Hi David,
I
believe there is a bug in the data capture. It appears to be in all
previous versions as well. The Step Response Screen was starting to
upload the plot data when the Move Motion was complete but not necessarily
when all the data has been captured (some extra data sitting still after the
move is captured). So with a small quick move, with a long data capture
time, on a fast PC, there can be a race condition. KMotion might upload
data before it was defined which might result in the Plot to crash.
The
default Step Response settings after a program install is a good candidate for
this. Small Move Size with 3.5sec of data capture. Try reducing
the capture time to be the time for the move (or less).
Or
please try this patched KMotion.exe to see if it resolves your problem.
Copy to the KMotion431f\KMotion\Release directory.
http://dynomotion.com/Software/Patch/FixStepResponseRaceCondition431f/KMotion.exe
Message: 7867 |
Date: 7/7/2013 |
| Subject: Re: Error Window |
Hello Tom,
I applied the patch and everything seems to be working fine.
Thanks!
David
--- In DynoMotion@yahoogroups.com, "David Stevenson" <david.m.stevenson@...> wrote:
> Hi Tom,
> I will try the patch.
> Because my machine moves quite slowly, the 1" move I use takes about 4 seconds so the data collection is usually done before the move is complete.
> Thank you,
> David.
