with G10 (or maybe with the .var file). ie.
G10L2P1X0Y0Z0 (Set G54 offset to 0,0,0 used by default) G10L2P2X2Y0Z0 (Set G55 offset to 2,0,0) G10L2P3X0Y2Z0 (Set G55 offset to 0,2,0)
I think in the .NET interface Brad put in ways to set them from your App.
The "Zero" on the KMotionCNC affects the G90 global offset which is different than the "Zero" button in Mach3 which changes the "work" or fixture offset.
I don't know which is better. We haven't had any complaints. Isn't the idea of fixtures such that there is a fixed known distance between them so you don't need to zero each one separately?
Message: 3897 |
Date: 2/14/2012 |
I've always found the most convenient way to set fixture offsets is to use the same methods used for setting G92 - position the machine using probing/edge finding/etc. to part zero (or some other reference position), then set the DROs. Or, if there is a known offset between fixtures, locate to one fixture zero, then change fixtures and enter the proper new values into the DROs. Your way works, just more typing.
"The "Zero" on the KMotionCNC affects the G90 global offset" - Do you mean G92? G90 sets absolute distance mode.
Ray L.
> Hi Ray,
> I think in the .NET interface Brad put in ways to set them from your App.Â
> Sent: Tuesday, February 14, 2012 4:03 PM
> Subject: [DynoMotion] Re: Fixture Offsets - What Am I Missing?
> Tom,
> Regards,
> Ray L.
> > Ray,
> > ÃÂ
> > G54-59 select different offset settings.ÃÂ Off all the fixture offsets are set to the same thing or zero then there won't be any change
> > ÃÂ
> > ÃÂ
> > Regards,
> > Ray L.
Message: 3898 |
Date: 2/14/2012 |
I've modified my app to work the way Mach3 does, so I'm happy.
I'm curious though.... In Mach3, G92 and G52 were frought with peril, and an area of many bugs. As a result, they were rarely, and very carefully, used. Are there any such issues in the KMotion interpreter? I'm guessing not?
Ray L.
> Tom,
> Regards,
> Ray L.
> > Hi Ray,
> > Â
> > Â
> > Â
> > Â
> > Â
> > Â
> > Â
> > Â
> > Â
> > Â
> > Â
> > Tom,
> > Regards,
> > Ray L.
> > > Ray,
> > > ÃÂ
> > > ÃÂ
> > > ÃÂ
> > > Regards,
> > > Ray L.
Message: 3899 |
Date: 2/14/2012 |
Yes I meant G92
Message: 3900 |
Date: 2/14/2012 |
None that I'm aware of.
Message: 3901 |
Date: 2/15/2012 |
I'm trying to make sure I understand how to properly calculate offsets, when G54-59, and G92/52 are involved. If G92/52 are not involved, it's quite simple. But when G92/52 are brought in, it seems to me rather confusing (a shame, since I think it could have been pretty simple had they been defined differently....). But it appears to me when setting G92/52 or G54-59 offsets I need to look at current machine position, and G92/52 offsets (in parameters 5211-5216), and the desired new, final work coordinate to calculate the offsets correctly. I believe the calculation (for X axis, G54) looks like this:
XCurrentWorkPos = XMachinePos - G92XOffset - G54XOffset ==>
XCurrentWorkPos = XMachinePos - [#5211] - G54XOffset
So, if we want to calculate the G54Offset to put us at XNewWorkPos:
G54XOffset = XMachinePos - [#5211] - XNewWorkPos
which we can set with:
G10 L2 P2 X[XMachinePos - [#5211] - XNewWorkPos]
Can I also do this programmatically using:
KM_Controller.Interpreter.SetupParams.X_AxisOffset?
To shift the G92 offset to put the work position at XNewWorkPos:
G92XOffset = XMachinePos - G54XOffset - XNewWorkPos
which we can set with either:
G92 XCurrentWorkPos or:
G52 [XMachinePos - G54XOffset - XNewWorkPos]
KMController.Interpreter.SetupParams.X_OriginOffset? Will this update #5211?
Do I have this right?
Ray L.
> Sent: Tuesday, February 14, 2012 6:09 PM
> Tom,
> Regards,
> Ray L.
> > Tom,
> > Regards,
> > Ray L.
> > > Hi Ray,
> > > ÃÂ
> > > The only way to set the Fixture Offsets in KMotionCNC is with G10 (or maybe with the .var file).ÃÂ ie.
> > > ÃÂ
> > > ÃÂ
> > > I think in the .NET interface Brad put in ways to set them from your App.ÃÂ
> > > ÃÂ
> > > ÃÂ
> > > I don't know which is better.ÃÂ We haven't had any complaints.ÃÂ Isn't the idea of fixtures such that there is a fixed known distance between them so you don't need to zero each one separately?
> > > ÃÂ
> > > Regards
> > > ÃÂ
> > > ÃÂ
> > > ÃÂ
> > > ÃÂ
> > > ÃÂ
> > > Tom,
> > > Regards,
> > > Ray L.
> > > > Ray,
> > > > ÃâÃÂ
> > > > G54-59 select different offset settings.ÃâàOff all the fixture offsets are set to the same thing or zero then there won't be any change
> > > > ÃâÃÂ
> > > > TK
> > > > ÃâÃÂ
> > > > Regards,
> > > > Ray L.
