Hi all, Posted a month or so ago that I purchased a Kflop to replace my Parallel Port controlled Mach 3 setup. In the process, I'd really like to add encoders to my stepper system to be used in closed loop mode. If the homing between Mach 3 and Kmotion is similar, I may used the Mach 3 plug in in open loop or simply missed step mode while I'm getting used to Kmotion and then ultimately switch over to Kmotion once I have all of the macro functionality I have in Mach 3 replicated in Kmotion.
I'm planning on adding 3 encoders, on the X,Y, and Z axes, either 2000 or 4000 line count depending on what I hear in terms of performance requirements. Encoders will be single ended wired directly into the Kflop as I simply can't afford something like a kanalog right now.
The rest of my setup is based on a G540 with the standard parallel port wiring. Here's the wiring I intend on doing. The Kflop box will have a DB25 output that plugs into the G540 and then 3 additional connectors for the encoders. I might add an mpg into the kflop as well as I've gotten used to using the Shuttle express for certain machining operations.
Could you guys have a look at this wiring setup and let me know if that looks pretty good?
TIA
-Andy
| Kflop JP7 |
G540 DB25 |
| VDD33 |
+3.3 Volts Output |
1 |
| VDD33 |
+3.3 Volts Output |
2 |
| VDD12 |
+12 Volts Output |
3 |
| RESET# |
Power up Reset (low true) output |
4 |
| IO44 |
Gen Purpose LVTTL I/O (3.3V Only) |
5 |
| IO45 |
6 |
| IO0 |
Gen Purpose LVTTL I/O (5V Tolerant) or Encoder 0 Input Phase A |
7 |
10 |
Limit/home Switches (opto isolated) G540 Input 1 |
| IO1 |
Gen Purpose LVTTL I/O (5V Tolerant) or Encoder 0 Input Phase B |
8 |
11 |
Probe (opto isolated) G540 Input 2 |
| IO2 |
Gen Purpose LVTTL I/O (5V Tolerant) or Encoder 1 Input Phase A |
9 |
12 |
Pendant Button 1 Cycle Start G540 Input 3 |
| IO3 |
Gen Purpose LVTTL I/O (5V Tolerant) or Encoder 1 Input Phase B |
10 |
13 |
Pendant Button 2 Feedhold G540 Input 4 |
| IO4 |
Gen Purpose LVTTL I/O (5V Tolerant) or Encoder 2 Input Phase A |
11 |
14 |
Spindle PWM Signal |
| IO5 |
Gen Purpose LVTTL I/O (5V Tolerant) or Encoder 2 Input Phase B |
12 |
15 |
Fault / Soft E-stop (supported in Mach 3 may not be necessary) Pin 10 on input or internal fault sets bit |
| IO6 |
Gen Purpose LVTTL I/O (5V Tolerant) or Encoder 3 Input Phase A |
13 |
16 |
Charge Pump?? Is this supported by Kflop/Kmotion? |
| IO7 |
Gen Purpose LVTTL I/O (5V Tolerant) or Encoder 3 Input Phase B |
14 |
17 |
Spindle Run |
| IO8 |
Gen Purpose LVTTL I/O (5V Tolerant) or Axis 0 Home (or Step 0 output) |
15 |
2 |
X Step |
| IO9 |
Gen Purpose LVTTL I/O (5V Tolerant) or Axis 1 Home (or Dir 0 output) |
16 |
3 |
X Dir |
| IO10 |
Gen Purpose LVTTL I/O (5V Tolerant) or Axis 2 Home (or Step 1 output) |
17 |
4 |
Y Step |
| IO11 |
Gen Purpose LVTTL I/O (5V Tolerant) or Axis 3 Home (or Dir 1 output) |
18 |
5 |
Y Dir |
| IO12 |
Gen Purpose LVTTL I/O (5V Tolerant) or Axis 0 + Limit (or Step 2 output) |
19 |
6 |
Z Step |
| IO13 |
Gen Purpose LVTTL I/O (5V Tolerant) or Axis 0 - Limit (or Dir 2 output) |
20 |
7 |
Z Dir |
| IO14 |
Gen Purpose LVTTL I/O (5V Tolerant) or Axis 1 + Limit (or Step 3 output) |
21 |
8 |
A Step |
| IO15 |
Gen Purpose LVTTL I/O (5V Tolerant) or Axis 1 - Limit (or Dir 3 output) |
22 |
9 |
B Dir |
| VDD5 |
+5 Volts Output |
23 |
Hooked to Encoder +5v, not run to G540 |
| VDD5 |
+5 Volts Output |
24 |
| GND |
Digital Ground |
25 |
18 |
GND |
| GND |
Digital Ground |
26 |
| KFLOP JP5 |
| IO36 |
Gen Purpose LVTTL I/O (5V Tolerant) or (or Step 4 output) or (Encoder 4 Input Phase A) |
1 |
X Encoder A |
5 v Direct |
| IO37 |
Gen Purpose LVTTL I/O (5V Tolerant) or (or Dir 4 output) or (Encoder 4 Input Phase B) |
2 |
X Encoder B |
5 v Direct |
| IO38 |
Gen Purpose LVTTL I/O (5V Tolerant) or (or Step 5 output) or (Encoder 5 Input Phase A) |
3 |
Y Encoder A |
5 v Direct |
| IO39 |
Gen Purpose LVTTL I/O (5V Tolerant) or (or Dir 5 output) or (Encoder 5 Input Phase B) |
4 |
Y Encoder B |
5 v Direct |
| IO40 |
Gen Purpose LVTTL I/O (5V Tolerant) or (or Step 6 output) or (Encoder 6 Input Phase A) |
5 |
Z Encoder A |
5 v Direct |
| IO41 |
Gen Purpose LVTTL I/O (5V Tolerant) or (or Dir 6 output) or (Encoder 6 Input Phase B) |
6 |
Z Encoder B |
5 v Direct |
| IO42 |
Gen Purpose LVTTL I/O (5V Tolerant) or (or Step 7 output) or (Encoder 7 Input Phase A) |
7 |
MPG Direct ?? I've gotten used to using an mpg for certain operations |
| IO43 |
Gen Purpose LVTTL I/O (5V Tolerant) or (or Dir 7 output) or (Encoder 7 Input Phase B) |
8 |
